Rear Hatch Problem
Discussion in '4th Gen 4Runners (2003-2009)' started by lrmills12, Apr 8, 2024.
  1. Apr 8, 2024 at 5:35 PM
    lrmills12
    lrmills12 [OP] New Member
    Silver 2008
    I have a 2008 4Runner with a rear hatch that wont open. I've read through a lot of the other threads on common issues with the rear hatch, actuator, and switch and this one seems different.
    If I reset the ECU and locks (unplug battery, plug battery back in, toggle door locks 3x), the door will open normally. However, once the door closes, the actuator runs once to seal the door, then after about 10-15 seconds, the actuator runs again. After the actuator runs the second time, the door becomes unresponsive and wont open until I perform the ECU/lock cycling again.
    If I open the door before the second time the actuator runs, the door opens normally. I can do this as many times as I like, but once the actuator runs the second time, the door is effectively dead.
    Just cycling the battery does not restore door functionality. I have to toggle the door locks as well.
    Has anybody else come across an issue like this before? I have a replacement actuator motor and door switch I was going to install, but I suspect the issue may be related to the ECU for the rear door.
  2. Apr 10, 2024 at 4:54 AM
    Ralph Blake
    Ralph Blake New Member
    2008 sr5 4runner
    Do a Googal search for 2008 4 gen rear hatch problems you will get many results.
    The Toyota rear hatch on the 2008 4runner is a very poor designed item, and has caused many problems for a lot of owners.
    Review the search results and i hope they will give you the needed info for a fix of problem.
  3. Apr 10, 2024 at 1:50 PM
    Bluesky 07
    Bluesky 07 Not a New Member
    Russell
    Northern Georgia
    How old is your battery? A weak battery can cause all kinds of oddball symptoms.
    Ralph Blake likes this.
  4. May 6, 2024 at 3:24 PM
    Muggsy71
    Muggsy71 New Member
    Tom
    2003 4runner
    Dod you get your problem with the latch figured out?
  5. May 6, 2024 at 4:33 PM
    4R777
    4R777 New Member
    Double check the exterior button cover. The original rubber cover had a problem with melting in high temperature environments. It turns into a thick heavy goo / tar-like substance and can cause the button to stick, which can cause problems.
    Also check your battery and make sure it's not weak.
  6. May 14, 2024 at 1:43 PM
    Ralph Blake
    2008 sr5 4runner
    I covered that latch mess with a thin piece of rubber then covered it with thick heating and AC foil, the gooy black holds the rubber in place the foil sticks to the rubber it flexs so you can unlock the hatch works in winter cold and summer hot and no mess on your fingers.
  7. May 14, 2024 at 1:54 PM
    4R777
    4R777 New Member
    I replaced mine with after market. Works like a champ. No more melting.
    https://www.amazon.com/s?k=Trunk+And+Liftgate+Latch+Rubber+Cover+For+4RUNNER+03-16&crid=17OOYS1FSQIT1&sprefix=rubber+latch+4runner+4th+gen%2Caps%2C314&ref=nb_sb_noss
    https://www.amazon.com/dp/B0CZLBRR65/
  8. May 14, 2024 at 2:06 PM
    Ralph Blake
    2008 sr5 4runner
  9. May 14, 2024 at 2:16 PM
    4R777
    4R777 New Member
  10. May 21, 2024 at 5:52 PM
    J.A.
    J.A. New Member
    NY
    2007 4Runner Sport 4WD V-8
    www.top4runners.com
    https://www.top4runners.com/ja/2007/interiorhatchrelease.html
  11. May 22, 2024 at 5:56 AM
    Ralph Blake
    2008 sr5 4runner
    If i have to ever go through all that to get my hatch opened, i am getting rid of my 4runner.
    Have never liked the way it worked that stupid motor pulling into locking a major unneeded item Toyota Engineers.
