RCI Skid Plate and Oil Change
Discussion in '5th Gen 4Runners (2010-2024)' started by afret, Jan 15, 2022.
  1. Jan 15, 2022 at 12:18 PM
    afret
    afret [OP] 2022 ORP, KDSS, Toyo AT3
    North Idaho
    Went ahead and ordered an aluminum RCI KDSS skid plate and the small filler plate today while waiting for my ORP. How messy is the oil and filter change with the RCI plate in place? The removable door for the filter looks pretty small so is it pretty easy to get the filter off and not spill oil on top of the plate?
  2. Jan 15, 2022 at 1:35 PM
    Tradbow
    Tradbow New Member
    Phil
    NW
    2023 MGM SR5
    I have the RCI engine skid and did my first oil change yesterday with the skid plate in place and I removed the canister without first draining the housing by removing the drain plug and it got pretty messy. The next time I will remove the small plug and attach a short piece of clear tubing. Should be fairly easy to clean any residual oil.
  3. Jan 15, 2022 at 6:31 PM
    afret
    North Idaho
    Thanks for the info. What's the oil change interval on 4Rs?
  4. Jan 15, 2022 at 7:02 PM
    polyguy79
    polyguy79 New Member
    LA County
    2021 White Runner ORP
    RCI aluminum skids (front, trans, TC, and gas), RCI steel sliders 20 degree no plates with kickout, Treaty Oak recovery points, LFD stainless crossbars, Greenlane ladder, Toyo Open Country AT III, Bilstein 5100s, OME (front 2” lift) and Eibach (rear 1”lift) coils
    Toyota says 10k….most do either 5k or 7.5k. I personally do 5k because it’s cheap and there is no harm in having clean oil constantly in your engine.
  5. Jan 15, 2022 at 7:28 PM
    JohnD
    JohnD New Member
    Find a piece of rigid tubing that just fits over the end of the little housing drain nipple provided with the filter. Notch the end of the tubing for the little lugs sticking out of the sides of the drain nipple. Make the tubing long enough that it extends well below the skid. Use that tube/nipple contraption to drain the housing into your pan. I used 1/2 EMT conduit. Clear plastic tubing would be neat and it may not get hot as quickly.
  6. Jan 15, 2022 at 8:34 PM
    afret
    North Idaho
    So the interval is like the Tacoma. Thanks and thanks for the tip about the tubing.
  7. Jan 15, 2022 at 9:10 PM
    Pavo
    Pavo New Member
    I have an rci aluminum skid plate, I just remove the entire skid plate, it's really light weight and zero mess
  8. Jan 15, 2022 at 9:24 PM
    Cowboy59
    Cowboy59 Enjoy the Adventure
    N. Florida
  9. Jan 16, 2022 at 7:18 AM
    afret
    North Idaho
    Thanks! I'll probably will end up just dropping the aluminum plate. :)
  10. Jan 24, 2022 at 6:37 PM
    spyder918
    spyder918 501st Unit: GGG
    2019 TRD ORP MGM
    Those of you who installed the RCI skid plate, were the bolts difficult to put on? I just ordered mine and wonder if I need to do this?
  11. Jan 24, 2022 at 7:28 PM
    polyguy79
    LA County
    Not at all. The hardest part is the transfer case crossbar, but even that isn’t bad. Did the whole install by myself easily
  12. Jan 24, 2022 at 8:23 PM
    Cowboy59
    N. Florida
    Mine went on without any issue. Super simple. I recommend starting the two middle bolts first. Just get them in enough to hold the plate up. Then set the two front bolts, but don't tighten all the way. Then set the two back bolts. Again don't tighten all the way. Once all six bolts are threaded, tighten the two middle bolts and then tighten the other four. I provide pictures on my build page at the link below.
    https://www.4runners.com/threads/cowboys-first-4runner-and-chronicle-of-mods-upgrades.18688/
    spyder918 likes this.
