Rays SCS wheels
Discussion in 'Wheels & Tires' started by JimmyAGR, Oct 24, 2019.
  1. Oct 24, 2019 at 6:47 AM
    JimmyAGR
    JimmyAGR [OP] New Member
    Jimmy
    Jacksonville
    2020 ORP
    So hopefully picking up my ORP tonight. Want to order some Rays SCS wheels and just want to make sure that the TPMS sensors from the factory wheels will work in the Rays.
    Thanks for any information.
    Jimmy
  2. Oct 24, 2019 at 7:01 AM
    Roman
    Roman New Member Vendor
    Roman
    Yes, they will work. We've used several SCS wheels and swapped the sensors over from the stockers.
  3. Oct 24, 2019 at 7:21 AM
    socal_erik
    socal_erik New Member
    Erik
    16 SR5
    Same for SR5 oem 5th gen?
  4. Oct 24, 2019 at 7:31 AM
    RusPro17
    RusPro17 Back home again!!
    Don
    Pa.
    2023 TRD Pro Solar Octane
    SCS wheels and Westcott lift
    Yes they will work. They did on my Tacoma.
  5. Oct 24, 2019 at 9:42 AM
    aroyalsfan
    aroyalsfan The Owner
    Kansas City
    I can't remember the last time I was ever right, but I the TPMS sensors are built into valve stem. So all they have to is pop it out of one wheel and put it in another. Since they are already programed to your vehicle it should make them compatible with all wheels stock or non-stock. Really the only thing you should have to worry about is if the wheel fits...and the largest tire you can fit without it rubbing. :deadhorse:
  6. Oct 24, 2019 at 10:42 AM
    socal_erik
    Erik
    16 SR5
    True, however, in my SR5 taco I had to flip them to work. Either way, they’ll still work lol
  7. Oct 24, 2019 at 10:48 AM
    JimmyAGR
    Jimmy
    Jacksonville
    2020 ORP
    Thanks everyone appreciate the quick responses. Just found out that the 4Runner that was delivered last night is a 2019, not a 2020 :mad:. So back to waiting....
  8. Nov 5, 2019 at 9:05 AM
    ILBEATU
    ILBEATU New Member
    I swapped the tires and sensors from my 19 Pro for some Ray10s. Everything swapped just fine.
  9. Nov 5, 2019 at 9:38 AM
    RusPro17
    Don
    Pa.
    Looks good. I was planning on putting a set of SCS wheels on my Pro. I figure you stayed with the stock tires. So the wheels are 17x8.5 correct. Do you have a pic straight on off to the side. Wanted to see if they stick out a little because of the wider wheel. Do they rub when you turn? Thank you.
    geek755 likes this.
  10. Nov 5, 2019 at 9:40 AM
    ILBEATU
    ILBEATU New Member
    I can get more pics. No rubbing. They do stick out some more. They are 17x8.5.
  11. Nov 5, 2019 at 9:41 AM
    RusPro17
    Don
    Pa.
    I had them on my Tacoma and just a little out but I think that looks better plus gives the handling a little better.
  12. Nov 5, 2019 at 10:23 AM
    JimmyAGR
    Jimmy
    Jacksonville
    2020 ORP
    Are they the bronze finish, they look much lighter?
  13. Nov 5, 2019 at 11:00 AM
    booyaa
    booyaa New Member
    slim
    worked on my 18
    socal_erik likes this.
  14. Nov 5, 2019 at 12:36 PM
    ILBEATU
    ILBEATU New Member
    Its just the light. They are brushed copper. I have some brushed bronze ones that change with the light and angle.
  15. Nov 5, 2019 at 12:39 PM
    JimmyAGR
    Jimmy
    Jacksonville
    2020 ORP
    Makes sense, looks great. I am looking at the bronze for my MGM paint. They are out of stock until around mid Dec.
  16. Nov 5, 2019 at 12:58 PM
    ILBEATU
    ILBEATU New Member
    Heres some pics. If you can buy the blems.
  17. Nov 5, 2019 at 1:11 PM
    RusPro17
    Don
    Pa.
    They look good at that stance!! Protruding just a little.
