Randomly engine does not start
Discussion in '3rd Gen 4Runners (1996-2002)' started by jguardia01, Dec 15, 2020.
  1. Dec 15, 2020 at 12:17 PM
    jguardia01
    jguardia01 [OP] New Member
    jj
    1999 4 runner
    none
    good morning people ...
    i have a 1999 basic 4runner
    2.7 / V4 engine ...
    4x2 ...
    ±250k miles ...
    for more than a year i have been having a problem: whenever it pleases her, engine does not start, all the dash lights are on but no even a sound ...
    after many attempts, sometimes a few seconds later, sometimes it has taken ±20 minutes, engine finally starts like nothing has happened ...
    it does it randomly so unfortunately, no electromechanical diagnostic tester has been able to identify the problem ...
    i changed the starter (it was the original), the battery (it was old anyways) ... the problem still ...
    no one has any idea ...
    all suggestions will be considered ...
    thanks ...
    jaime javier
  2. Dec 15, 2020 at 6:59 PM
    treyus30
    treyus30 New Member
    Trey
    '99 Limited & '99 Tacoma PreRunner
    My only thought is maybe your gear shifter isn't making it all the way into Park, or the identifier is wonky. Next time it happens, try holding the shifter forward.
  3. Dec 15, 2020 at 8:40 PM
    jguardia01
    jj
    1999 4 runner
    none
    thanks ... already checked that too ...
    also disconected the "power cut" ...
    a friend says it might be the ground wire which i am going to change tomorrow and lets' see ...
  4. Dec 16, 2020 at 6:02 AM
    canadian.bacon
    Snowland
    ‘22 Tesla Model Y
    I bet it’s the ground wire.
    bear1998 likes this.
  5. Dec 16, 2020 at 7:47 AM
    Sounds like Battery cables. They can rot out from the inside. When they get to a certain point they act EXACTLY like you describe. I had a car, where it would randomly not start. But if I turned on my headlights for 30 seconds, it would magically start. It wound up being a negative battery cable that rotted from the inside out. The ends and cable looked fine but once off the car, it audibly "crackled" inside from the corrosion when you bent it. My 4Runner had a very similar issue and I finally cut 8" off the negative battery cable and soldered on a new section.
    A bad ground will do something similar or even a faulty ignition cylinder.
    Edit: The headlight magic actually makes some sense. When you run power through a corroded electrical connection...it REVERSES a small bit of the corrosion which allows the starter to start the car on the next attempt.
  6. Dec 16, 2020 at 9:23 AM
    flyinhoot
    flyinhoot When in doubt, Throttle out.
    Nor Cal
    2020 TRD Pro 4Runner "Trudy"
    Monochrome everything. LED reverse lights.
    I had a 1999 tacoma with the 2.4. I had similar issue that would occasionally creep up. Large elevation changes would sometimes mess with the computer or something because usually it happened while camping. Try disconnecting the battery for about 10-15 minutes. It resets the computers. It would start right up after that every time.
  7. Dec 16, 2020 at 10:38 AM
    He made it sound like he can't even get it to crank. Don't know how what you suggested will help.
  8. Dec 16, 2020 at 1:18 PM
    treyus30
    treyus30 New Member
    Trey
    But what ground wire
    You might as well have said its not the tires.
  9. Dec 17, 2020 at 5:39 AM
    canadian.bacon
    Snowland
    ‘22 Tesla Model Y
    LOL, indeed. Usually there is a big ground wire in the engine bay. Not sure about the runner, but I had the exact same issue with 2 other cars. Rust buildup between the chassis and the cable.
