Rear Limited-Slip Differential?
Discussion in '5th Gen 4Runners (2010-2024)' started by icebear, Mar 22, 2024.
  1. Mar 22, 2024 at 11:44 AM
    icebear [OP] Member
    I was curious and found mentions on the net of torsen/True-Trac/helical LSDs going into the rears of 3rd and 4th gens, a Tacoma but not any 5th gen that I could see.
    I'd guess between traction control, a rear locker and the Limited's full-time 4WD it would be pretty niche and most appealing to SR5/TRD Sport models. I was thinking it'd be nice to have in wet pavement conditions.
    Has it ever happened? Does such an aftermarket fitment exist?
  2. Mar 22, 2024 at 12:48 PM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid (modified) RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ Apache CF220 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Lasfit LED Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    I am curious about this as well. Although I haven't heard of the option for the 5th Gen 4R.
    When I purchased my 4Runner I was worried that the open diffs meant it's less capable in certain conditions. When I experienced how well the traction control system and stability control systems work my mind was put to ease. The rig detects and reacts to slip very quickly and sends power where it needs to be. The only time the lack of an LSD comes up is when I come to a stop and hold the traction control button for a few seconds. This disables traction control and stability control. With these systems deactivated the 4R is pretty helpless in low traction/ 2-hi scenarios. The rear right wheel just spins like crazy.
    Coming from the sports car world clutch style or VLSD's do wear out and need to be rebuilt every once in a while. Maybe since the 4R is such a long lasting vehicle Toyota wanted to remove the need for this? Plus Toyota's TC and SCS work so well it may be a redundant system.
    Another thing to consider is ATRAC and MTS would in theory work against an LSD. So that's probably another reason they kept the diff open.
    This is all just conjecture of course. An interesting topic for sure.
  3. Mar 22, 2024 at 12:55 PM
    Startrek
    Startrek New Member
    " The only time the lack of an LSD comes up is when I come to a stop and hold the traction control button for a few seconds. This disables traction control and stability control." - why would I do it ?
  4. Mar 22, 2024 at 12:57 PM
    1SilverRunner
    Tejas
    Why would you disable traction and stability control?
    Because
    icebear[OP] likes this.
  5. Mar 22, 2024 at 1:06 PM
    1SilverRunner
    Tejas
    Come to think of it maybe MTS and ATRAC would benefit from an LSD?
    This is just speculation after all.
  6. Mar 22, 2024 at 4:43 PM
    icebear [OP] Member
    Traction/stability control and it not being very popular when it was around definitely means no factory LSD in most non-performance vehicles from the factory. IIRC the RAV4, Highlander, RX, Celica? at some point had a torsen rear option up to around 20 years ago.
    I don’t think one would improve MTS or ATRAC much directly but I think it might result in less clatter by keeping power going to both sides more evenly before either intervenes and help out in 2H and 4H where traction control is less aggressive.
    1SilverRunner likes this.
  7. Jan 18, 2025 at 3:06 PM
    icebear [OP] Member
    Update: Asked 4 Wheel Parts while I was there if any rear LSD’s, according to them or at least out of what they sell, exist for our fitment and the answer is no, just various lockers.
  8. Jan 18, 2025 at 4:29 PM
    Agent_Outside
    Built 2011 T4R Limited
    Fun fact: the McLaren P1 hypercar uses an open diff because utilizing the brakes and electronics was more efficient than adding the extra weight of a limited slip.
  9. Jan 18, 2025 at 4:34 PM
    I think the 2wd 5 gen gets a LSD.
  10. Jan 18, 2025 at 4:49 PM
    FourBelugas
    FourBelugas New Member
    23 white ORP
    It's a brake actuated simulated LSD I think, not a traditional LSD like clutchpack or helical gear set up.
  11. Jan 18, 2025 at 4:53 PM
    It’s an open diff. I believe there is a mechanical LSD option out there.
  12. Jan 18, 2025 at 4:55 PM
    icebear [OP] Member
    Same with the Dodge Caliber SRT-4! ;)
  13. Jan 18, 2025 at 5:13 PM
    The 8.2" is an oddball size yeah. I don't see any mechanical LSD options for it on ECGS' website.
    Meanwhile all the McLarens other than the P1, including the more hardcore Senna, have mechanical LSD available as an aftermarket upgrade: https://www.m-engineering.us/products/mclaren-lsd-differential?variant=37417714679976
    icebear[QUOTED][OP] likes this.
  14. Jan 18, 2025 at 5:29 PM
    Ok, I might have been thinking of the older 4R/Tacomas before the introduction of electronic traction aids.
  15. Jan 18, 2025 at 6:01 PM
    icebear [OP] Member
    Another fun fact, rear torsen LSDs were an uncommon option on the RAV4, Highlander, RX before traction/stability control showed up!
  16. Jan 18, 2025 at 6:09 PM
    bassist
    bassist New Member
    2023 TRD Offroad Premium
    I had a CJ with a limited slip once.
    It caused a clutch issue to suddenly become a driveshaft and axle issue.
    That was fun.
  17. Jan 18, 2025 at 6:45 PM
    Sin4R
    Distant land called Timbuktu
    2024 4Runner Limited
    Mall crawling kit.
    Proper LSD is very expensive mechanical part and it is only slightly better than modern brake-based simulated LSD. Mechanical LSD only makes sense in applications where you don't want to apply brakes because doing so reduces maximum acceleration and/or reduces grip available for cornering, such as track-focused RWD performance car. LSD also has lower maximum torque it can take when compared to open diff, so there are some cases where it can't be used.
  18. Jan 28, 2025 at 5:12 AM
    Greg D
    Greg D New Member
    Greg
    2013 4runner
    They have auto LSD rear. Which is funny because it's working if it's moving. I seldom slip a rear wheel, but unlike a locker, it works at all speeds and larger ring gear than a locker. My Limited is pretty impressive with slick tires and traction.
  19. Jan 28, 2025 at 12:12 PM
    icebear [OP] Member
    "Automatic Limited-Slip Differential (Auto LSD)" is Toyota's marketing speak for a more aggressive brake traction control mode, it's either an open or locking differential in the rear axle of all 5th gens.
    This also annoys me because C&D states "A limited-slip rear diff is included on all but [e-locker trims]" which is completely untrue but that's what Toyota puts on the spec sheet of every 2WD 4Runner.
    Assuming your Limited is 4WD, it has a true "limited-slip center differential with locking feature" as Toyota says on the spec sheet which is completely correct.
    I think it's as egregious as Kia calling it's "more center clutch pressure please" mode a center locker.
    TimGinCentralNJ likes this.
