Rago Fab Hardware Problems
Discussion in '5th Gen 4Runners (2010-2024)' started by adventure_t4r, Apr 29, 2021.
  1. Apr 29, 2021 at 9:54 AM
    adventure_t4r
    adventure_t4r [OP] New Member
    Cody
    1999 SR5 & 2017 TRD Off-Road Premium
    So I just got some Rago molle panels for the rear windows from a friend. The thing is when you try and loosen the bolt on the outside of the spacer to remove the molle panels, the whole spacer loosens from the threaded rod on the backside (in the 4Runner). So when we were un-installing these from his 4Runner, the threaded rod got stuck in the 4Runner and had to be taken out with vice grips. I can see constantly threading and un-threading (in order to mount accessories) can become a problem over time.
    After looking at the other molle panels in detail on the market; Finn Fab, Victory 4x4, TSO, Etc. - they all use a better design than Rago fab. Instead of threaded rods into a spacer, they all use one bolt and one spacer. In my opinion, this is a better design. Not sure why Rago is still using this faulty design.
    Has anyone experienced this?
    If I was looking at buying brand new, I would go with another company that uses a better design; Finn Fab, Victory, TSO. All of those panels use a better hardware system. I would steer clear of Rago.
    trail4r likes this.
  2. Apr 29, 2021 at 10:30 AM
    trail4r
    trail4r New Member
    Brenan
    2014 Trail Edition Premium
    Too Many to List
    Yeah, the same thing happened to us. No Bueno - went with Finn Fab Power Grid panels after this.
    adventure_t4r[OP] likes this.
  3. Apr 29, 2021 at 10:41 AM
    Mech-E
    Mech-E New Member
    2021 TRD Pro MGM
    red loctite the part you want to stay threaded?
  4. Apr 29, 2021 at 10:55 AM
    adventure_t4r
    Cody
    Yeah I guess that would work, shouldn't have to though in my opinion. Rago has had these out for a couple of years now, you think they would've made changes.
  5. Apr 29, 2021 at 10:56 AM
    adventure_t4r
    Cody
    I've heard nothing but good things about Finn Fab.
  6. Apr 29, 2021 at 11:08 AM
    newlife
    Knoxville TN
    2021 venture 22 JTR
    All of them.
    Why would you need to constantly unthread it though ? I haven’t taken mine off at all to mount my stuff to them. And 90% sure that was the intention rago had was a one and done install that you can add to it at any point. Even with my bolt on equipment (quick fists, fire mount etc) I was easily able to get a small wrench or flex head wrench behind the panel to hold a nut.
    ruiz4251 and ATX14 like this.
  7. Apr 29, 2021 at 11:08 AM
    Mech-E
    Mech-E New Member
    2021 TRD Pro MGM
    I guess they treat their 4runner accessories/updates the same way Toyota does. ;)
  8. Apr 29, 2021 at 7:02 PM
    Gamma Ray
    2020 SR5 Barcelona Red
    Nah, watch their video of the molle panel install again. They say in it that you may have to remove the panels in order to install things. Like you, I've done workarounds, but it hasn't always been easy. Of course, now that I've got the shelf, the panels aren't coming off anytime soon.
    Fltslr likes this.
  9. Apr 29, 2021 at 7:03 PM
    Gamma Ray
    I like Rago's stuff, but yeah, their hardware's kind of meh. I didn't replace the spacers, the washers, or the big bolt for the very top, but I did replace all of the other hardware with standard hex head bolts. I don't like the button head bolt stuff.
  10. Apr 29, 2021 at 9:18 PM
    Fltslr
    Fltslr the last hurrah
    2021 Lunar Rock 4runner Pro
    I got the shelf too. I just these amazing bungees and coated wire thingies, as well other non bolt on fasteners. 20210315_073644.jpg
    ruiz4251 likes this.
  11. Apr 29, 2021 at 10:16 PM
    ruiz4251
    George
    TEXAS
    16 Trail Premium
    @Fltslr
    Same
    I also use velcro molle backings
  12. Apr 30, 2021 at 10:24 AM
    adventure_t4r
    Cody
    That's a good idea thanks!
