Radar Detector? with Dongar Power Adapter
Discussion in '5th Gen 4Runners (2010-2024)' started by 1SilverRunner, May 20, 2024.
  1. May 20, 2024 at 2:26 PM
    1SilverRunner
    1SilverRunner [OP] My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid (modified) RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ Apache CF220 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Lasfit LED Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    So I'm switching from the Garmin dash cam to a FitcamX for better picture quality.
    Because I already have the Dongar adapter installed I was considering adding a radar detector there...
    My experience with radar detectors is they are very annoying with false alarms.
    Have radar detectors gotten better in the last 10 years? Less false alarms, better detection? Is it even worth the price or should I just continue being extra vigilant when pushing the speed limit on large highways.
    In Texas 75mph highways are met by normal traffic cruising at 80-90... The nail that sticks out gets hammered, and my 4R definitely sticks out.
    What's your two cents on radar detectors? Are they worth having, or should I just remove the adapter.
    Also, has anyone used the dongar adapter for something other than a dash camera? Any reason to leave it installed?
  2. May 20, 2024 at 2:31 PM
    There was a guy who posted recently about this exact situation. He wanted to run his dash cam and radar at the same time. Dongar does make a split pigtail for it. My opinion (which is worthless by the way), radar detectors are pointless. I'm sure they've gotten better, but if you're keeping your eyes open and paying attention then you won't need one.
    My truck really stands out, so did my truck before that. I never had to worry about getting pulled over for speeding. I do drive like a grandpa though. I'm the ass-hat going 60 or 65MPH. I'm not important enough to break the speed limit just to get to where I'm going.
    EDIT, here's the thread: https://www.4runners.com/threads/radar-detector-camera-hardwiring.38550/#post-592973
  3. May 20, 2024 at 2:44 PM
    Grandpawmoses
    Grandpawmoses Dirty Old Man
    David
    2024 4R TRD Pro
    Too poor to buy anything now
    Most radar detectors operate on 12 volts. I'm not sure about the Dongar's output.
    Today's radar detectors are "smart" in that they learn false signals, have red light locations, but aren't much help with advance notice of laser radar. That's where the Waze app shines.
    Radar detectors are best around town when the traffic cops constantly move their locations.
    1SilverRunner[OP] likes this.
  4. May 20, 2024 at 2:49 PM
    1SilverRunner
    Tejas
    Ahhh is the Dongar Adapter not a 12v connection? I was under the assumption that it was.
  5. May 20, 2024 at 3:45 PM
    Grandpawmoses
    David
    2024 4R TRD Pro
    All the Dongar's I've seen online just have a USB output.
    Quoting from an add for them.
    • OPTIMAL PERFORMANCE: This dash cam adapter is recommended for USB-powered devices drawing less than 2A at 5V to ensure efficient heat management. If you're using a USB-C powered device, please ensure compatibility by checking the voltage specifications beforehand.
    • COMPATIBILITY LIMITATIONS: Please note that this adapter is not compatible with devices requiring 12V or those powered by a barrel jack or RJ11 connector. This adapter is not compatible with digital mirrors or mirrors with backup cameras.
    There may be radar detectors that do work on 5 volts though.
  6. May 20, 2024 at 4:16 PM
  7. May 27, 2024 at 2:42 PM
    TimGinCentralNJ
    TimGinCentralNJ New Member
    Tim
    '24 Limited in Classic Silver
    TRD Pro rims w/265/70-17 Toyo OC AT3s
    I'm sorry....whose 4Runner moves fast enough to break the speed limit? Certainly not mine!
    CalcityRenegade likes this.
  8. May 27, 2024 at 3:17 PM
    CalcityRenegade
    CalcityRenegade New Member
    Matt
    2023 T4R ORP KDSS
    If anything were most likely at risk of getting a ticket for impeding traffic :bananadead:
  9. May 27, 2024 at 5:54 PM
    SVMTRCSR
    SVMTRCSR New Member
    318 curves in 11 miles
    2021 4Runner SR5 2WD
    Go Trump!
    I've used an Adaptiv motorcycle radar detector on my motorcycles and in my 4Runner for the last 10 years. It has saved me numerous times in the small towns and backroads in my area, like more times that I can remember. Freeways, it false alarms too much from semi's and other stuff, but I hardly travel on the freeways anymore and if I do, I just set my cruise to 72 and let the madness go by.
    Again, I would not go without one, at least weekly I'll going down a county road or state route, and it goes off, I slow to limit and there will be a sheriff or THP coming at me or sitting on the side. It was well worth the $500 for detectors and accessories.
  10. May 27, 2024 at 9:02 PM
    Take it to a good mechanic
  11. May 28, 2024 at 5:29 AM
    Grandpawmoses
    David
    2024 4R TRD Pro
    You guys must not have those pesky speed traps just waiting for someone to break 30 mph in a 25 mph zone.
