Rago fab cb antenna mount owners
Discussion in 'Audio & Video' started by T4R13, Apr 7, 2021.
  1. Apr 7, 2021 at 10:41 AM
    T4R13
    T4R13 [OP] New Member
    Clarksburg wv
    19 sr5p
    Requesting help from anyone who has successfully made this work for there 5th gen. Having sky high standing wave, ground powder coat off on all screw heads and where the fire ring mounts on the bottom , ran a braided ground on inside of bracket to the body and still no go
  2. Apr 7, 2021 at 11:14 AM
    T4R13
    Clarksburg wv
    19 sr5p
  3. Apr 7, 2021 at 11:53 AM
    Wish there is any option that goes on the stock roof rails. If there is I can move my GMRS antenna and add a cb as well.. :)
    (Not feeling comfortable to drill the bumper.)
    (Update - something like this)
  4. Apr 7, 2021 at 11:56 AM
    T4R13
    Clarksburg wv
    19 sr5p
    Do not under any circumstance drill it lol. Not for this mount anyway , I’ve tried everything checked resistance between everything. Have it where I should and don’t where I shouldn’t. I’ve spent hours messing with it
  5. Apr 7, 2021 at 11:58 AM
    I hope someone can help you with this.. :(
  6. Apr 7, 2021 at 12:02 PM
    T4R13
    Clarksburg wv
    19 sr5p
    Would be pretty easy to make a cb mount for there. Just need a standard l mount bracket that you could bolt into the channel with a weld washer. Similar to how the factory cross bars tighten down. Had I not invested so much time and energy into gutting the interior and everything to run this setup I should have done something like that
    kmeeg[QUOTED] likes this.
  7. Apr 7, 2021 at 12:13 PM
    newlife
    Knoxville TN
    2021 venture 22 JTR
    All of them.
    What did you attach your ground to in the body? Also what antenna are you running?
    jmkulbeth likes this.
  8. Apr 7, 2021 at 12:14 PM
    newlife
    Knoxville TN
    2021 venture 22 JTR
    All of them.
    To add have you tested the antenna on another rig that is known to have low swr? Maybe a friend or a local cb shop?
  9. Apr 7, 2021 at 12:17 PM
    jmkulbeth
    jmkulbeth Have you tried turning it off and on again?
    Jeffrey (KE5HDB)
    Siloam Springs, AR
    2020 4Runner Offroad Premium, Nautical Blue
    Bone stock!
    I'm looking at something like for the rack: Comet RS-660U Mobile Antenna Adjustable Roof Rack Mounts - Mobile Antenna Mounts (dxengineering.com)
    I haven't measured to see if it'll fit, but something along these lines would work. Plus, you can fold it down when you're height-restricted.
  10. Apr 7, 2021 at 12:17 PM
    T4R13
    Clarksburg wv
    19 sr5p
    5’ tunable tip firestick
  11. Apr 7, 2021 at 12:19 PM
    T4R13
    Clarksburg wv
    19 sr5p
    Have swapped all kinds of antennas on another rig that works. Local cb shop told me mount looks great but won’t ever work., which I don’t want to believe , hoping for someone with the same setup to chime in
  12. Apr 7, 2021 at 12:29 PM
    jmkulbeth
    Jeffrey (KE5HDB)
    Siloam Springs, AR
    Bone stock!
    I can't see any reason that mount won't work. Granted, it's not sitting on flat surface and it's got the body blocking it a bit, but it'll work fine for most applications. I had a similar mount on my Jeep... I bolted an old tire-bump stop to the body in roughly the same place you've placed yours, and ran a 4ft tuneable firestick. It worked fine. You might never get to 1:1, but 2:1 would be fine.
    I'd re-check the grounds. If you have a multi-meter you can check between the ground at the antenna, the mount, and where you've grounded it on the body.
  13. Apr 7, 2021 at 12:39 PM
    T4R13
    Clarksburg wv
    19 sr5p
    Right. I’m not asking for perfect. Just in a safe range that won’t fry the finals on my radio. I have a multimeter. From the coax going into radio. The threaded portion I have good ground to negetive on battery. No continuity between center pin and threaded portion. And from center pin to antenna Tip I have good continuity
  14. Apr 7, 2021 at 12:52 PM
    T4R13
    Clarksburg wv
    19 sr5p
    Bad bad bad swr
  15. Apr 7, 2021 at 12:55 PM
    jmkulbeth
    Jeffrey (KE5HDB)
    Siloam Springs, AR
    Bone stock!
