Rear calipers smaller?
Discussion in '5th Gen 4Runners (2010-2024)' started by Try Harder, May 10, 2024.
  1. May 10, 2024 at 3:55 PM
    Try Harder
    Try Harder [OP] New Member
    Steve
    15 4runner limited
    None yet.... emphasis on yet
    Reason I ask is, I had to add 1" spacers to eliminate a minor rub up front on my new 17's. I'm wondering if the rear calipers are smaller and the spacer unneeded. The rear hangs out more than Id like, Save me some aggravation please, what should have been routine turned into a dumpster fire. These tires are getting heavy on and off... certainly someone here has addressed this. Thanks
  2. May 10, 2024 at 4:02 PM
    I'm curious what rims you got that a spacer helped clear the caliper.
  3. May 10, 2024 at 4:09 PM
    nova
    nova New Member
    mike
    Prescott Valley - Arizona
    Grenadier Trialmaster
    Rock Sliders, Bull Bar
    Spacers would cause rubbing, not fix it. Where were you rubbing prior to the spacers?
    To your question, stock wheels won’t rub the calipers front or back.
  4. May 10, 2024 at 4:34 PM
    Try Harder
    Steve
    15 4runner limited
    I think you misunderstood, the back of the wheel SLIGHTLY rubs the caliper. It was necessary to add the spacer. I already chewed out Custom Offsets. IMG_1557.jpg
  5. May 10, 2024 at 5:06 PM
    Agent_Outside
    Built 2011 T4R Limited
    If it’s rubbing on the caliper I’m assuming it’s at the back of the spokes? If so spacing the front will help and shouldn’t be necessary on the rear. Rear brakes are always smaller.
    But having a mismatched track width isn’t ideal. I’d space them the same. Actually that’s not true, I’d get wheels that fit properly and not use spacers, but you know what I mean.
    Toy4X4, steelevo and Try Harder[OP] like this.
  6. May 10, 2024 at 5:17 PM
    Try Harder
    Steve
    15 4runner limited
    Thank you, that's what I was hoping to hear. I will remove them from the rear in the morning.
  7. May 10, 2024 at 6:33 PM
    So wait, you have spacers on the front and rear?
    But now, you said you’re going to remove them (spacers) from the rear.
    If you space the front, space the rear.
    You want tracking to be the same.
    Harringbr99 and catbrown357 like this.
  8. May 10, 2024 at 6:47 PM
    catbrown357
    catbrown357 New Member
    Tempe
    2011 Limited 4WD
    Especially with a Limited and full time 4WD. I think you're asking for all kinds of issues with TC, ABS, etc.
    Harringbr99 likes this.
  9. May 10, 2024 at 7:11 PM
    joshdub
    joshdub New Member
    2020 TRD ORP
    You can run spacers on the front and not on the back. It's possible the rear calipers clear better than the larger fronts.
    The people here wigging out about track differences must not understand what happens to track width when you life a IFS truck
    Try Harder[OP] and Toy4X4 like this.
  10. May 10, 2024 at 9:54 PM
    Never saw that it was lifted…..must have overlooked that while I was wigging! ;)
    raimieb likes this.
  11. May 10, 2024 at 10:19 PM
    I believe Toyota Troopers have a different track by design so it’s not the end of the world. But I agree with others, much easier to buy rims that are designed for your truck.
    Toy4X4 and Saker like this.
  12. May 11, 2024 at 4:10 AM
    You should probably get the proper rims for fitment. If you were into truck-pulling the different track width would be great, but...
  13. May 11, 2024 at 11:40 AM
    I’m assuming the sellers told the OP they won’t accept them back. Because otherwise, I’d for sure get rid of the wheels. Spacers are an unnecessary inconvenience when you already put money into wheels.
    Toy4X4[QUOTED] and Slopemaster like this.
  14. May 12, 2024 at 4:51 AM
    Would you take the wheels back? Especially after they rubbed on the calipers. Expensive lesson learned? I have made mistakes similar to this and tried to 'fix' it. I feel your pain (OP), maybe you can get rid of the wheels to someone with the same bolt pattern, different application. I hope this works out for you somehow.
  15. May 15, 2024 at 4:00 PM
    Try Harder
    Steve
    15 4runner limited
    I had done my research before making this decision.. spoke with the proper people. Thanks for everyone's help through this. The Falken 275/70/r17 are coming off Monday , slight rub on full turn and I took it on a long ride on the highway. Too noisy for me. Continental 265/70/17 All season going on...
