Randomly not starting
Discussion in '3rd Gen 4Runners (1996-2002)' started by amiesoboe, Jan 10, 2023.
  1. Jan 10, 2023 at 11:43 AM
    amiesoboe
    amiesoboe [OP] New Member
    Amie
    Indiana
    1999 4Runner
    I recently had the alternator replaced in my 99 4Runner. They checked the battery and everything else is fine, however, sometimes it won't start. The lights come on but when I turn the key there is not a sound. I had it jumped both times it happened and it did start but it doesn't make sense if the battery is fine. Could it be the starter? Thanks in advance!
    Bob likes this.
  2. Jan 10, 2023 at 3:27 PM
    Doubtful. Starters and alternators rarely go bad on these.
    Especially, if a jump starts it, the starter should be good.
    You probably have a bad wiring connection between the battery and the starter. Check all the grounds to the engine and body and look at your battery cables and see what condition they are in. They can rot from the inside out.
    Applying extra voltage from a jump, can reverse corrosion in the cables or a connection enough that it will start. It will probably start for a while until the corrosion comes back.
  3. Jan 10, 2023 at 6:05 PM
    Ahdofu
    Ahdofu New Member
    Matt
    When do you experience the periodic not starting issue? Does it happen after a while where the vehicle has sat inoperative or can that happen at any moment? If the former, then I'd call it a battery issue. If the latter, then a bad connection.
  4. Jan 10, 2023 at 6:45 PM
    mousemeat
    mousemeat New Member
    Memphis, TN.
    1997 4 runner limited
    check wiring...especially battery...