  13. Jan 24, 2022 at 8:54 PM
    I took a hard look at the RCI skid plate and that’s what concerned me, was the small size of the oil filter access hole. If you gotta pull the skid to change the filter, then what’s the point?
  14. Jan 24, 2022 at 9:29 PM
    Cowboy59
    N. Florida
    I have the RCI skid and you don't have to pull the skid to change the filter.
    21Venture and Trail Runnah like this.
  15. Jan 24, 2022 at 9:52 PM
    spyder918
    2019 TRD ORP MGM
    Thanks for sharing that!
  16. Jan 25, 2022 at 3:01 AM
    BobbyB
    Bob
    Marietta, GA
    2021 White TRD Off Road
    I installed the RCI full skid package plus gas tank skid on my 2021 OR last weekend by myself and it was a simple install. Having a floor jack to lift and position the skids and transfer tank skid cross member made the job easy for one person.
    As has been stated by others, wait until all skids are in place before you tighten all the bolts.
    Cheers,
    Bob
  17. Jan 25, 2022 at 7:24 AM
    TrailGuy2016
    TrailGuy2016 New Member
    2016 Trail Premium, Silver
    I have the RCI plates and the oil change is super easy. Access door for the filter, and the oil drops straight out through a hole in the plate behind the filter area.
    spyder918, Trail Runnah and polyguy79 like this.
  18. Jan 25, 2022 at 8:36 AM
    polyguy79
    LA County
    There is no reason to pull the skid to replace the filter. The door is plenty big. If you put these plates on and install a fumoto valve to boot, oil changes will be much quicker than with OEM plates. It’s not even close
  19. Jan 25, 2022 at 9:25 AM
    Overland WT
    Overland WT Grumpy Old Guy
    Bryan
    West Texas
    2017 TRD Off Road
    Many with many more to go
    Where did you find the Fumoto valve? Had one on my Jeep but that distributor only carries FCA, not Toyota.
  20. Jan 25, 2022 at 9:31 AM
    polyguy79
    LA County
    Toy4X4 likes this.
  21. Jan 25, 2022 at 9:43 AM
    Zeet959
    Zeet959 New Member
    Tony
    Nebraska
  22. Jan 25, 2022 at 4:45 PM
    polyguy79
    LA County
    I have both of what Zeet is showing above and those are also HIGHLY recommended! It’s an investment upfront, but saves you time and mess for years and years to come!!
  23. Feb 3, 2022 at 3:34 AM
    konstantineaquavi
    konstantineaquavi New Member
    polyguy79 likes this.
  24. Feb 3, 2022 at 9:07 AM
    spyder918
    2019 TRD ORP MGM
    How long did you guys wait for your front RCI skid plates? Currently still waiting for mine.
  25. Feb 3, 2022 at 9:12 AM
    polyguy79
    LA County
    About 2 weeks or so. Wasn’t bad at all.
  26. Feb 3, 2022 at 9:15 AM
    spyder918
    2019 TRD ORP MGM
    That's quick. I'm currently at 2 weeks and nothing yet. :rant:
  27. Feb 3, 2022 at 9:21 AM
    polyguy79
    LA County
    If it makes you feel any better: 1) that was about 3 months ago and lead times are constantly changing, and 2) it took 2 months for me to get my sliders from them. Just be patient. It’s a great company with a great product. Wait times are the norm for these types of items and RCI still has one of the shortest. You will love them once they arrive.
  28. Feb 3, 2022 at 9:27 AM
    Tradbow
    Tradbow New Member
    Phil
    NW
    2023 MGM SR5
    I ordered mine in mid April of 2021 and received it the end of May. So about a month and a half.
  29. Feb 3, 2022 at 9:52 AM
    2020 4Runner
    2020 4Runner New Member
    Fl
    It was designed so that you don't have to remove it.
  30. Feb 3, 2022 at 10:20 AM
    TrailGuy2016
    I ordered mine in May 2020, and it took 4 weeks, and THEN they sent me the wrong transmission plate. They finally made it correct after about another 4 weeks. COVID ravaged them it sounded like. Still happy with them and the product.
