Purchased '96 4runner 2wd looking for advice
Discussion in '3rd Gen 4Runners (1996-2002)' started by SutterCaine, Mar 1, 2023.
  1. Mar 1, 2023 at 10:20 AM
    SutterCaine
    SutterCaine [OP] New Member
    '96 4RUNNER SR5
    New to the forum and looking for some advice...I have been browsing various threads, trying to determine what area i should focus on to eliminate oversteer, overall loose steering, but also what feels like driving a boat when I hit a dip at highway speeds. Almost feels like Body roll.
    just picked up a 1996 4Runner SR5 2WD with 308K on the clock, paid 1700 so I knew i'd be dumping some $$ into it. Started with this 16-piece suspension/steering kit from 1A:
    https://www.1aauto.com/1996-02-toyo...936/i/1asfk04998/1118862/1996#product-reviews
    (2) Rear Shock Absorbers
    (2) Front Lower Ball Joints
    (2) Front Outer Tie Rods
    (2) Front Sway Bar Links
    (2) Rear Sway Bar Links
    (2) Front Upper Ball Joints
    (2) Front Strut & Spring Assemblies
    (2) Front Inner Tie Rods
    I also had the upper control arm bushings replaced while it was taken apart.
    Issue #1 was the new springs ended up lifting the front a TON, almost like they were made based on the '99 springs? I had the "cali bro lean" going so I had that Daystar 1.5" spacer put in the back. However, i'm still 1" high in the front so i have since ordered ToyTec 3" rear coils (arriving Thursday).
    Issue#2 the tires i ordered ended up way too small after the springs lifted the front, so I am now shopping for 255/70r17 to fill it out more.
    Basically I had all of this done, went and got it aligned...it no longer feels like a cardboard box on wheels but the steering is scary at times. You make a turn, it doesn't want to go back to center without you physically turning it back, and then it drifts too far that direction so you correct again. When going over dips/bumps at higher speed it almost feels like the passenger side moves up and down first followed by the left, like the vehicle is rolling like a wave. I am wondering if part of this has to do with that spacer on the back that's installed on what is probably the original spring and it's worn to shit.
    When the ToyTec springs come in i'll toss those in and pull the spacer...i should be .5" higher in the rear. If i post several photos below of the suspension, perhaps somebody will notice something off?
  2. Mar 1, 2023 at 10:20 AM
    SutterCaine
    '96 4RUNNER SR5
    **update
    After speaking with a friend yesterday, I have also ordered the Energy suspension bushing kit for the steering. He said that made a world of difference on his.
    Superdave1.0 likes this.
  3. Mar 1, 2023 at 10:21 AM
    SutterCaine
    '96 4RUNNER SR5
    pics of front driver/passenger
  4. Mar 1, 2023 at 10:22 AM
    SutterCaine
    '96 4RUNNER SR5
    front coil/UCA...
  5. Mar 1, 2023 at 10:24 AM
    SutterCaine
    '96 4RUNNER SR5
    also noticed these bolts w/ washer that had tick marks. The white lines no longer lined up, either from suspension install or from alignment.... would that have anything to do with it or does that change since the suspension angles have been modified from new springs?
  6. Mar 1, 2023 at 10:30 AM
    All I can say is that I wish my 2013 looked this clean underneath.
    F@cking New England.
    corrupt3db0x and SutterCaine[OP] like this.
  7. Mar 1, 2023 at 10:48 AM
    roboturner
    roboturner Dead Eyed
    ‘98 NW 3.4L 5MT SR5 | '18 6MT DCSB Tacoma | '00 IJM 3.4L TRD Tacoma
    Springs are actually what provide ride height, not shocks, so no doubt your original springs are sagging in the back. I don't have a familiarity with the A1 kit you ordered, but theoretically it was designed to knock off the OEM specs. OEM should have a 1" rake (back 1" higher than front), your front suspension should settle a bit - maybe 1/2" or so after you put some miles on it. Your new 3" springs will likely lift the back far more than 3" from current, as you're measuring from the current sagged ride height - just FYI. Keep us posted.
  8. Mar 1, 2023 at 10:52 AM
    SutterCaine
    '96 4RUNNER SR5
    Ah I didn't even consider that with the sagging springs (and the 1.5" spacer)... all of that is out of the picture when i replace with 3" springs. I was originally going to order the OME 2" but when i measured yesterday, I determined that wouldn't be quite enough to give me some rake.
