RCI front skid coverage
Discussion in 'Armor' started by glwood54, Aug 5, 2021.
  1. Aug 5, 2021 at 2:57 PM
    glwood54 [OP] Stop making me buy stuff!
    Looking at the RCI front skid again, and am wondering - for those of you who have one, does it take the place of both of these?:
    I'm sure this has been answered somewhere, but thought I would ask. I've been hijacking someone else's thread looking for an answer, so I figured I better just see if anyone has an answer, thanks.
  2. Aug 5, 2021 at 3:15 PM
    travelinscout
    travelinscout New Member
    2020 TRD ORP MGM
    I have the RCI on mine, and there are separate plates to cover what is in this picture. I had the TRD Pro skid up front, so I just added the TRD Integration plate, the Transmission Skid, and the Transfer Case Skid. If you don't have the TRD plate, then to replace these two, you need the engine plate, and the transmission plate.
    I hope this helps!
  3. Aug 5, 2021 at 3:19 PM
    Sort of... I'm not really looking for the whole skid set. I am wondering what oem skids need to be removed to install the front RCI skid. It is considerably longer than the front skid shown above, and has an access hole in the rear for the oil drain plug, which is in the second skid shown above...
    I guess I need to ask RCI.
  4. Aug 5, 2021 at 5:59 PM
    For anyone who's interested - the word from RCI is that their engine skid plate replaces both of the pieces in the photo above.
  5. Aug 5, 2021 at 6:56 PM
    Reldn
    Reldn New Member
    Missouri
    '24 Ice Cap TRD ORP
    Yep, I can confirm. The front skid does take the place of both of those stock skids.
    Bodie the Dog likes this.
  6. Aug 5, 2021 at 7:14 PM
    Are you talking about this plastic piece? I didn't remove it. And its a good thing I didn't remove it as I help me to mount the front camera.
    Harringbr99 and Reldn[QUOTED] like this.
  7. Aug 5, 2021 at 7:46 PM
    Reldn
    Reldn New Member
    Missouri
    '24 Ice Cap TRD ORP
    Huh...Yep, that's the piece. I like that placement for a front camera. I hadn't even considered leaving that piece attached. I'll amend my post!
  8. Aug 5, 2021 at 8:41 PM
    Is that plastic piece attached at the front of the RCI skid, or just on the bumper side up front?
  9. Aug 5, 2021 at 9:08 PM
    I used 2 zip ties for a cleaner look.
  10. Aug 5, 2021 at 9:34 PM
    Good idea. I think I'll look into placing an order for one of these skids. It looks so much cleaner and I'm sure is a huge improvement over the stock engine skid.
    Thanks!
  11. Aug 6, 2021 at 5:32 AM
    olliechristoper
    olliechristoper New Member
    Chris
    I have noticed most of all these aftermarket skid plates end at the radiator. Are there any companys out there that have them full length like the OEM TRD pro front plate that goes to the bumper?
  12. Aug 6, 2021 at 5:35 AM
    iamincrediboy
    iamincrediboy New Member
    South FL
    +1 for RCI front skid replacing the two separate stock pieces. Also, FYI for everyone, RCI sells the piece that the above poster attached their camera to. Maybe a touch more peace of mind when that is metal instead of plastic, thats why I got mine. Plus its what covers your radiator and fan and hoses right there from debris bouncing up.
    Ironguy, Bodie the Dog, Reldn and 2 others like this.
  13. Aug 6, 2021 at 6:18 AM
    Ajmogen
    Ajmogen Staying Stock
    Aaron
    Wisconsin
    Liscence Plate Surround
  14. Aug 6, 2021 at 6:26 AM
    olliechristoper
    Chris
    Thank you guys!! I am now really liking the RCI brand.
    travelinscout and Ajmogen like this.
  15. Aug 6, 2021 at 7:01 AM
    The OEM TRD skid goes a bit more forward than the aftermarket skids, but it does not go all the way to the bumper. You would still need a filler of some kind with the TRD skid.
    7385 likes this.
