Rear Coil Options
Discussion in '3rd Gen 4Runners (1996-2002)' started by kkvf24, Jul 18, 2022.
  1. Jul 18, 2022 at 11:35 AM
    kkvf24
    kkvf24 [OP] New Member
    Kurt
    2001 4runner SR%
    Hey All -
    I replaced my front struts/coils with Detroit Axle and rear struts as well. Currently my rear is still saggy - about 1" less than front. Front - ground to fender is sitting at about 34.75". Rear is about 33.5". Should I want the rear up to the same height - should I replace with the 99' tall rear coil springs or with 2001 coil springs - I'm going OEM springs, not looking to lift - just want it even. I guess I was hoping replacing the coils would give it that extra lift in the back but I don't know which ones to get.
    My tires are 30" on 15" stock wheels.
    What are your thoughts?
  2. Jul 18, 2022 at 12:55 PM
    So 15 inch wheels will clear a third gen’s brakes?
    The steel rims?
  3. Jul 18, 2022 at 12:56 PM
    kkvf24
    Kurt
    2001 4runner SR%
    These are stock 15”wheels with 30” tires on them. Alloy not steel and clear just fine.
    SR5 Limited likes this.
  4. Jul 18, 2022 at 12:56 PM
    They have those pucks to raise the rear little?
  5. Jul 18, 2022 at 1:01 PM
    kkvf24
    Kurt
    2001 4runner SR%
    Not sure what you mean. My rear is sagging and Im going to replace springs now as the struts alone didn’t help. Im trying to figure out if the 99 springs would be better or just go with the OEM height for 2001 year.
  6. Jul 18, 2022 at 1:24 PM
    kmeeg LionRunner
    I have these in CO which I would like to sell with local pickup. Looks like they fit 2003 and up 4Runners and you may be not local to CO. May not fit your 2001 I guess.
  7. Jul 18, 2022 at 9:45 PM
    Kwikvette
    Kwikvette Kwik Fab
    Multiple
    4Runners do not use struts, neither front or back.
    They also have nothing to do with supporting weight; coils do that.
    If you're carrying some extra weight, go for '99 coils otherwise go for OEM coils for your model year.
    Easy stuff.
  8. Jul 19, 2022 at 7:00 AM
    kkvf24
    Kurt
    2001 4runner SR%
    gotcha - thanks! I said struts - I meant shocks. I will replace with the OEM rears - thanks!
    Kwikvette[QUOTED] likes this.
