Questions about shifting between 2WD and 4WD
Discussion in '5th Gen 4Runners (2010-2024)' started by Doug11401, Dec 18, 2020.
  1. Dec 18, 2020 at 6:03 PM
    Doug11401
    Doug11401 [OP] New Member
    2020 4Runner TRD Off Road Premium
    I like my 2020 4Runner a lot, but I have a few questions about it:
    - Why is there so much vibration when I try to shift the transfer case lever from the H4 position to Neutral and then to L4? Is this normal? I feel like the amount of vibration that's occurring isn't good for the tranny.
    - Is it easier on the transmission and transfer case if I shift from H2 to H4 while stopped and in neutral, as opposed to doing this while moving and in gear? Or does it make no difference?
    - Can you/should you shift from H2 to H4 while in Park?
    Thanks in advance for any comments/recommendations....
  2. Dec 18, 2020 at 6:08 PM
    You MUST be stopped and in neutral to shift from 4Hi to 4Lo! It's in the manual and on the visor I believe.
    Low range is only for low speed operation. It should never be used above 10 MPH or so.
  3. Dec 18, 2020 at 6:09 PM
    4Runner fun
    Ryan
    Nebraska
    7385 and Thatbassguy like this.
  4. Dec 19, 2020 at 4:18 AM
    DRobs
    DRobs New Member
    Dan
    Missouri Ozarks
    2019 TRD OR - MGM
    Welcome aboard.
    7385, Taco Supremo and Thatbassguy like this.
  5. Dec 19, 2020 at 5:28 AM
    welcome
    7385 likes this.
  6. Dec 19, 2020 at 3:52 PM
    Welcome from Wisconsin! On slippery snow covered roads I just let off the throttle while putting it in 4Hi, then go down the road at a comfortable speed, I've never hurt a 4wd system traveling on slippery surfaces even at say 45-50mph. 4LO, that's a different story, trans in neutral, stopped of course and don't travel above 10-15 mph, with small incremental turning.
    glwood54, ruiz4251, DRobs and 3 others like this.
  7. Dec 20, 2020 at 7:30 AM
    Doug11401
    Yes, I read the manual and understand that you can shift between H2 and H4 while moving, but you can't/shouldn't be moving when you shift between the H4 and L4.
    BTW, my next door neighbor is a bass fisherman, too. It's practically all he thinks about, and he used to do it competitively. I live in Vancouver, WA.
  8. Dec 20, 2020 at 7:33 AM
    Doug11401
    That thread was helpful. Thanks! I'm relieved to know for sure that the grinding when shifting between Neutral and L2 is normal. And I plan to shift more vigorously -- as in "racking a shotgun", like one of the contributors to that thread suggested.
    4Runner fun[QUOTED] likes this.
  9. Dec 20, 2020 at 7:37 AM
    Doug11401
    Thanks for the welcomes! This is a very helpful site.
    I'm still curious about what the answers are to my second and third questions. But you've answered the most important one (about whether the heavy vibration between Neutral and L2 is normal).
    Toy4X4 and 4Runner fun like this.
  10. Dec 20, 2020 at 7:39 AM
    So, you were getting a vibration while shifting from 4hi to 4lo while stopped and in neutral?
    I haven't fished as much the last few years, but I was pretty nutso for a long time!
    This is true. I compare it to shifting an outboard motor. Don't be shy with it. :)
  11. Dec 21, 2020 at 10:14 PM
    tundradan
    tundradan New Member
    2013 Silver 4Runner Limited
    Stock....for now
    Welcome from Beaverton!
  12. Dec 22, 2020 at 5:46 AM
    EffinNewGuy
    EffinNewGuy Completely clueless
    Southeast
    Absolutely nothing
    Responses to your original questions.
    - Why is there so much vibration when I try to shift the transfer case lever from the H4 position to Neutral and then to L4? Is this normal? I feel like the amount of vibration that's occurring isn't good for the tranny. - You're being too gentle/easy during shifting. Stop, put Transmission in Neutral, shift from H4 to L4 with authority. You don't have to try and break off the lever, but don't treat it gently either.
    - Is it easier on the transmission and transfer case if I shift from H2 to H4 while stopped and in neutral, as opposed to doing this while moving and in gear? Or does it make no difference? - I can't really see an issue shifting transfer case from H2 to H4 while stopped and in neutral, but this was designed to go from H2 to H4 while on the move, under 50 MPH. Just follow the manual, you can't go wrong.
    - Can you/should you shift from H2 to H4 while in Park? - I would not advise doing this. I've seen individuals get their transfer case or transmission 'hung up' trying to do this. Again, follow the manual.
