Radio has no power
Discussion in 'Audio & Video' started by JAB6791, Oct 9, 2022.
  1. Oct 9, 2022 at 2:41 PM
    JAB6791
    JAB6791 [OP] New Member
    2019 Limited
    My wife’s 2019 limited’s radio has no power. I checked the radio 1 fuse and amp fuse in the box under the hood, both intact. The other fuse box underneath the dash next to the parking brake has no fuses concerning the radio, as per the fuse diagram. The back up camera still displays on the screen. The cd currently installed won’t eject. So no power to the unit. Anyone know if there is a fuse behind the unit itself? Any and all help will be appreciated! Thanks!
    4RunrDoc likes this.
  2. Oct 17, 2022 at 3:34 PM
    dolbytone
    dolbytone New Member
    2020 TRD Off Road
    Switched power is probably on a different circuit. Dome light working? 12VDC power socket work?
  3. Oct 20, 2022 at 2:07 PM
    aroyalsfan
    aroyalsfan The Owner
    Kansas City
    Did you press the volume knob?
    dolbytone likes this.
  4. Oct 20, 2022 at 3:12 PM
    This happened on the Corolla sadly, so we updated to the Soundstream. Which my wife hates because didn’t get hands free model.
  5. Jul 16, 2023 at 3:04 PM
    16trail
    16trail New Member
    Did you find a solution to this problem? My radio is doing the same exact thing. 2016 Trail, non JBL. Thanks
  6. Jul 17, 2023 at 11:18 AM
    LadeDruck
    LadeDruck New Member
    2022 Pearl Effect White Ltd.
    I would check with the amp.
    behind the passenger side panel the jbl system amp is located, if this isn’t running neither will the radio.
    mid you pop in there you’ll know real fast if the circuit is dead or if the head unit is an isolated issue. Also much easier to use a multimeter to diagnose from that location if you don’t want to pull the radio.
  7. Jul 17, 2023 at 1:34 PM
    16trail
    16trail New Member
    Thanks for the information, but my unit is non JBL with nav. Fuses are good and voltage checks out fine at connectors behind radio. I found a used non jbl unit to test and it does the same thing.
  8. Jul 19, 2023 at 1:08 PM
    4RunrDoc
    4RunrDoc New Member
    Nikki
    4Runner TRD Premium
    This is currently happening in my 2017 TRD premium. It was working yesterday just fine then all of a sudden when I started my vehicle it didn't come on but the reverse camera is working so there's power to the screen. I've already tried all of the obvious buttons I've checked all of the fuses that are to be represented for audio or communication or any of those and still no luck.
  9. Jul 19, 2023 at 1:37 PM
    dolbytone
    2020 TRD Off Road
    The stereo will not come on without this fuse:
  10. Jul 19, 2023 at 2:17 PM
    4RunrDoc
    4RunrDoc New Member
    Nikki
    4Runner TRD Premium
    This is what my panel looks like
  11. Jul 19, 2023 at 2:20 PM
    4RunrDoc
    4RunrDoc New Member
    Nikki
    4Runner TRD Premium
    I checked 30a, 25a, 7.5a
    Of the ones checked, lone had any visiable issues
    Any other suggestions?
  12. Jul 22, 2023 at 1:23 PM
    16trail
    16trail New Member
    Sorry, no solution yet. I’ll post when I figure it out…
  13. Aug 25, 2023 at 12:38 PM
    16trail
    16trail New Member
    Turned out to be the radio. The factory replacement that I found on eBay was also failed, but seller sent me another unit and it’s working.
