Rear Brake Pads and rotors upgrade!
Discussion in '5th Gen 4Runners (2010-2024)' started by Lc200, Dec 18, 2023.
  1. Dec 18, 2023 at 10:45 AM
    Lc200
    Lc200 [OP] New Member
    Pre Facelift SR5P
    Hey folks,
    Time to get new rear pads and rotors. Anyone has any experience using other brands other than OEMs. Better bite, less noise, good life etc etc etc.
    I have heard Akebono ProAct pads are better. And also Centric rotors?!
    I would need part numbers please, it's a maze out there.
    Cheers.
  2. Dec 18, 2023 at 11:13 AM
    Hard to top OEM.
    Tama1968, Old goat, CIDD and 4 others like this.
  3. Dec 18, 2023 at 11:14 AM
    Rocko9999
    Rocko9999 New Member
    2011 Limited
    OEM rotors. Aftermarket rotors in the last few years have a high chance of being out of round from the factory. Akebono makes good pads. If you go aftermarket, they are the only pads I would use. It's a heavy rig-don't expect much improvement.
    Lc200[OP] likes this.
  4. Dec 18, 2023 at 11:25 AM
    jasonmcelroy
    Jason
    San Jose, CA
    2021 Grey Trail
    I just did rear brakes last weekend and used oem parts.
    Pads are stamped "Akebono" on them.
    Whole order was under $300. Quality of materials and fit was evident.
    JS222STL and Lc200[OP] like this.
  5. Dec 18, 2023 at 11:53 AM
    Lc200
    Pre Facelift SR5P
    Got it. I was inclined to go with OEMs but was wondering if there were other brands like EBC, Galfers etc that make pads for the 4R that have been tried.
    I am also looking to change the emergency brake pads. Anyone done these?
    @jasonmcelroy- How long did it take you to do the rears?
  6. Dec 18, 2023 at 2:11 PM
    jasonmcelroy
    Jason
    San Jose, CA
    2021 Grey Trail
    Maybe an hour? Was doing the oil and driveshafts at the same time. Very simple job.
    Jason
    Lc200[QUOTED][OP] likes this.
  7. Dec 18, 2023 at 2:32 PM
    Daddykool
    How many miles on your current ones, and are they OEM? I replaced the originals on my 2019 at 92k miles (rear) and 115k miles (front). That's a great argument for not looking into other brands. I used OEM. Did not replace any rotors, as they looked to be in fine shape and didn't need replacing.
    JS222STL likes this.
  8. Dec 18, 2023 at 4:57 PM
    Lc200
    Pre Facelift SR5P
    I am going to go ahead and order an OEM set of pads and rotors. Just need to decide where. Online after shipping is only a couple of tenners cheaper than local dealer.
    Mine started squeaking at slow speeds some days ago.
  9. Dec 18, 2023 at 5:10 PM
    Advics (OEM Toyota brake system supplier) makes "best" pads for the aftermarket, but I don't see them offering ceramic pads for the rear, so I went for Bosch earlier this year:
    Raybestos 980780PER slotted rotor
    Bosch BC606 ceramic pads
  10. Dec 18, 2023 at 6:07 PM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    I also used these bc606 pads.
    3JOH22A[QUOTED] likes this.
  11. Dec 18, 2023 at 6:59 PM
    Lc200
    Pre Facelift SR5P
    How is the noise/squeak and life on them?
  12. Dec 18, 2023 at 7:15 PM
    ^So far, so good. No dust. No noise.
    I had good experience with the Raybestos PER-series slotted rotors on my father's Subaru (which previously chewed through StopTech rotors after 25k).
  13. Dec 18, 2023 at 8:34 PM
    nova
    nova New Member
    mike
    Prescott Valley - Arizona
    slightly modified LE
    If I were to install something besides OE breaks, it would be Powerbreaks. Since those are over $2500, it’s OE for me!
