Rear Door Open Light Stays on and rear window will not go down
Discussion in '2nd Gen 4Runners (1990-1995)' started by brock1211, Jul 31, 2024.
  1. Jul 31, 2024 at 7:46 AM
    brock1211
    brock1211 [OP] New Member
    Dallas
    1991 4runner
    The rear door open light on my 91 4runner stays on all the time. I also can't get the rear window to roll down. I'm thinking the rear door open light is telling the rear window to not work. Any ideas?
  2. Jul 31, 2024 at 9:50 AM
    trlhiker
    trlhiker Lazy Bum
    1992 4Runner SR5 V6 4X4
    pull off the rear panel and test the motor to see if that still works? Also check and see if the wiper is in it's proper place.
  3. Aug 7, 2024 at 5:44 PM
    SilentPursuit
    SilentPursuit New Member
    1995 4Runner 3.4 swapped 5 speed
    You can do the rear wiper bypass trick, a quick google will pull up a reference as to which wire to jump. It’s very easy and you will pull the plastic where the rear light is so you can inspect it.
  4. Aug 8, 2024 at 10:08 AM
    trlhiker
    trlhiker Lazy Bum
    Also, door has to be locked for window to go down
  5. Aug 8, 2024 at 10:50 AM
    Acesandeights
    Acesandeights #34
    2024 ORP
    Have you confirmed the rear door isn't open?
  6. Aug 20, 2024 at 8:02 PM
    Renegade15
    Renegade15 New Member
