Power steering pump and reservoir question
Discussion in '3rd Gen 4Runners (1996-2002)' started by CoolToyota, May 24, 2025 at 8:41 AM.
  1. May 24, 2025 at 8:41 AM
    CoolToyota
    CoolToyota [OP] New Member
    98 4Runner 1A5
    Took the pump apart to replace the seals etc and wondered about the reservoir - is there a screen etc that’s replaceable in that ? And recommends on what to use to clean flush it out ? By the way - pump has been working just wanted to clean and renew it.
  2. May 24, 2025 at 5:31 PM
    Hungryhawk
    Hungryhawk New Member
    Southern CA
    2017 SR5
    Why not replace reservoir? Every 100,000 miles or so I do on all my vehicles. If any actual problems I add an in-line filter also.
    What fluid are you using? How often refreshed or changed?
  3. May 25, 2025 at 5:13 AM
    CoolToyota
    98 4Runner 1A5
    I’m new owner so first time servicing system. I understand use transmission fluid ?
  4. May 25, 2025 at 8:09 AM
    Hungryhawk
    Southern CA
    2017 SR5
    Lots of opinions for which ATF. Max Life gets lots of positive reviews. I think it is especially good for older systems due to seal conditioners. I did a couple PS reservoir suction & fills with it. It really cleaned up brown residue from factory original PS fluid. Now I am using Mobile one full synthetic ATF.
  5. May 25, 2025 at 11:05 AM
    CoolToyota
    98 4Runner 1A5
    Good info ! I’m replacing the rack and the hoses - perhaps I could have did the pump as well but didn’t - I was going to replace the seals etc of the pump - the pump was working when I tore into everything I just figured I’d get it cleaned up and rehab it !