  14. Dec 19, 2023 at 9:18 AM
    TRDSD
    2019 TRD Off Road Premium
    I went with StopTech slotted rotors front and rear + NRS Premium galvanized-backed hybrid pads (made in Canada). Very happy with them. Pretty much zero dust, no noise and stop on a dime.
  15. Dec 23, 2023 at 1:06 PM
    MAXIM
    MAXIM New Member
    OEM rotors are awesome, inexpensive and Made in Japan. TRD brake pads, if you don't mind brake dust - you will thank me later for recommending them. Superb initial bite.
    -and-lt;-and-lt;-and-lt;-and-lt;-albums-_722a44be5d03b59132c9adafb591a70b7ccce40a.jpg
  16. Dec 23, 2023 at 5:17 PM
    I think OEM is a good solid choice. I revamped mine last year with the Bigbrake kit or whatever is called, by powerbrake. I can tell a little bit of a difference but not so much. I never did a good benchmark on before and after, but I think they are a bit better than OEM. Issue is, these things were expensive....:( Nothing new there.
  17. Dec 23, 2023 at 7:22 PM
    nova
    nova New Member
    mike
    I think the advantage Powerbreak brings is the ability to dissipate heat and provide reliable breaking in extreme applications. So if you’re heavy and running 35+” tries, it could be worth the bucks. But I’m still waiting to hear back from some of the early adopters.
    Ironguy and ChessGuy like this.
  18. Dec 24, 2023 at 5:08 AM
    raimieb
    raimie
    2021 ORP 4x4
    Lots…
    Maxim, are those stock calipers with the logo on them or did you add that? Looks neat!
  19. Dec 24, 2023 at 6:21 AM
    Topic is rear brakes, which do ~20% of the braking unless you're in 4WD. Does this vendor even offer a rear big brake kit? Does it require 18" wheels?
    2ndGen22re likes this.
  20. Dec 24, 2023 at 7:08 AM
    nova
    nova New Member
    mike
    For the rear, Powerbreak has the D-Series
    raimieb likes this.
  21. Dec 24, 2023 at 8:55 AM
    rickystl
    rickystl New Member
    Rick
    St. Louis, MO
    2021 TRD/Off-Road Premium
    Interesting. It "seems" on the 4R that the rear brake pads tend to wear just slightly sooner than the fronts. My 2010 FJ Cruiser (essentially the same mechanics) did the same thing. But close enough where I replaced all four at the same time. The later ceramic brake pads appear to last a long time. And so nice not to have to deal with the old, black brake dust.
  22. Dec 25, 2023 at 10:24 PM
    Snake River
    Snake River New Member
    2022 Army Green 4Runner Off-Road Premium
    A friend who is a service manager at a local Toyota dealer strongly suggests OEM brakes on my 4Runner. They are an excellent combination with the 4Runner weight, use, and design. When the time comes, that’s what I’ll use.
  23. Dec 26, 2023 at 4:14 AM
    Nmscuba
    Nmscuba New Member
    Anthony
    2020 4 runner
    None
    I would agree. Toyota designed this vehicle knowing the weight and towing capacity so I would certainly think they designed the brakes to handle it all. If not it would be one heck of a lawsuit and injuries. Aftermarket isnt always better its just another company making money and SOMETIMES improving a product
  24. Dec 26, 2023 at 11:52 AM
    MAXIM
    MAXIM New Member
    Just a door handle Sticker on stock caliper. Did it for kicks. Amazing it held up for years now.
    raimieb[QUOTED] likes this.
  25. Dec 26, 2023 at 12:14 PM
    mcat707
    mcat707 MURDERED TRD
    NOR*CAL - Solano County
    2015 TRDPro - Attitude Black Metallic 218
  26. Dec 26, 2023 at 3:22 PM
    raimieb
    raimie
    2021 ORP 4x4
    Lots…
    Totally amazing it held up this long. Well done.
  27. Dec 27, 2023 at 2:02 AM
    Matt83
    Matt83 New Member
    Northeast
    Try Lewis Toyota in Kansas for free shipping.