  16. Aug 6, 2021 at 8:50 AM
    Any input on bare aluminum vs. black powdercoat on the RCI engine skid?
  17. Aug 6, 2021 at 8:56 AM
    There is not much of a gap with TRD skid. Not sure there's a filler plate for TRD skids.
    21Venture likes this.
  18. Aug 6, 2021 at 9:05 AM
    Bare aluminum looks matching with TRD skid but I see scratches. Black powdercoat looks better when you have RCI front skid. Also add lower control arm skid to hide the LCA bolts if you go with RCI front skid.
  19. Aug 6, 2021 at 9:31 AM
    21Venture
    21Venture Roof Rat
    Bryan
    Edinburg, TX
    2021 4R Venture Super White & 2007 FJ
    4R-TerraFlex Falcon Sport/Tow 2/1 Lift/Level, Nise Rack Crossbars, KO2 LT265-70-17 FJ- Icon Stage 3, 4.56 gears and 10k winch
    Been looking at this also. Mainly for the oil filter access without removing the skid plate.
    Just ordered.
  20. Aug 6, 2021 at 10:13 AM
    Reldn
    Reldn New Member
    Missouri
    '24 Ice Cap TRD ORP
    They are definitely really nice skids. I have almost the full set of them armoring the underside of my vehicle.
  21. Aug 6, 2021 at 10:17 AM
    You're right. I forgot how those go forward like that...my mistake.
  22. Aug 6, 2021 at 10:22 AM
    Nice. Which metal and finish did you decide on?
    21Venture[QUOTED] likes this.
  23. Aug 6, 2021 at 10:24 AM
    Someone posted at one time that they trimmed the OEM plastic filler piece and mounted it with the TRD skid, similar to what you did, just without the rear zip ties. It was held on by the front bolts only, being as how it was smaller now that it was trimmed.
  24. Aug 6, 2021 at 10:26 AM
    Any photos of your skid setup?
  25. Aug 6, 2021 at 10:28 AM
    21Venture
    21Venture Roof Rat
    Bryan
    Edinburg, TX
    Went with black power coated steel. Also ordered the lil bumper blank to fill in the gap.
    To the folks that have these already- Is it fairly easy to pressure wash and clean these? Both top side and bottom? That's my big concern is the skid plate holding sand?
    olliechristoper likes this.
  26. Aug 6, 2021 at 10:31 AM
    TRD skid pic is from my TRD Pro. I did not change anything. I just added RCI skids behind the TRD Pro skid.
    Black RCI skids are from my TRD ORP. I did not do any trimming. Nothing more done from my install video. Just removed stock skids and install RCI full skids with provided new bolts. Added 2 zip ties at the bottom for the plastic cover. Top bolts kept as is.
  27. Aug 6, 2021 at 10:38 AM
    Reldn
    Reldn New Member
    Missouri
    '24 Ice Cap TRD ORP
    Yep, I've got a couple photos so far:
    Engine + Bumper fill plate:
    Gas Tank:
    Rear Diff:
    I don't have any photos of my Transmission & T-Case skids at the moment, but, I could probably grab some shots of those if you'd like.
    olliechristoper and 21Venture like this.
  28. Aug 6, 2021 at 10:52 AM
    iamincrediboy
    South FL
    So yes, the act of cleaning is easy, pressure wash and wipe clean to your hearts content. But don't forget, more specifically to those of us who got good ol steel... the front skid alone is about 52lbs. Transmission skid as about 40. Transfer case/cross member are about 60 combined. Gas tank is about 55lb.
    These arent insignificant numbers when noodling about on your back under the car with limited mobility, unless you're a badass with your own lift.
  29. Aug 6, 2021 at 11:00 AM
    I only meant he reused the oem plastic filler piece as you did, not that you trimmed anything.
  30. Aug 6, 2021 at 11:11 AM
    21Venture
    21Venture Roof Rat
    Bryan
    Edinburg, TX
    Thank you. Shazam that's a good bit of weight to push around underneath the truck. Most offroad is spent at the beach and vehicle is usually pressure washed before leaving the island and again during wash at home.
