Question for Roof Rack Cross Bars
Discussion in '5th Gen 4Runners (2010-2024)' started by TRDTyler, Apr 1, 2026.
  1. Apr 1, 2026 at 5:46 AM
    TRDTyler
    TRDTyler [OP] New Member
    2018 TRD Pro/2019 SR5 Premium
    LFD Cross Bars:
    I’m either going to get the standard steel bundle or the aluminum extrusion bundle.
    The steel has open slots that you bolt up from underneath whereas the aluminum has the track allowing for the t-nuts and such.
    wondering if you all have a preference of one over the other?
  2. Apr 1, 2026 at 5:50 AM
    brodeyo
    brodeyo New Member
    Alumn lighter, but you can use any size bolt on the steel. I'm all for universal.
    TRDTyler[OP] likes this.
  3. Apr 1, 2026 at 10:12 AM
    22 ORP
    I have a question. It looks like the way that the end pieces attach to the steel or aluminum bars is different. Do the aluminum bars attach just with 2 little bolts through the ends, bearing the weight in shear?
  4. Apr 1, 2026 at 10:24 AM
    pursuitofnow
    pursuitofnow New Member
    2022 Lunar Rock ORP
    Modifications are always evolving and listed in my profile. --Exterior-- Fox DSC 2.5 Camburg billet UCA Dobinsons 327 rear springs Dirt King Fabrication 1" diff drop kit Overland Custom Designs forged sway bar links Durobumps front and rear DR.KDSS bolt on trackbar correction kit Volk Racing TE37XT -10 BFG KO2 285/70-17 (Load E) 38psi cold Powerbrake D-Line Rotor & Pad Kit (front & rear) Westcott no kick DOM TIG RCI aluminum full skids (with cat guard) ARK mudflap delete Black lower valance front & rear Xpel xr plus ceramic tint, 80 windshield, 50 all other windows Diode Dynamics SS3 Fog lights (Pro, yellow) --Interior-- Meso interior door handle covers Meso interior lights AJT climate & radio knobs AJT V3 shift knobs Seat gap filler Center console and glove box organizer Desert Does It front seat jackers Taco Vinyl steering wheel overlay Cali Raised molle panels and overhead tray H3R fire extinguisher My Medic first aid --Accessories-- Rigd RambleSwing Pro Rigd Ultratable Iceco VL35ProS fridge Dometic GO Hydration water jug Dometic Recon 360 faucet Flameking 5lb propane tank Rotopax 3 gallaon gas (x2)
    Yes, but isn't that how most cross bars on full size aftermarket rack attach (two bolts through the side plate into the crossbar)?
  5. Apr 1, 2026 at 10:55 AM
    22 ORP
    On an aftermarket flat-top roof rack maybe. I’ve never seen one up close. But with the steel version of the LFD bars it looks like the cross bars and the end plate are all one piece.
    Top: steel. Bottom: aluminum.
  6. Apr 1, 2026 at 10:58 AM
    Beachguy
    2024 TRP ORP
    I had the steel ones on my ‘21 and they were fine.
  7. Apr 1, 2026 at 11:45 AM
    pursuitofnow
    2022 Lunar Rock ORP
    Correct, I understood what you were saying.
  8. Apr 1, 2026 at 12:17 PM
    RWKJR77
    RWKJR77 New Member
    Rob
    I have the steel ones and really like them. I also upgraded my rook rails to their 3/4's and have been very happy.
  9. Apr 1, 2026 at 12:55 PM
    TRDTyler
    Apparently under that end piece for the aluminum bar, there is a 90 degree lip that it sits on as well from reading a bit more info on LFD’s website.
    Captain Spalding likes this.
  10. Apr 1, 2026 at 1:12 PM
    jasonmcelroy
    Jason
    San Jose, CA
    2021 Grey Trail
    Don't know where you're located but I have a set of LFD steel powdercoated bars I no longer use. Make an offer for pickup. I think shipping would be prohibitively expensive given the weight. SF Bay Area.
    Took them off because I switched to a full length roof rack to increase packing capacity.
    Honestly the extruded aluminum channel cross bars are less convenient for me than the slotted steel ones, but the money is spent and I'm making do. I do appreciate the increased mounting space.
    Jason
  11. Apr 1, 2026 at 1:16 PM
    TRDTyler
    I do greatly appreciate it but I am all the way out in TN so I think you’re right that shipping would probably be pretty significant, unfortunately.
    I do also appreciate your input in regards to the aluminum extrusion though, makes me probably think the steel might be a better option for the time being - especially since that is the one you all have and there have been no major issues with it.
    jasonmcelroy[QUOTED] likes this.
  12. Apr 1, 2026 at 8:22 PM
    MellowCat
    MellowCat New Member
    Scott
    Cincinnat, Ohio
    2021 4Runner TRD Offroad Premium
    LED light upgrade, TRD skid plate, Rock rails (stock TRD), LFD roof rails, Rival connector and transfer case skid plates.
    I went for the Alum cross bars as they use salt liberally around here :) I can't imagine the mounting failing, way stronger than the factory bars the cross bars mount too. IMG_0126.jpg
    pursuitofnow, TRDTyler[OP] and vthoky like this.