  9. Mar 1, 2023 at 11:00 AM
    SutterCaine
    '96 4RUNNER SR5
    forgot to add the rear coil/spacer photos --
  10. Mar 1, 2023 at 11:38 AM
    roboturner
    As far as the steering is concerned, from center, can you turn the wheel more to the left than the right or vice versa? I think there is a bearing in the rack of the 3rd gens that could go bad, but usually its one of two things
    • Bad alignment
    • steering column needs to be centered on the rack (hence the turning question from above)
    [Also, you should probably change the diff fluid and grease your driveshaft - it won't help with your issues, but tends to be an overlooked maintenance item]
  11. Mar 1, 2023 at 11:53 AM
    SutterCaine
    '96 4RUNNER SR5
    will do on the diff fluid. also forgot i had u-joints replaced, instantly cured a shutter/shake during light acceleration. wouldn't they have greased at that time?
    thoughts on having transm fluid drained and refilled with 309,000 miles? it shifts smooth.
  12. Mar 1, 2023 at 11:58 AM
    roboturner
    Yeah they would've so you're probably good there till your next cycle, i do it every other oil change - which is 2 years for me. People have pretty strong opinions on messing with Auto Tranny fluid, there is some thought that messing with it at high mileage can cause more issues than it solves, others swear by the drain and fill-drive 100 miles, drain and fill-drive 100 miles, drain and fill combo. A full vacuum pump out and fill is widely panned. I'm more of a MT guy - so I'd let others chime in.
    You may also google "pink milkshake" and read up on it, as it's a possibility with the AT - where the transmission oil cooler leaks coolant into the tranny and creates a pink sludge that royally screws up ATs. Don't get yourself too worked up about it, but may just see what other folks have done / what they look for
  13. Mar 1, 2023 at 3:08 PM
    SutterCaine
    '96 4RUNNER SR5
    Should have posted alignment earlier, all though I’m not sure it matters I’m positive I’ll be getting it done again (somewhere else next time)
  14. Mar 2, 2023 at 10:16 PM
    Your rear control arm bushings are shot if it floats on the highway and tries to scoot out from under you when you hit a dip.
    roboturner likes this.
  15. Mar 3, 2023 at 4:41 AM
    SutterCaine
    '96 4RUNNER SR5
    ah thank you for the tip, I thought I ordered those when getting the steering bushings but I think I got the wrong part…?
    Energy Suspension 8.7106R Rear Track Arm Bushing Set
  16. Mar 9, 2023 at 6:52 PM
    SutterCaine
    '96 4RUNNER SR5
    Tried to make a separate thread about the ToyTec coils but I’m not 30 days old…
    Anyone with a 3rd gen in Dallas area want to buy 3” toytec rear springs? Hit me up. New in box. Rather sell local than pay to ship them back.
  17. Mar 9, 2023 at 7:06 PM
    Superdave1.0
    Superdave1.0 New Member
    LX470, 2025 Civic Si
    Looks like a lot of front end lift. I'd try to get a different front coilover set up. Maybe bilstein 5100 shocks and stock height springs. Then you can adjust them to the height you want.
    With that amount of front lift you might need upper control arms (UCA). Several companies make them to accommodate lifted vehicles. They help with drivability and alignment.
    Rear spacers kind of add to the floaty feeling. A proper rear lift spring will ride much better.
    The steering bushings you ordered will for sure help.
  18. Mar 9, 2023 at 7:12 PM
    SutterCaine
    '96 4RUNNER SR5
    Thanks. I’m removing spacer tomorrow. Apparently I’m about 2.5” high in the front from factory spec. Sitting at 22.25” driver and 22.75” passenger (hub to fender)
    I bought Moog factory rear springs, and oddly enough if you set them against the OME 2” they are definitely taller… however, much easier to press down with my bare hands. I am guessing the 2” lift from the OME comes not all from height but compression/stiffness?
    tomorrow I’m dropping off for rear springs, front and rear sway bar bushings, track arm bushings, steering rack bushings,
  19. Mar 9, 2023 at 10:19 PM
    I change my trans fluid when I do regular oil changes. Just two quarts at a time that’s what the pan holds. Then it’s very easy to add two quarts through the dipstick hole.
    SutterCaine[OP] likes this.
  20. Mar 10, 2023 at 4:32 AM
    roboturner
    I’d still put some miles on before going too drastic, those Moogs will settle in the front, I’m just not sure how much as i don’t have experience with them
  21. Mar 10, 2023 at 4:39 AM
    SutterCaine
    '96 4RUNNER SR5
    I’ve put about 500 so far
