Question About Potential Damage After Wheeling
Discussion in '4th Gen 4Runners (2003-2009)' started by Tobinhoss, Dec 31, 2023.
  1. Dec 31, 2023 at 12:59 PM
    Tobinhoss
    Tobinhoss [OP] New Member
    Hey there guys, I’ve got a 2006 4Runner that I just recently took out to the hills. The truck is lifted 2” with some 33s on it. We’ve gotten a lot of rain in NorCal so I decided I would hit some mud, and while doing so I smacked a bank while out there. Not much seemed wrong and my tire and wheel were just fine and there was no damage to either. It was a pretty light smack at maybe 5-10 mph. I’m just a little worried that something might be wrong as when the wheel is held straight on the car veers slightly left on the highway. The wheel itself doesn’t pull when let go but I’m still a little worried. What are some failure points that these trucks have before bending frames? I’ve looked all I could and have seen no damage but what is the chance I’ve tweaked my frame? Thanks guys!
  2. Dec 31, 2023 at 5:21 PM
    xtremewlr
    xtremewlr New Member
    Todd
    Tucson, AZ
    2003 4Runner V8 Limited 4WD
    Lots with more in the works
    Probably just knocked the alignment out of whack and need to get it aligned again. Not uncommon on these trucks and is also an issue with the 2nd gen + Tacomas, which share the same front suspension. I doubt there is any actual damage that you need to worry about.
  3. Dec 31, 2023 at 5:39 PM
    The alignment cam bolts are round, and there's slop in the frame holes. The front cams are directly under the steering rack. Any little bump will throw off the toe. Get an alignment done and you're good, until the next trail run :laughing:
    Remember, mud kills your truck slowly, not right away.
  4. Dec 31, 2023 at 6:50 PM
    Not unless you spend 12 hours cleaning out the frame and you replace all the things that break or wear out! Lol;)
  5. Dec 31, 2023 at 7:17 PM
    As mentioned already, get the alignment checked and don't panic.
    Also, be glad you have a Toyota. I have a friend with a Ranger and he bent a tie rod doing shit I do all the time. :D
  6. Dec 31, 2023 at 7:56 PM
    "Smacked a bank"
  7. Dec 31, 2023 at 8:07 PM
    backpacker
    backpacker New Member
    2023 TRD ORP
    Just how he planned it, I'm sure. :rolleyes:
  8. Dec 31, 2023 at 9:53 PM
    He definitely seemed to have supreme confidence in his own skills, considering how it could have ended lol. Fully sent!
  9. Jan 1, 2024 at 8:06 AM
    ^You know what's worse than rolling your vehicle on its roof? Rolling your vehicle on its roof in a mud pit. All the mud rushing in at head level while you try to unbuckle your seatbelt. :laughing:
  10. Jan 1, 2024 at 9:58 AM
    Exactly, and only slightly worse is when the mud comes up to waist level, but your head is below your waist, and the doors don’t open because you’re in a mud bowl. No thanks…gives me goosebumps just thinking about it.
