Purchased new rims and tires front end wandering?
Discussion in '5th Gen 4Runners (2010-2024)' started by CHIEF_BLK_NIPS, Nov 27, 2022.
  1. Nov 27, 2022 at 11:41 AM
    CHIEF_BLK_NIPS
    CHIEF_BLK_NIPS [OP] New Member
    Steve
    New Jersey
    2023 Ice Cap white off road premium 4runner
    TRD cold air intake, TRD matte bronze wheels with 265-70-17 Cooper discovery AT, xpel ceramic tint double layered on the whole truck plus the windshield is done in 70%. ARK mudflap delete kit, Meso dual color dome lights, solidified rear compartment cover. Molle sunvisor panels, J&L oil catch can TRD pro black valance and grille. Black mirror caps, Camping mod for rear glass, Switch Pros SP9100, Cali Raised ditch light mounts with LASfit LED cubes. Under hood LED light MOD, Compustar drone remote start
    So i have a 2023 TRD ORP and I hated the wheels and tires so I purchased Fuel Shox rims in 17x9 with a -12mm offset with factory size cooper discover AT3 tires they look amazing ride quietly no shakes at all but the only downfall is i feel as if the just wanders and grabs the crowning in the road something fierce. Is this because its now a little wider stance ? or would me putting the 265s on a 9'' wide rim cause this to happen ?
  2. Nov 27, 2022 at 11:55 AM
    I'm curious as to why you went from a 7.5" wide wheel to 9" wide...that's got to be a major factor...were those wheels only offered in 9" wide?
    With all the issues we read about with aftermarket wheels, I would think one would want to stay as close to stock specs as possible, especially if you had no issues before.
  3. Nov 27, 2022 at 11:59 AM
    Dabigono
    Dabigono Just Joined
    2020 4Runner
    It could be a radial pull. Cross rotate the front tires (front right to front left and front left to the front right) and see if that helps
  4. Nov 27, 2022 at 12:12 PM
    Check tire pressures.
  5. Nov 27, 2022 at 12:34 PM
    Commited
    Commited New Member
    Oscar
    So Cal
    2019 Silver Metallic TRD ORP
    Tinted fronts, blacked out overlays.
    This ^^ From experience.
  6. Nov 27, 2022 at 12:55 PM
    CHIEF_BLK_NIPS
    Steve
    New Jersey
    they were only offered in 9'' wide unfortunately, I ordered my truck and toyota told me they had a shortage on the trd bronze wheels so I was stuck with those ugly silver and black wheels and all seasons.
  7. Nov 27, 2022 at 12:56 PM
    CHIEF_BLK_NIPS
    Steve
    New Jersey
    Ill try it tomorrow it started raining and its brutal cold out right now and I really dont feel like firing up the wood stove for the garage thanks for your input.
  8. Nov 27, 2022 at 12:56 PM
    CHIEF_BLK_NIPS
    Steve
    New Jersey
    Tire pressure is at 38PSI thats what i run in them thanks for your input
    Singleminded likes this.
  9. Nov 27, 2022 at 1:15 PM
    They should be close to stock since you didn’t go much larger. Chalk test it.
  10. Nov 27, 2022 at 1:52 PM
    CHIEF_BLK_NIPS
    Steve
    New Jersey
    you think i possibly need an alignment ?
  11. Nov 27, 2022 at 2:01 PM
    2Toys
    2Toys Imperial Star Cruiser
    Gordon
    2019 4Runner TRDORP
    Is it possible that a stock 265 on a 9 inch rim is too wide and would cause the problem? I have Fuel Blitz wheels (18") with 275s on mine with no issues. I don't have the shimmy issue either. IMG_4494.jpg
  12. Nov 27, 2022 at 2:48 PM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    Its possible. Drop psi to 35
  13. Nov 27, 2022 at 4:17 PM
    Lots of good input already. I had a similar issue last summer when I had the spacer lift removed and installed 265’s. Turns out that the first alignment didn’t have enough toe in. Once they corrected the toe, it was good to go.
  14. Nov 27, 2022 at 5:43 PM
    Dabigono
    2020 4Runner
    Post some pics of your ride and new shoes!
