Questions about 4 Wheel drive on my 4th gen 2006 SR5
Discussion in '4th Gen 4Runners (2003-2009)' started by drlngus, Mar 27, 2023.
  1. Mar 27, 2023 at 7:05 PM
    drlngus
    drlngus [OP] New Member
    265/70/17 Tires, 1" Daystar Leveling Kit
    Hello All,
    I currently just got a 2006 4th gen 4x4 SR5 and have some questions on using the 4 wheel modes. I was originally told by a few people that you shouldn't use 4H wheel settings on Dry Ground, Use it in slippery, snow, mud, sand, grass applications only. But reading the manual, it says you can use the 4H wheel selection on ALL types of surfaces and change from 2 wheel to 4H under the speed of 65 miles per hour. Please help me to better understand.
  2. Mar 28, 2023 at 4:11 PM
    Libagui
    Libagui New Member
    Librado
    2006 Silver 4runner limited.
    If you have the center differential lock bottom you can run on 4hi on dry pavement unless you lock the center differential. That is one of the things I like the most about 2003-2009 models.
    drlngus[OP], Curt56 and kmeeg like this.
  3. Mar 28, 2023 at 4:23 PM
    kmeeg LionRunner
    As @Libagui mentioned you can run 4H with center diff unlocked on dry pavement.
    IMO the best way you make use of the multi-mode 4wd system is use 2wd on dry pavement. Use 4H with center diff unlocked in wet and snow conditions on pavement. If that's not enough for deep snow then turn on the center diff to lock 50:50 split.
    "I was originally told by a few people that you shouldn't use 4H wheel settings on Dry Ground" This is valid for part-time 4wd without center diff. I know one bugger kept arguing on this on a post when I talk about the 4th gen system. LoL.
    drlngus[OP], Curt56 and Libagui like this.
  4. Mar 28, 2023 at 4:29 PM
    Libagui
    Libagui New Member
    Librado
    Correct, most people with 4WD don't understand this since this feature is very rare. We have AWD or 4WD with the push of a bottom.
    kmeeg[QUOTED], drlngus[OP] and Curt56 like this.
  5. Mar 28, 2023 at 5:57 PM
    drlngus
    Thank You for the clarification
  6. Mar 28, 2023 at 8:21 PM
    GreatWhitePig
    GreatWhitePig New Member
    I drive mine in 4HI once a month around town. Then I find a dirt road and throw her in 4LO for a little while just to keep the transfer case actuator from seizing.
    drlngus[OP] and kmeeg like this.
  7. Apr 2, 2023 at 8:53 AM
    Vegg8
    Vegg8 New Member
    Brenn
    2014 4runner sr5, 2007 4runner sr5
    I have a 2007 and 2014 4runner. My 2007 i run 4hi most the winter. Its awd. If I want true 4wd, I lock my center diff. In 4hi I can drive circles on dry pavement without any binding. Don't do that if center diff is locked. It will bind, make noises and eventually break something. My 2014 4runner is 2wd or 4wd with center diff locked. I like my 2007 4wd settings better.
    GreatWhitePig and drlngus[OP] like this.
  8. Apr 2, 2023 at 10:06 AM
    Vegg8
    Vegg8 New Member
    Brenn
    I have driven 70mph plus for hours with both cars center diff locked. North dakota winters... No issues.
  9. Apr 4, 2023 at 2:19 PM
    GreatWhitePig
    70 in 4LO is the way!
    This is a joke obviously.
    drlngus[OP] likes this.
