Rear End Noise
Discussion in '5th Gen 4Runners (2010-2024)' started by Imdav2u, Jan 5, 2025.
  1. Jan 5, 2025 at 10:17 AM
    Imdav2u
    Imdav2u [OP] Living and dying in three quarter time.
    23 TRD PRO
    I have a 23 Pro with around 12k miles. With the cold weather we have been having, I noticed strange noises coming from the rear of the truck when I back out of my driveway. After I drive it for a bit it no longer makes noise. The truck only gets driven once every week or so. Is this normal for Fox shocks?
  2. Jan 5, 2025 at 10:41 AM
    catbrown357
    catbrown357 New Member
    Tempe
    2011 Limited 4WD
    You're going to have to define the noises a little more. Squeaking? Grinding? Thumping? How about a video? Is is still under warranty?
    TrailSpecial22, Toy4X4 and icebear like this.
  3. Jan 5, 2025 at 10:44 AM
    Imdav2u
    23 TRD PRO
    A low squeak, not too loud. It is under warranty for the 36 month until November. Would the shocks be covered under the 5 year/60k warranty?
  4. Jan 5, 2025 at 10:57 AM
    Lc200
    Lc200 New Member
    Pre Facelift SR5P
    Probably your rear driveshaft. It's a noisy ol thing. A known issues with the 4runners.
  5. Jan 5, 2025 at 11:18 AM
    Imdav2u
    23 TRD PRO
    It sounds more like a shock issue than a u-joint.
    Toy4X4 likes this.
  6. Jan 5, 2025 at 11:40 AM
    garoto
    garoto New Member
    I had something similar and it would up being the trunk latch. Closing it on a microfiber towel completely resolved the issue for me. I sprayed some silicone grease and that worked out. It was a pain to find because it really sounded like the struts were doing it.
  7. Jan 5, 2025 at 1:27 PM
    catbrown357
    Tempe
    2011 Limited 4WD
    Likely not. They're usually considered a wear item. Wouldn't hurt to ask though.
  8. Jan 5, 2025 at 7:11 PM
    Taylor21554
    Taylor21554 New Member
    Naples Florida
    24 SR5 4x4
    Spray some silicone on your rubber bushings
    Toy4X4, icebear and Imdav2u[OP] like this.
  9. Jan 8, 2025 at 3:53 PM
    Constant squeal?
    Cyclical squeak?
    Is it associated with suspension movement or body movement?
    Could be brake squealers tabs, or suspension, or driveshaft.
  10. Jan 8, 2025 at 5:35 PM
    Imdav2u
    23 TRD PRO
    It happened when I backed out of my driveway where it meets the street. I tried Taylor's advice, it seemed to work. It was 18° when I drove it this evening, no noise.
    Taylor21554 likes this.
  11. Jan 9, 2025 at 4:43 AM
    Bushings love silicone lubricants, especially poly bushings. You'll notice temporary relief when you spray your shock bushings, if it persists, maybe you could replace shock bushings with poly bushings?
  12. Jan 12, 2025 at 10:37 AM
    Taylor21554
    Naples Florida
    24 SR5 4x4
    Yeah I recently went out on a trail, got some sand and mud on some suspension parts, took to a diy car wash to get all the dirt out. That’s when I got my squeaking. Pushed up and down on the back bumper, and sprayed silicone on every bushing I could find, and noise went away. Sometimes it’s just the simple things.
    Dislodging all that dirt, or even putting the truck on a lift to relief some of the weight off the suspension will do that too, so some silicone spray always worked for me. Glad it helped.
    Toy4X4 likes this.
  13. Jan 12, 2025 at 11:16 AM
    That’s good. Another thing that occured to me is that since your 4runner is new, it could be the “normal” brake squeal in reverse. Usually happens with light brake pressure when slowly backing out.
    I’m still not super clear on the description of what you’re hearing. However, regarding bushings, keep in mind that the rubber ones on the 4runner really shouldn’t make any noise unless torn.
    These bushing are rubber that is vulcanized between an outer steel shell, and an inner thick steel tube, through which a bolt goes through. A bolt that is properly torqued through one of these bushings will not allow the inner steel tube to rotate relative to the steel that it’s clamped to. The steel tube is clamped by the pressure of a tightened bolt, meaning that the only movement is flex in the rubber. Flexing rubber doesn’t make noise…unless maybe it’s torn.
    However, a loose bolt passing through a bushing could result in noise if the steel tube rotates relative to the steel that’s sandwiching it. So unless you’ve done suspension work and left something loose, it’s doubtful you have noise coming from any of the rubber bushings on a stock 4runner.
    Especially one so new.
    I have had squeaking noise from the rear suspension on one occassion. It was my fault, because I sprayed wool wax on the lower coil seats. This must have allowed a tiny bit of movement between the coil and the metal seat as the suspension flexed. It went away after I soaked the coil seat with brake clean a few times.
  14. Jan 12, 2025 at 7:07 PM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    Before you drive it. Grab a hold of the roof rack and rock the truck side to side as hard as you can. You'll be able to tell if you have a noisy shock.
    McSpazatron and Toy4X4 like this.
  15. Jan 13, 2025 at 4:45 AM
    Grandpawmoses
    Grandpawmoses Dirty Old Man
    David
    2024 4R TRD Pro
    Too poor to buy anything now
    Mine does it when it's cold. It's more of a "bump-bump" sound though. I blame it on tire flat spots from sitting overnight.
  16. Jan 13, 2025 at 7:23 AM
    Imdav2u
    23 TRD PRO
    It doesn't do it if it's warm outside or if it gets driven more often.
