Rear Factory Locker Help
Discussion in '3rd Gen 4Runners (1996-2002)' started by Swimnbud, Jun 10, 2025.
  1. Jun 10, 2025 at 10:17 AM
    Swimnbud
    Swimnbud [OP] New Member
    Kirk
    3rd Supercharger
    I just purchased a 96 limited with the original dealer installed supercharger and rear locker (not manual, so close to a unicorn, but not quite.) I already have a 98 limited with a rear locker. The locker won't fully engage on the 96. I can hear the solenoid clicking, but the light won't stop flashing regardless of movement, neutral, reverse, etc. Everything looks ok with the wiring (mathes my 98), with exception of a tube that has been cut that exits the e locker near the wiring and terminates at a clip on the body underside. Can anyone tell me what that tube is and if having it cut could be part of the problem?
  2. Jun 10, 2025 at 10:23 AM
    Welcome to the forum from Wisconsin!
    The tube could be a breather. If it's clogged, it could cause an issue.
    They can be finicky, especially if not exercised regularly.
    You are in 4lo when trying to engage the locker, correct?
    Toy4X4 and Swimnbud[OP] like this.
  3. Jun 10, 2025 at 10:25 AM
    Swimnbud
    Kirk
    3rd Supercharger
    Thank you, yes, in 4 low. With the ignition on and the engine off I can hear the solenoid trying to engage.
  4. Jun 10, 2025 at 2:05 PM
    Swimnbud[OP] likes this.
  5. Jun 10, 2025 at 2:07 PM
    "Back and Forth"? It gets easier.
  6. Jun 10, 2025 at 2:08 PM
    I think 10 mph is max locked in?
  7. Jun 10, 2025 at 2:21 PM
    I did 15-20mph with my rear locked on a gravel road
    Manual says not go above 5mph.. but I did Oops eeeee
  8. Jun 10, 2025 at 2:33 PM
    Just locked my in. Took going back and forth like five times and I turned the wheel a bit. Thats cold so then it goes in and out quick.
  9. Jun 10, 2025 at 3:37 PM
    Swimnbud
    Kirk
    3rd Supercharger
    I’ve driven more than 5 miles trying to get into Walkine on gravel. I also put it up on a four post lift and tried for about 20 minutes going forward and back and shifting it. It’s definitely not going in, or perhaps it is going in, but the indicator light is not ceasing to flash. I haven’t tested to see if it’s actually locked yet. Does anybody have any idea what the tube is that comes out of the solenoid housing
  10. Jun 10, 2025 at 4:59 PM
    It's probably a breather, as mentioned above.
  11. Jun 10, 2025 at 5:12 PM
    Swimnbud
    Kirk
    3rd Supercharger
    Thank you. I spoke to they local dealership and they confirmed that it’s a breather.
    Shredder and Thatbassguy like this.
  12. Jun 11, 2025 at 4:39 AM
    Another Wisconsin welcome! Stubborn system...
    Swimnbud[OP] and Thatbassguy like this.
  13. Jun 12, 2025 at 11:30 AM
    Swimnbud
    Kirk
    3rd Supercharger
    I spoke to a machine shop that deals with these axels who told me that it was probably a bent fork. Rather than open it, I changed the fluid and am going to drive it for a few days and see if maybe it's just sludged up from being parked for so long
    roboturner likes this.
