raptor lights
Discussion in '5th Gen 4Runners (2010-2024)' started by Tgatten0722, Oct 16, 2020.
  1. Oct 16, 2020 at 3:55 PM
    Tgatten0722
    Tgatten0722 [OP] New Member
    Travis
    2020 4Runner Venture
    None
    just installed the TRD pro grille with raptor lights.. followed a YouTube video and my raptor lights don’t shut off when the car is off.. the positive is plugged into the only remaining spot in the fuse box and the negative is on the bolt beside the fuse box.. not the most mechanically inclines.. any help is appreciated. Thanks
  2. Oct 16, 2020 at 3:58 PM
    PVT Pablo
    PVT Pablo
    Paul
    Puget Sound, WA
    2016 4Runner TRD Pro
    Wait did you just plug into a random fuse location or did the instructions say to plug there?
    Thatbassguy, A&P and Mtbpsych like this.
  3. Oct 16, 2020 at 5:06 PM
    ForRun
    ForRun 4Runner
    2020 orp
    Need a fuse tap and go to the ignition 10 amp.. that or t tap the parking lights and use an inline fuse
    Thatbassguy, AG4RN8 and A&P like this.
  4. Oct 16, 2020 at 11:44 PM
    4runningyeti
    4runningyeti New Member
    PA
    2020 BRM TRD ORP
    FYI the 2020 have different fuses alignments especially in the cab fuse box and a little bit as well in the engine bay fuse box, I had to play around to fine an empty one that wasn’t “always hot” and ultimately, could not, just used the included n+1 fuse tap included and went into the spot recommended. Unfortunately it means box in engine bag doesn’t close perfectly, but tight enough- I was able to do the bolt trick - if standing by front driver tire looking across the engine bay it’s the bolt apparatus in the back right of fuse box- to feed the wire up and through so it at least looks a little cleaner.
    but yes to answer your question, the empty engine box fuses spaces all seem to be always hot.
  5. Oct 17, 2020 at 4:04 AM
    4RunnerRVA
    4RunnerRVA New Member
    So I plugged mine into the “INJ” spot on the engine bay fuse box with the adapter my lights came with to have 10/5 fuses.. they are on only when the engine is on, then turn off.
    I did just discover yesterday that the cabin fuse box is unfortunately different in the 2020s as we attempted to install a switch, and finally gave up until I do a little bit more research.
    AG4RN8 likes this.
  6. Oct 17, 2020 at 4:23 AM
    RusPro17
    RusPro17 Back home again!!
    Don
    Pa.
    2023 TRD Pro Solar Octane
    SCS wheels and Westcott lift
    I have a brand new set of raptor lights for sale on here. I decided not to add them. I put my Bajadesigns 20 inch led bar in behind that grille part. There is a video on you tube the guy added them to his 2020 Pro. I think he has them in the INJ spot in the fuse box.
  7. Nov 17, 2020 at 7:21 PM
    FJredux
    FJredux New Member
    Philippe
    San Diego, CA
    1.25" wheel spacers, 2" lift, Raceline wheels, BFG AT 285/75R17
    Has anyone found a Raptor light kit that fits the 2020 Venture grille? The top of the grille does not have a honeycomb pattern. It has the Toyota oval emblem in the middle and some rectangular slots on either side.
  8. Dec 15, 2020 at 2:04 PM
    SomeDogsLife
    SomeDogsLife 805 SoCal Girl
    Alyx
    Ventura County, CA
    2021 Venture Special Edition
    Matte Rivera Blue + black fenders, hood scoop & roof wrap, Full vehicle PPF, Smoked headlights & taillights, Ceramic window tint 5% back & 17% front + UV blocking clear windshield tint, Hydrophobic coated wheels & windows, fog light fangs.
    I searched everywhere for square raptor lights to for the Venture with no luck. People were saying to get a light bar instead but I love the look of the raptor lights. I ended up buying a TRD Pro grille.
    FJredux likes this.
  9. Dec 15, 2020 at 10:21 PM
    Area52
    Area52 New Member
    PHX
    ‘20 SR5p
    You can do it on the non-pro grille. Just have to go with two instead.
  10. Dec 21, 2020 at 1:05 AM
    SomeDogsLife
    Alyx
    Ventura County, CA
    Could you post pics of what you did please?
  11. May 17, 2021 at 11:13 PM
    SomeDogsLife
    Alyx
    Ventura County, CA
