Rear clank noise when under load, especially on hill.
Discussion in '4th Gen 4Runners (2003-2009)' started by Ewert_10, Mar 19, 2024.
  1. Mar 19, 2024 at 1:05 PM
    Ewert_10
    Ewert_10 [OP] New Member
    Luke Ewert
    04 4Runner v6 4wd
    3'' Lift, spacers
    Hi, curious if yall could help me out? A couple months back I bought an 04 4runner v6 4wd sport. Once i a while the there is a clank/pop sound in the back under the car. Almost a medal sound. This usually occurs when I am taking off from a hill or under load. It happens randomly and usually only once in each drive. Not super concerning but definitely want to narrow it down. Let me know. Thanks!
  2. Mar 19, 2024 at 1:13 PM
    Two4Runner
    Two4Runner New Member
    Lance
    4Runner
    Does it sometimes happen when you come to a stop? Or when you take off from a stop? If so you may need to grease your slip joint on the drive shaft. It can feel like someone slightly bumped you from behind
  3. Mar 19, 2024 at 1:27 PM
    Ewert_10
    Luke Ewert
    04 4Runner v6 4wd
    3'' Lift, spacers
    No, it happens when I take off. Just loud and definitely not normal. For instance I reversed up a slight hill the other day, hit a small bump, and then the clank happened.
  4. Mar 19, 2024 at 1:29 PM
    Two4Runner
    Lance
    4Runner
    Sounds like a different problem than the drive shaft clunk. Sorry I'm no help
  5. Mar 19, 2024 at 2:03 PM
    Ripper238
    Ripper238 New Member
    2019 TRD OR
    Something is loose. Maybe exhaust?
    I had an old car that the rear diff would clank. But this sounds different.
  6. Mar 20, 2024 at 8:06 PM
    BassAckwards
    BassAckwards New Member
    2006 4Runner V6 SR5 2wd
    Might be the brake pads, they tend to make a bit of a clanking noise sometimes. Mine always does it when backing out of the driveway. Does it on my Tacoma too, same brake design up front
