Raptor lights looking for recommedations
Discussion in '5th Gen 4Runners (2010-2024)' started by 4Runner_Patrick, Mar 26, 2023.
  1. Mar 26, 2023 at 12:56 PM
    4Runner_Patrick
    4Runner_Patrick [OP] New Member
    2023 TRD PRO Black
    Hi all,
    I've noticed many different companies are selling these kits. Not sure which one to go with.
    Any suggestions are appreciated.
    Thanks
  2. Mar 27, 2023 at 1:39 PM
    DIRTRCR13
    DIRTRCR13 New Member
    Jerm
    The 405
    '16 Sierra Romeo Cinco
    Out of the 5000 different kits out there, there are really only 4-5 different makers... And not much different between them all anyways. Pick one. If you go on the cheaper side, just make sure its a reputable sales place that will help you in the event of a failure.
  3. Mar 27, 2023 at 2:14 PM
    TN_FunRunner
    TN_FunRunner Custom Title
    Jay
    W. TN
    2018 TRD ORP, 2007 SR5 4WD
    I have the smoked amber 3 light kit from 4runner lifestyle. Perfect fit easy install.
  4. Mar 27, 2023 at 2:22 PM
    I use these when I convert my DRL to a highbeam. I'm using only 2 of them (since I only want to have DRL for the sake of it if there is any law for it)
    Recently I have notice 1 or 2 of leds on each flickering. I'm running off a wire tap from the cigarette lighter, not using the INJ fuse. So this post if for you to avoid this brand.
    Also following this thread if any one has a good set that is running for years even after splashing water (Including high pressure car washes) and snow.
    Even better if there is a wire harness (that doesn't require to remove the bumper and headlight) for 2021 bi-led 4runners to run both DRL and Highbeam.
  5. Mar 27, 2023 at 3:07 PM
    2020 4Runner
    2020 4Runner New Member
    Fl
  6. Mar 28, 2023 at 5:29 AM
    Marco
    Marco New Member
    2021 TRD Off Road
    Where does everyone tap in for Raptor Light power? I used the EFI-2 spot but lights would randomly turn on. The add-a-fuse wasn't low profile enough to use another port and the harness wasn't long enough to get to the cabin through the firewall. I was trying to avoid adding wire and another connection.
  7. Mar 28, 2023 at 6:20 AM
    22LimeRush
    22LimeRush New Member
    2022 Toyota 4runner TRD Pro - Lime Rush mostly stock
    Mostly Stock - just a few interior accessories, shelving, sorters, screen protector.
  8. Mar 28, 2023 at 8:24 AM
    Ripper238
    Ripper238 New Member
    2019 TRD OR
    It will enhance the visibility of your vehicle off road and in bad weather conditions. That's really what they are useful for, like marker lights.
    I don't have them, though cool looking. I would rather be stealthy.
    fixed viability to visibility. thx Zap. ;)
  9. Mar 28, 2023 at 8:50 AM
    Rayc308
    Rayc308 New Member
    Ray
    2023 Trd premium
    I have a orp with the silver bars on each side of Toyota logo where do you put the raptor lights
  10. Mar 28, 2023 at 9:14 AM
    OverRunner
    OverRunner rebmeM weN
    Jared
    Denton, TX
    ‘21 ORP w/KDSS
    They are clearance markers that indicate your vehicle is wider than 80” to oncoming traffic (like truckers). They are required on any vehicle wider than 80”, hence their requirement on the Raptor, which has wider set wheels than the non-SVT F-150 brother. They’re often located on top of the cab in older/other trucks, but for the SVT, Ford wanted to do something unique to the Raptor. I upgraded my fog lights for better visibility in inclement weather, as I didn’t think tiny markers would help much, but I’d be glad to be proven wrong :)
    I think it’s really just cosmetic on a 4Runner.
    5six likes this.
