Rear Coils?
Discussion in 'Suspension' started by ToyMan, May 3, 2017.
  1. May 3, 2017 at 2:29 PM
    ToyMan
    ToyMan [OP] New Member
    Frank
    1995 4runner limited
    Has anyone found a rear coil that lifts up the ass end off this thing without buying a spacer or going with a coil with a expensive lift kit ? Like maybe FJ coils or something from a newer truck maybe ? Not to worried about it being stiff I got a tool box in the back ! But just would like to lift up the ass maybe 2" if possible without buying expensive coils.
  2. May 3, 2017 at 4:11 PM
    brochacho
    brochacho New Member
    2018 Sequoia TRD Sport
    Define expensive? Maybe these?
  3. May 4, 2017 at 11:20 AM
    bahndrvr
    bahndrvr New Member
    Trevor
    Melbourne, Fl
    03 SR5 V8 4Runner
    2003 4Runner SR5 v8 - Temp Front: Top hat spacer 2.5" on Tacoma struts/springs Rear: TJM/King heavy extended Tacoma shocks 315 BFG AT KO2's (35's) Thrush Welded muffler and rear watermelon delete with turned exit K&N drop in, and extra filter delete Strengthened/Welded passenger side front diff mount Front diff drop - due to the top hat spacer and massive droop.... Scion headunit CB Other stuff done, 6th 4Runner:)
    I ran landcruiser stock takeouts in the rear of my 95, worked perfect, plenty of info for which ones you need, seems like I had the fronts, was around 2.5-3" of lift, need a panhard extension and longer brake lines and shocks to maximize the massive flex, but you coupld probably put in and enjoy if you don't flex it much, I wheeled the hell out of mine!
  4. May 4, 2017 at 3:25 PM
    ToyMan
    Frank
    Thanks a lot buddy ! What year was the land cruiser coils you used ?
  5. May 4, 2017 at 4:29 PM
    bahndrvr
    bahndrvr New Member
    Trevor
    Melbourne, Fl
    03 SR5 V8 4Runner
    I think this will have some good info for you! Actually I seeeched for 3rd gen forgetting you were a second gen but info is all here just do a search for 2nd gen cruiser coils and info will be there! FYI if you want a title more out of the front go with bj spacers and longer shocks!
  6. May 4, 2017 at 4:30 PM
    bahndrvr
    bahndrvr New Member
    Trevor
    Melbourne, Fl
    03 SR5 V8 4Runner
