programming for dummies..
Discussion in '5th Gen 4Runners (2010-2024)' started by j4unner, Mar 21, 2021.
  1. Mar 21, 2021 at 10:39 AM
    j4unner
    j4unner [OP] shootz brah..
    j4runner
    nCal
    21 SR5P
    i saw youtube videos and read manuel but still can not get the programming for the garage..
    garage: genie 7035 just replaced 2 years ago..
    car: 2021 4R..
    ty!
  2. Mar 21, 2021 at 12:01 PM
    08TXRunner
    08TXRunner New Member
    '20 SR5P
    j4unner[OP] likes this.
  3. Mar 21, 2021 at 3:18 PM
    j4unner
    j4runner
    nCal
    21 SR5P
  4. Mar 21, 2021 at 4:59 PM
    j4unner
    j4runner
    nCal
    21 SR5P
    thanks 08TRXRunner.. success!
  5. Mar 21, 2021 at 5:23 PM
    08TXRunner
    '20 SR5P
    Welcome bud!
    I'm guessing the first link, because that second one now appears dead.
  6. Mar 21, 2021 at 8:24 PM
    j4unner
    j4runner
    nCal
    21 SR5P
    2nd link works just had to go to homepage from the “dead” site and plug on car info..
  7. Mar 22, 2021 at 5:38 PM
    T-Rex266
    T-Rex266 Moderator Staff Member
    Can you type up the instructions, that you found worked?
  8. Mar 22, 2021 at 6:35 PM
    08TXRunner
    '20 SR5P
    Sorry, I did this in January of 20 when I bought my truck. What I remember is this - the manual states to hold a button in the truck to program the truck. The Homelink site says you have to hold two buttons to program, and that was the trick. The Toyota manual has incorrect instructions, the Homelink site has the correct ones.
    EDIT: from the Homelink site for a Genie:
    Intellicode 1 – General Instructions
    1. For first time training, press and hold the two outer HomeLink® buttons, releasing only when the HomeLink indicator light begins to flash, which may take up to 20 seconds. (Do not perform this step when training the additional HomeLink buttons.)
    2. Position the hand-held transmitter 1-3 inches away from the HomeLink surface (usually located on your visor, overhead console, or mirror), keeping the HomeLink indicator light in view.
    3. Using both hands, simultaneously press and hold both the desired HomeLink button and hand held transmitter button. DO NOT release until the HomeLink indicator light flashes slowly and then rapidly. When the indicator light flashes rapidly, both buttons may be released. (The rapid flashing indicates successful training.)
    4. A second person may make the following steps quicker and easier. Please use a ladder or other device. Do not stand on your vehicle to perform the next steps. On the garage door motorhead, press and release the learn code button - the red LED will begin to blink.
    5. Get back into your vehicle and press the desired HomeLink button one time.
    6. Press the desired HomeLink button a second time.
    7. Press the HomeLink button a third time. You should see the garage door open/close. HomeLink programming is complete.
    j4unner[OP] and T-Rex266 like this.
  9. Mar 22, 2021 at 8:09 PM
    j4unner
    j4runner
    nCal
    21 SR5P
    nothing has been programmed but I still cleared the homelink system by holding buttons 1 & 3 down for about 10 seconds until I saw flashing green..
    the method that work for me was from the "learn' button.. on my motorhead it said "program" for the button as previous posted in thread..so I held that down for a few seconds, it went from solid green to solid blue.. (this is where I messed up on several previous attempts)..I was trying to sync on solid blue. (wait for blinking purple)..
    so from solid green, to solid blue..I waited a few more seconds and it started to blink purple..from there I went over to the car and pressed desired homelink button.. 2 seconds release and repeat until garage door closed.. BOOM! finally got it..
    T-Rex266 likes this.
  10. Mar 23, 2021 at 12:30 PM
    T-Rex266
    TrueTexas and 08TXRunner like this.
  11. Mar 24, 2021 at 6:27 AM
    08TXRunner
    '20 SR5P
    Yes, that's the same as the instructions I posted.
  12. Dec 23, 2021 at 11:59 AM
    carb434
    carb434 New Member
    Andrew
    MGM TRD-ORP
    None
    I know this is an old thread, but if anyone has trouble pairing with a genie remote, check the back of the remote for the software code. If it’s version 2.0.3 then it won’t work, you have to get a new remote or borrow one. I messed with this for hours, then finally found the genie instructions that showed to look for the software version… sure enough my remote had that. Got a new remote, worked exactly as explained above.!
  13. Dec 23, 2021 at 12:34 PM
    4R21
    4R21 New Member
    AK
    Land of Cheese
  14. Feb 22, 2024 at 2:24 PM
    CJT4Runner
    CJT4Runner Frosty
    Chris
    ‘20 TRD ORP
    Is there a way to program a remote from the home link button? I know how to go from remote to 4R but I need 4R to remote.
  15. Feb 22, 2024 at 3:30 PM
    backpacker
    backpacker New Member
    2023 TRD ORP
    Falken Wildpeak 265/70R/17 load E
    Do you mean you want the remote to learn from the 4R? If so does the 4R already know how to open the garage door? Ultimately, it's the door opener that runs the show. You can program a new remote for that door opener without the 4R being involved.
  16. Feb 22, 2024 at 4:05 PM
    CJT4Runner
    CJT4Runner Frosty
    Chris
    ‘20 TRD ORP
    Yes, I’d like the remote to learn from the 4Runner if that’s even possible. The 4R knows how to open a gate and I want to be able to share that.
