Problem with AC Resetting after having my 5th gen 4Runner sit for a couple of hours
Discussion in '5th Gen 4Runners (2010-2024)' started by Maverick808, May 29, 2021.
  1. May 29, 2021 at 1:24 PM
    Maverick808
    Maverick808 [OP] New Member
    2018 Mganetic Grey Metallic Toyota 4Runner Limited
    Hey i’m new to the forum and I created a account just to see if anyone else have had this issue with their 5th gen Limited dual zone climate system. When I let my 4Runner sit for a couple hours and then go to start it up. I try to turn on my AC but it doesn’t do anything for a about 5-10 seconds and none of the lights are on, than when it does turn on its set to 75 degrees when I had it at Lo before turning my truck off
  2. Mar 24, 2023 at 4:31 AM
    Willie
    Willie New Member
    2019 limited 4Runner
    Similar problems. Climate control is “off” after starting up and will only turn on if turned on manually. Almost seems as though it loses the memory of the last state when turned off. Toyota dealer has not seen this before. Diagnosing $$$. Trial and error part swapping???
  3. Aug 12, 2025 at 7:58 AM
    jpress
    jpress New Member
    2018 4Runner Limited
    2018 4Runner Limited 4x4, Mine has just started doing this exact same thing about two weeks ago. Took it to my local Toyota dealer and they have not seen this before so they waived the $135 diagnostic fee and stated they don't see any codes and sent me on my way. Mine does not have any display on the climate screen for a full minute after start up, then it will display the face vent icon. Once I see that icon I can manually start up the fan and the temp is automatically set at 75 degrees.
  4. Aug 16, 2025 at 3:22 PM
    Greg D
    Greg D TJ312
    TJ312
    2013 4runner
    It doesn't do anything until compressor pressure builds and it actually gets to a temperature it doesn't mind blowing on you. I think that a politeness thing.
  5. Aug 16, 2025 at 4:33 PM
    kolter45
    Denver
    Inferno Pro & BRM Sport
    Post a video
  6. Aug 17, 2025 at 5:57 PM
    jpress
    jpress New Member
    I've had this 2018 4runner limited 4x4 for 5yrs and this problem just started two weeks ago? In the past, as soon as I started the vehicle, the a/c or whatever climate control was selected last would automatically come on without having to wait a full minute regardless if it was A/C, heat or outside air vent....
