Rear hatch/cargo door interior latch handle?
Discussion in 'General 4Runner Talk' started by Theol Mann, Feb 26, 2025.
  1. Feb 26, 2025 at 7:34 PM
    Theol Mann
    Theol Mann [OP] New Member
    Theol
    2017 Midnight Blue
    Keeping it stock.
    I recently bought my 1st 4R, a 2017 rear wheel drive. While still getting to know this truck I discovered there is no convenient way to open the rear door from the inside. Is this true with later model year 4R's or am I just lucky? :oldglory:
  2. Feb 26, 2025 at 8:10 PM
    I don't quite follow, it's just a normal handle in the back?
  3. Feb 26, 2025 at 8:15 PM
    Beachguy
    2024 TRP ORP
    Maybe the child safety lock is flipped?
  4. Feb 26, 2025 at 8:28 PM
    Theol Mann
    Theol
    2017 Midnight Blue
    Keeping it stock.
    Oops! I misspoke. I was referring to the very back door at the rear of the 4R. The hatch? The overhead door? Cargo door?
  5. Feb 26, 2025 at 9:34 PM
    Startrek
    Startrek New Member
    you have to pop square lid on door panel, stick hand inside, find something to hold on and pull. Very useful if you find yourself trapped in a cargo compartment.
  6. Feb 27, 2025 at 3:19 AM
    J.A.
    J.A. New Member
    NY
    2007 4Runner Sport 4WD V-8
    www.top4runners.com
    Bluesky 07 and 4onto like this.
  7. Feb 27, 2025 at 4:02 AM
    MeefZah
    MeefZah ------------
    Lexington, Ohio
    2020 GX460
    TLCA #25089
    None of the 5th generations have that feature. You have to build it yourself which involves jumping a wire from the rear hatch door ECU to ground through a switch. I was not able to look at the above listed link on my phone but it's probably substantially similar. If you do a search on this forum for the thread title "Ultimate camping mod", you'll bring up a vendor that sells a kit that allows you to build a release button.
  8. Mar 3, 2025 at 9:31 AM
    4onto
    4onto New Member
    Toronto
    2009 SR5 V6 4WD
    Clean installation. As well, it's good to know the exterior release switch rubber degrades on its own. I thought it might be the yearly rustproofing since new that caused it.
    J.A.[QUOTED] likes this.
  9. Mar 5, 2025 at 6:01 PM
    Hungryhawk
    Hungryhawk New Member
    Southern CA
    2017 SR5
    I found a post for a mechanical release which appeals to me. Try searching this site and the "other" site for detailed "how to".
    I saved a couple pics. Basically you take interior panel off tail hatch and gain access to white plastic latch mechanism. Pop off a small cover. Attach a strong thin cord inside to the metal arm to pull and trip the mechanism. Drill a hole in the little cover for the cord. I am still thinking about a clean way to terminate the pull cord-got about half the idea figured.