    Hmmmm. I wonder if the spring is throwing it off. You might try removing it and see if it's influencing your SWR.
  16. Apr 7, 2021 at 12:59 PM
    T4R13
    Clarksburg wv
    19 sr5p
    Also tried without it
  17. Apr 7, 2021 at 1:06 PM
    jmkulbeth
    Jeffrey (KE5HDB)
    Siloam Springs, AR
    Bone stock!
    I'm running out of ideas. I'm guessing you checked the ground between the mount and the body. And there shouldn't be continuity between the base of the antenna above the nylon insulating washer and the mount/body. You might touch base with Firestik - they may have some ideas. I've had good luck with them via email in the past. They have some good suggestions regarding SWR on their website, too. Tech-Docs Index (firestik.com)
  18. Apr 7, 2021 at 2:14 PM
    photo8 New Member
    TRD Off-Road
    It's probably the location so close to the body.
    • Disconnect the cable at both ends and check it with an ohm meter for shots and make sure the PL-259 is properly connected.
    • Sweep the installation with a vector network analyzer (VNA) this will show you where it's resonant and can help you adjust tuning.
    • Consider going to a roof mount NMO mount with Larsen NMO-27 antenna.
  19. Apr 7, 2021 at 2:32 PM
    T4R13
    Clarksburg wv
    19 sr5p
    Thanks
    starting to believe it. When I was originally looking for mounts seemed like this was a popular one. Now that I’ve installed it. I can’t find any info on it
  20. Apr 7, 2021 at 5:34 PM
    T4R13
    Clarksburg wv
    19 sr5p
    At my witts end with it, going to use for a reverse led pod or just take it off all together, don’t even want to look at the thing
  21. Apr 8, 2021 at 6:11 AM
    newlife
    Knoxville TN
    2021 venture 22 JTR
    All of them.
    Have you tried relocating the ground? Maybe take a piece of 14g or whatever size wire really and run it to the frame. It’s a long shot but we did similar testing with the Tacoma until we found a sweet spot behind the camper shell on the rear. I think I ended up running between the tailgate and bumper down to the frame snd bolting in on a bumper bracket snd finally got the swr in a safer range. It wasn’t perfect but it wasn’t in the threes.
    you may have to try different spots but that may work out for you.
  22. Apr 8, 2021 at 8:32 AM
    T4R13
    Clarksburg wv
    19 sr5p
    Tried a couple spots, where did u attach the ground to the bracket? Where it bolted to truck or where the coax meets the bracket
  23. Apr 8, 2021 at 9:04 AM
    newlife
    Knoxville TN
    2021 venture 22 JTR
    All of them.
    On the actual bracket. That made the entire bracket a ground.
  24. Apr 8, 2021 at 9:17 AM
    T4R13
    Clarksburg wv
    19 sr5p
    Sadly I’ve tried that. Heading out for Moab tn. Maby one of the cb shops out there can troubleshoot it for me. Or Maby I’ll run into someone with the same mount
  25. Apr 9, 2021 at 5:21 AM
    newlife
    Knoxville TN
    2021 venture 22 JTR
    All of them.
    Gotcha. Last thing I would check is your wires. Make sure nothing got pinched, nothing is torn or stretched. Truly don’t think at this point it’s the mount. The mount is just a piece of metal there has to be something else that’s causing the issue. It could be mount positioning but I still don’t believe the actual metal mount is the problem.
    and just to make sure you set the mount up correctly make here is from Firesticks website.
    573B15DE-CE84-432E-8C0F-F646BDBFD833.jpg D26B71D9-5973-4F77-8BEA-421694778DC0.jpg
  26. Dec 16, 2021 at 3:53 PM
    peter2772000
    peter2772000 New Member
    Peter
    Montreal/Cape Coral
    2019 TRD Pro
    This ever get resolved?
  27. Dec 16, 2021 at 4:01 PM
    Henry J
    Sacramento Ca
    Following
  28. Dec 25, 2021 at 11:18 AM
    Gstick
    Gstick New Member
    19' TRD OFF ROAD
    I was considering going with this mount, but I think that I'll just use a Stryker A10 magnetic antenna.