  15. Nov 27, 2022 at 6:00 PM
    Overland WT
    Overland WT Grumpy Old Guy
    Bryan
    West Texas
    2017 TRD Off Road
    Many with many more to go
    This... again. I'm guessing they are probably north of 40psi? Drop to 32psi and take her for a spin.
    I run a 17x9 -25 with zero issues. -10 would have been a better choice, but I got a screaming deal on these wheels so I couldn't let them pass me by. Dont mind my big finger.
    Dabigono likes this.
  16. Nov 27, 2022 at 7:42 PM
    CHIEF_BLK_NIPS
    Steve
    New Jersey
    The truck is brand new I put the wheels on it at around 600 miles
  17. Nov 27, 2022 at 7:43 PM
    CHIEF_BLK_NIPS
    Steve
    New Jersey
    Having issues loading pics
    Joe68RS, HotelMedicis and Dabigono like this.
  18. Nov 28, 2022 at 5:58 AM
    Dabigono
    2020 4Runner
    Your truck looks great!
    If it turns out to be a radial pull, don’t wait too long to get it warrantied. The earlier the better so the shop won’t give you too much of a hassle.
    Keep us posted
    CHIEF_BLK_NIPS[OP] likes this.
  19. Nov 28, 2022 at 7:11 AM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    Check pressure, set 32psi-35psi. Then get it aligned.
  20. Nov 28, 2022 at 7:18 AM
    HotelMedicis
    HotelMedicis No Commercial Interests
    Did you de-badge it? Stunning!
  21. Nov 28, 2022 at 7:48 AM
    Daddykool
    Beauty is in the eye of the beholder. OR wheels are pretty much my favorites. They clean up easily, too.
  22. Nov 28, 2022 at 10:55 AM
    Point taken on the tires, but I too am one of those who really like the silver and black wheels. I can't see shelling out upwards of $1000 for something that isn't as good as what I already have.
  23. Nov 28, 2022 at 12:59 PM
    CHIEF_BLK_NIPS
    Steve
    New Jersey
    That’s TRD pro grill cover I bought the white Toyota block letters just waiting to put xpel paint protection on it before I throw the letters on. I also changed the back still deciding if I want a black rear balance or paint it white to blend
  24. Nov 28, 2022 at 1:00 PM
    CHIEF_BLK_NIPS
    Steve
    New Jersey
    your right I should have worded it differently to remove the wheels that I personally don’t care for. Plus I wanted the more aggressive stance.
    Daddykool[QUOTED] likes this.
  25. Nov 28, 2022 at 1:01 PM
    CHIEF_BLK_NIPS
    Steve
    New Jersey
    Thank you all for the help I am going to mess with it once I’m done work.
  26. Nov 29, 2022 at 4:55 AM
    CHIEF_BLK_NIPS
    Steve
    New Jersey
    So I started with the easiest task first dropped the air pressure to 35 and it seems to have less pull. Still feels off so tonight I will try to swap the tires around and see what happens.
  27. Nov 29, 2022 at 2:29 PM
    HotelMedicis
    That's such a beauty. I love it de-badged, no lettering, words, etc.
    That tint looks dark. What are your front and rear windows metering at? I put 30% on the sides and back and my front driver and passenger windows meter at 28% (legal) and rear is at about 9% I think (also legal).
    For what it's worth I run all my tires at 38 psi with no wandering or other issues but I haven't gone over 50 mph yet. (Stock wheels and tires.)
    Just a stunning truck.
  28. Nov 29, 2022 at 4:37 PM
    CHIEF_BLK_NIPS
    Steve
    New Jersey
    What’s the chalk test?
  29. Nov 29, 2022 at 4:39 PM
    CHIEF_BLK_NIPS
    Steve
    New Jersey
    why thank you my windows meter 00 I work at a tint shop so I have multiple layers of the higher end xpel heat rejection film. I’ve used 3m in the past but the xpel xr plus is far superior. Not trying to promote what we sell but I was a 3m certified installed for 12 years and this xpel outshines it in more ways than one.
  30. Dec 1, 2022 at 2:35 PM
    CHIEF_BLK_NIPS
    Steve
    New Jersey
    Thank you im going to give this a try saturday morning I have a dead end road behind my fathers shop.
    Nano909[QUOTED] likes this.