  13. May 2, 2021 at 12:38 PM
    jwatson1122
    jwatson1122 New Member
    Joshua
    '16 4Runner Trail
    “coated wire thingies,” are the best.
  14. Nov 25, 2023 at 10:35 AM
    Andrea t
    Andrea t New Member
    I know this thread is old but i have bought the rago molle panels for 5gen 4r and so one side complete with minimal issues and the other side is going to become a nightmare. The spacer screw refuses to screw into its intended hole. Won’t budge. I don’t wanna force and make things worse. Anyone have any advice bc I’m about ready to break down pay Toyota $100,000,000.00 to finish this off for me. Could use some guidance pls
  15. Nov 25, 2023 at 10:57 AM
    You might need to use a thread chaser from a tap and die set.
    RumHamRunner73 likes this.
  16. Nov 25, 2023 at 11:16 AM
    Andrea t
    Andrea t New Member
    That would be something, having to go thru all that for it to work when it was supposed to work from the get go. Probably should have done more research before buying rago brand. Thanks for responding
  17. Nov 25, 2023 at 12:02 PM
    Don't give up. Someone you know probably has the tool you need. I had to fiddle a bit with my panels (RAGO)
  18. Nov 25, 2023 at 12:13 PM
    Andrea t
    Andrea t New Member
    Oh no, not giving up. I’m gonna chase down a thread chaser. By any chance do you know what size is needed?
  19. Nov 25, 2023 at 12:53 PM
    I am going to guess it is 8 x 1.25. I think the bottom front and rear cargo are 6 x 1.00, I am assuming this is the upper coat hook you are having an issue with?
  20. Nov 26, 2023 at 9:54 AM
    Andrea t
    Andrea t New Member
    Hey was messing around out there and here’s the real problem, two different parts! Thank you Rago!
  21. Nov 26, 2023 at 9:57 AM
    Andrea t
    Andrea t New Member
    So we can see the bad one in the left is shorter, the hex head on the end is a larger size than the right and the threads are very different. Gd I’m unhappy and they better expedite another asap
  22. Nov 26, 2023 at 10:01 AM
    What did Rago say?
  23. Nov 26, 2023 at 10:12 AM
    Andrea t
    Andrea t New Member
    I don’t expect a response today, Sunday. As they only operate Monday-Fri. The entire experience has been disappointing ..having to go online and replay/watch YouTube vids on this. Is it that hard to throw an instruction pamphlet in your products? I paid a lot for this set up and expected more from them
  24. Nov 26, 2023 at 2:34 PM
    I would expect that them seeing the photo in post #20 would warrant an overnighted replacement.
  25. Nov 26, 2023 at 2:37 PM
    Andrea t
    Andrea t New Member
    The one on the right side is correct
  26. Nov 27, 2023 at 10:44 AM
    SuedePflow
    SuedePflow New Member
    paul
    2020 TRD ORP
    Gobi Rack & ladder Custom made swing out spare tire carrier. BA4x4 front bumper w/ lightbar Warn Evo 8-2 winch w/ 200A kill switch N-Fab side steps TRD Skidplate Clearanced front bumper TRD Pro grille OEM rear black valence Wheels/suspension mods: (5) Method 703 Wheels, KO2 tires, 1.25 spacers Body mount chop Bilstein 6112 front lift, 5160 rear w/ 2" icon springs SPC upper control arms Lighting mods: Alpharex Luxx headlights Aiden James LED fog light bezel and cam relocation (7) Baja designs Squadron lights on custom mount.
    It's been a while since I installed my Rago's, but I had no issues. I think I did loctite the threads between the spacer and little threaded rod. But no issues since.
  27. Nov 27, 2023 at 11:04 AM
    Andrea t
    Andrea t New Member
    No issues bc you were sent the correct hardware to set it up, gotcha. I was not that lucky and still waiting for their response.
