Question for those who don't have running boards
Discussion in '5th Gen 4Runners (2010-2024)' started by Pavo, Aug 19, 2022.
  1. Aug 19, 2022 at 5:47 AM
    Pavo
    Pavo [OP] New Member
    I took my friends running boards off and replaced the bolts back on, I was wondering if you guys without the running boards have the same bolts on there from the factory or if there's the rubber grommet plugs in there, if someone could post a pic that would be great thanks
  2. Aug 19, 2022 at 6:25 AM
    Deuxdiesel
    Deuxdiesel New Member
    SE MI
    '18 SR5P
    There is nothing wrong with using the bolts. Put a dab of anti-seize on the threads and put them back in.
    Toy4X4, Stoney Ranger and Slopemaster like this.
  3. Aug 19, 2022 at 7:06 AM
    ^ agree,
    Keep the holes filled somehow.
    Toy4X4 and BearBio like this.
  4. Aug 19, 2022 at 7:13 AM
    Pavo
    True but I would like to see how it comes from the factory without the running boards
  5. Aug 19, 2022 at 7:23 AM
    LuLu
    LuLu New Member
    Utopia
    2022 TRD Sport
    It doesn't come pre-drilled with the holes.
    That's what the service advisor told me before mine was installed.
  6. Aug 19, 2022 at 7:30 AM
    Pavo
    I would be suprised if they drilled holes at the port but I guess we will find out when someone peeks under their non running board optioned 4runner and verifies
  7. Aug 19, 2022 at 7:51 AM
    2ndGen22re
    CR
    Carson Valley, NV
    1990 22RE & 22 AG ORP KDSS
    No drilling. They are threaded inserts spot welded behind the sheet metal, just took mine off.
  8. Aug 19, 2022 at 7:55 AM
    Yep, asked my dealer about it and he said they come with non structural bolts in holes that get replaced with better bolts if running boards get installed.
    Toy4X4 and Pavo[OP] like this.
  9. Aug 19, 2022 at 8:20 AM
    BgBmBoo
    BgBmBoo New Member
    Kansas
    Mine did not come with running boards. Just checked and there are two bolts in the holes. I didn't take them out to check quality.
  10. Aug 19, 2022 at 8:20 AM
    They come with bolts from factory.
    Toy4X4 and Pavo[QUOTED][OP] like this.
  11. Aug 19, 2022 at 8:42 AM
    Pavo
    Thanks!
    kmeeg[QUOTED] likes this.
  12. Aug 19, 2022 at 9:44 AM
    nickjo
    nickjo '21 Lunar Rock TRD Pro
    WA state
    I've got a follow up question for folks following this thread. I recently took off my factory running boards in prep for installing C4 sliders next month. During my shoddy deinstallation process, a bolt got stripped / stuck and so I ended up ripping open a larger, jagged (quarter sized) hole in the sheet metal to get it out.
    Any suggestions / best practices for plugging this hole? Soldering seems like a possibility.
  13. Aug 19, 2022 at 10:48 AM
    Considering where these are, I would think a painted piece of sheet metal applied with JB Weld would be more than sufficient. If you wanted to get really fancy, you could put a nutsert with the same threads it had before you ripped it out in the new piece of sheet metal. That way, if anyone down the road wanted running boards again, the bolt hole would be there.
    nickjo[QUOTED] likes this.
  14. Aug 19, 2022 at 10:48 AM
    That’s not the way I would go. Heat might compromise the paint and increase the risk of corrosion. I’d fill the hole with epoxy putty or silicone sealant or something like that.
    ETA: GL’s idea is better than mine!
  15. Aug 19, 2022 at 11:09 AM
    BearBio
    BearBio New Member
    Greg
    2019, Dark Blue SR5
    Roof rack, side bars
    My 2019 SR5 had holes already when I put the steps on.
    Pavo[QUOTED][OP] likes this.
  16. Aug 19, 2022 at 6:55 PM
    SCgman
    SCgman New Member
    Columbia SC
    2022 4runner SR5 4wd
    Front plate bracket install Step hitch insert install Cargo area Pet barrier Protective seat covers Front seats Yakima roof rack- detachable Rear molle storage panels w/ Connecting shelf
    Same for my "22.....I had to remove 6 filler bolts on each side to install my side bars.
    BearBio[QUOTED] likes this.
  17. Aug 20, 2022 at 3:13 AM
    peter2772000
    peter2772000 New Member
    Peter
    Montreal/Cape Coral
    2019 TRD Pro
    My personal life mission LOL
  18. Aug 20, 2022 at 8:04 AM
    2ndGen22re
    CR
    Carson Valley, NV
    JB weld.
  19. Aug 20, 2022 at 9:09 AM
    BearBio
    BearBio New Member
    Greg
    2019, Dark Blue SR5
    My concern with JB weld or soldering is the permanence. What if you wanted to change back sometime in the future? You'd have to drill new holes or ream out the JB Weld/solder.
  20. Aug 20, 2022 at 9:25 AM
    See post #13.
