Rear left wheel caster is off after 3" lift
Discussion in '4th Gen 4Runners (2003-2009)' started by Djordhan, Jan 2, 2025.
  1. Jan 2, 2025 at 8:58 PM
    Djordhan
    Djordhan [OP] New Member
    2007 4Runner Limited V8
    2"-3" lift kit.
    Hello!
    Just finished lifting my 2007 limited with Icon springs in the rear and now my rear left wheel is a little too far back, almost touching the mud flap. My right rear wheel is centered in the well so I assume my axle is not perpendicular with the frame and that doesn't sound good to me!
    I'm not familiar with any adjustment in the rear that could correct that easily so I suspect that it's coming from the adapter I used to hold the bottom of the spring. Maybe I installed it a little too far towards the front of the axle, therefore pushing the axle backwards when the spring is compressed. Does that make sense?
    Any idea or recommendation?
    Thanks!
    JD
  2. Jan 3, 2025 at 5:49 AM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid (modified) RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ Apache CF220 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Lasfit LED Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    Check your lower links and mounts. They do bend pretty easily when off roading.
    The links locate your axle in the middle of the wheel well. Your panhard bar is responsible for keeping your axle centered from side to side.
    Pretty old school setup and very simple.
    Edit: Forgot to ask if you have still have stock links. Some links are offset so installation error could be a cause as well.
