Ratha Precision Design Tire Carrier Build
Discussion in '5th Gen Builds (2010-2024)' started by JT4RN, Jan 18, 2026.
  1. Jan 18, 2026 at 9:22 AM
    JT4RN
    JT4RN [OP] New Member
    Rust Belt
    2018 Trd offroad
    After doing some research on tire carriers. I decided to purchase the Ratha Precision Design diy kit. The Ratha weld kit requires you to purchase tubing to complete the build. Since his videos were based on a 4runner. I reached out to Ratha to see if he could include all the pre-cut tubing and weld a couple of parts. After some back and forth emails. A custom invoice was created and now here we are. With the included tubing already cut to the proper length, all I had to do was weld the remaining pieces.
    The latest kit use bearings for the hinge a big upgrade from previous bushings. A option for a billet aluminium handle instead of the plastic knob for the locking pin.
    MeefZah, ToyotaDude99 and ChessGuy like this.
  2. Jan 21, 2026 at 5:10 AM
    JT4RN
    Rust Belt
    2018 Trd offroad
    Package two arrived without damage. The welds and tubing look great. The hinge is definitely stout. Being a novice welder, the build is only possible due to the extra help that Ratha put in.
  3. Jan 21, 2026 at 5:50 AM
    L
    20 Venture/17 Taco
    Looking good. Let us know how it looks when mounted.
    JT4RN[OP] likes this.
  4. Mar 27, 2026 at 3:55 PM
    JT4RN
    Rust Belt
    2018 Trd offroad
    Today, I decided to start the build. Just posting photos of my progress. The build plans are pretty straightforward. My only issue was not having a band saw to cut the excess and make a clean 45° cut. I used an angle grinder and had to clean it up with a flap disk. I tacked the accessory hitch mount and stopped there.
    Thacrow and HuskyMike like this.
  5. Mar 27, 2026 at 5:06 PM
    Wow. I commend your efforts. Always admire people on this site who have these skills. Keep posting pics. I can’t wait to see it completed
    MeefZah and JT4RN[OP] like this.
  6. Apr 5, 2026 at 1:48 PM
    JT4RN
    Rust Belt
    2018 Trd offroad
    I had some free time yesterday. Preceded to finish up tacking the rest of the hitch mount, swing arm and locking pin.
    MeefZah, Thacrow and NB4x4 like this.
  7. Apr 5, 2026 at 2:05 PM
    Charlievee
    Charlievee Not new member.
    Lots of work for a hitch mount, but i'm no welder.
    NB4x4 likes this.
  8. Apr 5, 2026 at 3:01 PM
    JT4RN
    Rust Belt
    2018 Trd offroad
    It's actual not too bad. I have done all the mods on the 4runner and building this is just a part of it.
  9. Apr 7, 2026 at 1:47 PM
    JT4RN
    Rust Belt
    2018 Trd offroad
    Next on the list, tacking up the vertical tube to the wheel mount receiver. With that done I decided to mount the tube 1/2 inch away from corner of the bent bracket. Thus moving it closer to the tailgate.
    I then proceeded to tack the bent bracket flush with the end of the swing arm. I positioned the support tube to the center of the wheel receiver tube and tacked it in place.
    For the wheel mount tube, I cut it 10 degrees with an angle grinder. After several minutes I changed my mind and went with 7 degrees instead. Then temporarily attached the wheel plate. Now the tedious part, welding and blending the cover plates in. It took some time, not perfect but I got it done. Finished the day by tapping the bolts for the wear pad and bump stops.
    MeefZah, Thacrow and HuskyMike like this.
  10. Apr 7, 2026 at 3:25 PM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    Appreciate you sharing here. Appreciate all the pics and updates.
    How much did it cost?
  11. Apr 8, 2026 at 5:58 AM
    JT4RN
    Rust Belt
    2018 Trd offroad
    Thanks, I was cursed with the DIY bug. I hope it helps others with their own build. Made the purchase last November. The custom invoice was $874. Spent another $130 to purchase 2 bolt taps, wheel mount bolts, and two cans of Steel It.
    Thacrow[QUOTED] likes this.
  12. Apr 8, 2026 at 10:08 AM
    looking good. What coating do you plan to go with? Powder Coating?
  13. Apr 8, 2026 at 11:32 AM
    JT4RN
    Rust Belt
    2018 Trd offroad
    Thanks, no powder coating. I am going with two cans of Steel It. It's a polyurethane aerosol with UV resistant anti corrosion coating. I can touch it up when needed.
    morfdq[QUOTED] and Thacrow like this.
  14. Apr 9, 2026 at 1:12 PM
    JT4RN
    Rust Belt
    2018 Trd offroad
    Squeezed in a couple of things yesterday. Did a dry fit of the carrier and no issues with the tailgate. Did the latch handle mod. Bought a small 1/2 inch pipe and cut the threads of one side. I also cut the toggle handle about 1 off. Grind it down with a flap disk to fit the pipe. Weld it and fitted an old mountain bike handle. Last thing for the day was tack the gusset.
    MeefZah and Thacrow like this.
  15. Apr 9, 2026 at 9:54 PM
    leftyfire
    leftyfire New Member
    Michael
    Colorado Springs
    2006 Limited V6
    Looks like a fun project!
  16. Apr 11, 2026 at 2:56 AM
    JT4RN
    Rust Belt
    2018 Trd offroad
    At times it is. Wish my weld table was 100% flat. It flexes when I really need to clamp down. I have to constantly check things, making it a longer process. Can't wait until it's done though.
