Rear emblem and 4runner overlay
Discussion in 'General 4Runner Talk' started by Danjou, Sep 6, 2023.
  1. Sep 6, 2023 at 8:08 PM
    Danjou
    Danjou [OP] New Member
    Howdy, new guy here. I looked if there were other posts on this topic (must be) but couldn't find them. Looking to cover the rear chrome emblem and the 4 runner sign, got a 2023 PRO. Went to dealership, they do not sell the rear emblem and the 4runner overlay on their own, they sell the whole overlay kit and they want $220 for it; I'm sure the quality is there but the price is a no-go. I found the rear emblem and the 4runner sign for $30 on Yota Xpedition site.
    Anyone purchase these and if you did, are you happy with the quality?
  2. Sep 6, 2023 at 9:19 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    Hey OP @Danjou
    Welcome here! You're in the right place, great website.
    I'll have surfed them on the web, but not purchased from Yota Xpedition. I'll let other members speak to their overlay quality.
    As for me, I've actually been really satisfied with Amazon emblem overlays. I bought a set with good reviews at around $30CAD ea. and bought a second as a backup in case 3M fails on any letters n such. But the first set is still holding and looking perfect, after a year and a half up here in Canada.
    Goodluck
    https://www.amazon.ca/gp/aw/d/B08L7BYS52?ref=ppx_pop_mob_b_asin_image
  3. Sep 7, 2023 at 1:45 AM
    Danjou
    Thanks djwantke, was surfing youtube and found a good vid on Yota's inlays. Looks like their product will work just fine. Thanks for jumping in, I checked your link and they are out of stock but I appreciate the fast answer. Have a great day!
    djwantke likes this.
  4. Sep 7, 2023 at 2:08 AM
    Welcome. Like above you can get overlays on Amazon. You can wrap or plastidip then also. Just depends on the work you want to put in.
  5. Sep 7, 2023 at 6:51 AM
    FN2187
    FN2187 Stormtrooper
    Earth
    2019 TRD ORP w/ KDSS
    You can also check ebay. I'm pretty sure I got my red overlays from there because Amazon only had black at the time.
  6. Sep 7, 2023 at 7:11 AM
    steelevo
    Utah
  7. Sep 7, 2023 at 7:29 AM
    Awesome good on you happy to help. I also saw my link was out of stock but that's Amazon.ca and I figured you're in the United States. Plus Amazon has many other options then my link. Highly recommend eBay for a lot of these things too, you'll save money
  8. Sep 9, 2023 at 11:39 PM
    LuLu
    LuLu New Member
    Utopia
    2022 TRD Sport
    +1 on the Yota Expedition emblem overlays and third smoked brake lights.
    Prep matters. Installation on a hot day after emblems warmed up.
    Prep area with mild alcohol.
  9. Sep 9, 2023 at 11:46 PM
    Captain Sensible
    Captain Sensible New Member
    Anybody know a carbon fiber overlay? '23 ORP
  10. Sep 10, 2023 at 2:49 AM
    2016SR5P
    2016SR5P New Member
    Massachusetts
    2016 SR5P 4WD