  12. May 28, 2024 at 6:22 AM
    joshdub
    joshdub New Member
    2020 TRD ORP
    I guess I'll just throw away my radar detector because it's useless. I'd be much better off collecting the tickets from all the speed traps it has warned me of.
    Ripper238 likes this.
  13. May 28, 2024 at 7:20 AM
    Ripper238
    Ripper238 New Member
    2019 TRD OR
    I would highly suggest running a Radar Detector ether way. Situational awareness is priceless and the abilities of radar detectors are quite amazing now with smartphone integration and false filtering.
    But you need to pick wisely because there there is a lot of junk out there. I'm a V1 fan and have it fully integrated into my countermeasures and smartphone. Some other good stand alone models are Radenso, Escort and Unidin, but the V1 IMO is far superior with its smartphone integration, if willing.
    I also run LIDAR shiters for that extra edge.
    If you want to deep dive into the countermeasure hobby I made a forum we sold a while back for this kind of thing. RDF
    I would have been toast without a radar detector:
  14. May 29, 2024 at 5:57 AM
    GoatJerky
    GoatJerky New Member
    Sully
    i haven't run a radar detector in almost 20 years.
    Waze is FAR more efficient at letting you know where 90% of speed traps are. No false alarms like a radar detector going off every time you pass a grocery store with automatic doors, and with many departments moving to laser, it doesn't really matter. The second they hit the button, they have you. No delay like raday.
  15. May 30, 2024 at 12:13 PM
    ShakyDog
    ShakyDog New Member
    Steve
    2021 4R TRD ORP Nautical Blue
    I run my V1 in my 07 Z4, but it is almost too annoying anymore to be affective. I have all but tuned out the X and K band alert. The problem is we still have LE here in Missouri that run older K. I will say the thing still saves me money. I tend to not look at the speedometer in my Z4...
    Steve
  16. May 30, 2024 at 12:17 PM
    New detectors have auto mute for false alarm. It will show on the screen that its auto mute but not give annoying sound.
  17. May 30, 2024 at 1:10 PM
    Grandpawmoses
    David
    2024 4R TRD Pro
    My 10 year old Escort 360 Max (which has GPS) has a learning feature that if you pass by a false alarm three times, it blocks that false alarm location in it's data base with red light cameras. I'm intrigued by the new Redline 360 that receives crowd-sourced alerts for protection something like what Waze offers.
  18. May 30, 2024 at 1:14 PM
    joshdub
    joshdub New Member
    2020 TRD ORP
    Waze is great and a good companion to a radar detector. However Waze also has plenty of false alarms where an officer is marked but is no longer there. Additionally I have experienced many instances where my detector picks up KA band and waze shows nothing, only for there to be a speed trap a mile up the road.
    TimGinCentralNJ likes this.
  19. May 31, 2024 at 8:19 AM
    TimGinCentralNJ
    Tim
    You've got a good point re: Waze. It also just occurred to me...if you are the only one (or one of the only ones) on the road, there are no other drivers out there ahead of you to tag the police vehicle that's hidden 5 miles up ahead. Depending on the type of radar being used, that is where the radar detector could save your biscuits.
    TimG
  20. May 31, 2024 at 1:06 PM
    Ripper238
    2019 TRD OR
    Waze is a nice enhancement but wont save you from moving radar or a hidden LEO. But you have to go top tier radar detector for the false filtering. A top tier unit has no delay and tons of range too.
    Upgrade and use one of the apps. My V1 is super quiet and has incredible range when i run the app. It's well worth the upgrade. I have saved tons of $$ with my V1 over the years, even when it was noisy.
  21. Sep 8, 2024 at 10:59 AM
    mostfrantic
    mostfrantic New Member
    I run both Waze and Radar detectors constantly. Why? I speed. They work best together.
  22. Sep 15, 2024 at 10:17 AM
    TroutMan
    TroutMan New Member
    @Ripper238 - can you say a bit more about the LIDAR setup you have? And I'm interested in what this means: "have it fully integrated into my countermeasures and smartphone" ... I get the smartphone point, but what else do you have it integrated into?
  23. Sep 15, 2024 at 11:28 AM
    Grandpawmoses
    David
    2024 4R TRD Pro
    Lidar is a method for determining ranges by targeting an object or a surface with a laser and measuring the time for the reflected light to return to the receiver. Lidar may operate in a fixed direction or it may scan multiple directions, in which case it is known as lidar scanning or 3D laser scanning, a special combination of 3-D scanning and laser scanning.
    Here's a very article:
    https://www.vortexradar.com/2022/06/testing-best-police-laser-jammers-2022/
  24. Sep 15, 2024 at 11:48 AM
    Grandpawmoses
    David
    2024 4R TRD Pro
    Also....
    It gives you time to quickly slow down as needed, disable your jammers, and let him get a reading off of your car doing the speed limit.