  13. Apr 2, 2026 at 4:51 AM
    I really like the idea of the extruded bars (and I have some 2x1 extrusion in the shop)... are they noisy at all?
  14. Apr 2, 2026 at 6:57 AM
    TRDTyler
    Very curious about this as well! How is the noise?
    Also, how easy is it to mount and unmount things in your experience?
  15. Apr 2, 2026 at 8:57 AM
    QuillPig
    QuillPig New Member
    I have the aluminum ones. I've got the fairing in the front, and noise is negligible, barely different than the factory bars. They are sturdy and have held up to every load I've put on them.
    I've had a heck of a time getting the right t-nuts to fit the tracks. But that's probably more on me not paying attention and buying the wrong thing.
  16. Apr 2, 2026 at 9:46 AM
    MellowCat
    Scott
    Cincinnat, Ohio
    I have the fairing, very quiet for me. The Toyos hum much more :)
    vthoky and TRDTyler[OP] like this.
  17. Apr 2, 2026 at 10:12 AM
    I have some extrusion on hand, and I can machine my own brackets. After that, I wouldn't have a problem springing for the OE fairing. ;)
    MellowCat likes this.
  18. Apr 2, 2026 at 10:12 AM
    TRDTyler
    Thanks for that!
    Those with the aluminum ones too, is there any other downside at all really to getting those over the steel ones?
    My thought is just to run 1/4 20 carriage bolts in the rails to mount things and not necessarily worry with the t-nuts for the things I would be mounting but maybe that’s easier said than done, I’m not sure.
  19. Apr 2, 2026 at 10:19 AM
    I'm looking at it from the viewpoint opposite of TRDTyler: I'm thinking aluminum from the non-rust aspect, and I think the extrusion could be more versatile in terms of future mounting options. "Hammer-style" or roll-in T-nuts are The Stuff.
    I'll admit that I'm probably biased -- I've built a lot of things from those extrusions over my career, and my steelworking skills kinda stink. :)
  20. Apr 2, 2026 at 10:24 AM
    TRDTyler
    Makes total sense!
    I am just somewhat torn between which option is better for ease of mounting and which one would satisfy my needs better. I feel like they both are solid options.
    To be honest: I like the lower price and utility of the steel, but I greatly appreciate the full t-slots and rust resistant construction of the aluminum.
    Also for what it’s worth, the aluminum appears to be slightly wider and maybe ever so slightly taller than the steel too, but I could be wrong - I am basing it solely off internet pics so take that as you will
  21. Apr 2, 2026 at 10:27 AM
    QuillPig
    QuillPig New Member
    I went with aluminum because I'm in the Northeast and everything steel rusts and looks terrible after a couple of winters. I also liked the lighter weight, and didn't see any strength advantage to the steel, given that these sit on the factory rails, which will give out well before either style of bar does.
    TRDTyler[QUOTED][OP] likes this.
  22. Apr 2, 2026 at 10:29 AM
    I don't know about any width difference, but with the aluminum bars you could make your own brackets and give the extrusions as much "height above the rails" as you want (if you needed additional height, of course).
  23. Apr 2, 2026 at 10:38 AM
    TRDTyler
    I am in the Southeast so not anything major but they do salt our roads when inclement weather is anticipated - and I hate it o_O
    But regardless, do you happen to have any pics of your set up by chance?
    If not no big deal just figured I would ask just because I like seeing other set ups.
  24. Apr 2, 2026 at 10:55 AM
    water
    water New Member
    brian
    Portland, OR
    2019 4runner
    Yes
    I use these M8 T-nuts for the slots on the steel rack. Makes for easy install and removal. They fit through the slot sideways and rotate into the locking position. So no need to fully remove the nut!
  25. Apr 2, 2026 at 10:59 AM
    BLKNBLU
    BLKNBLU New Member
    2019 Nautical Blue OR
    I have the LFD extruded out in the shed waiting to go on the truck. I am replacing some Victory metal crossbars that are very similar to the LFD although the LFDs look a little taller. The Victory's are very nice but I find attaching hardware from underneath a real PITA. The LFD may be better if they are in fact taller. If you are going "set it and forget it" with your hardware it probably isn't a big deal either way. My needs require moving things around from time to time though.
  26. Apr 2, 2026 at 11:02 AM
    BLKNBLU
    BLKNBLU New Member
    Pics of the LFD assembly:
  27. Apr 2, 2026 at 11:03 AM
    BLKNBLU
    BLKNBLU New Member
    That's a pretty good idea.
  28. Apr 2, 2026 at 11:06 AM
    TRDTyler
    Thanks for the pics! That’s super helpful showing angles that the website doesn’t too so everyone can see exactly how they are put together.
  29. Apr 2, 2026 at 11:29 AM
    Per the LFD website, SS brackets & mounting hardware, with extruded aluminum cross bars, correct?
  30. Apr 2, 2026 at 11:40 AM
    BLKNBLU
    BLKNBLU New Member
    I think so. I'll check when I get home. I saw this thread this morning and popped out to grab these pics...in the shed...in the dark...in a hurry to leave for work. I haven't actually laid eyes on these since January-ish so I'll get back on this.
