Rear door jammed shut.
Discussion in '3rd Gen 4Runners (1996-2002)' started by SirSteveUK, Aug 5, 2019.
  1. Aug 5, 2019 at 9:04 AM
    SirSteveUK
    SirSteveUK [OP] New Member
    Steve
    98 Grey 4Runner
    Hi folks
    Have recently resurrected our 97 4-cyl 4runner after about 5 years of non-use.
    Rear door worked fine for a while then stopped working.
    The lock fitting had fallen into the mechanism compartment some time ago - but the door still worked.
    I think that the lock may have shifted and now be blocking the opening mechanism. The pull handle works fine - and springs back correctly.
    I have read that the plastic cover that I need to remove is held by one screw and plastic clips. ( on a later model, mind)
    Trouble is I can't find the screw anywhere. Can someone tell me where it is ? It doesn't appear to be behind the tag plate.
    Thanks
    Steve
