Potential Alternator/Voltage Issues
Discussion in '4th Gen 4Runners (2003-2009)' started by Topher1164, May 20, 2024.
  1. May 20, 2024 at 1:17 PM
    Topher1164
    Topher1164 [OP] New Member
    I'm having weird issues.. The other day my car started making a fan whirling noise, which I believe was the alternator... it went away.. but then the next day my radio would shut off when I engaged the brakes... This all started when I bought a new electric cooler for car camping... and testing it out with the 12v normal charger...
    I have a thought that maybe my battery is getting drained from something when it is off...
    Maybe this connected to the battery? ... I'm assuming it's something to do with a head unit or something similar.. I think this could be a factor.
  2. May 20, 2024 at 1:19 PM
    Previous owner probably had a system. You will have to follow the wiring.
  3. May 20, 2024 at 1:22 PM
    Topher1164
    Thanks! I've been having weird issues that I thought was alternator related, like when I engage my brakes, my radio shuts off... I just got an electric cooler for car camping, and I believe it has exposed this issue.. The alternator seems to be charging the battery, but potentially something is draining it when the car is off.
  4. May 20, 2024 at 1:22 PM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid (modified) RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ Apache CF220 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Lasfit LED Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    Looks to be a fuse.
    Follow the wire and figure out where it leads... Alternatively you could disconnect it and see what happens lol. Might just solve your voltage issue...
  5. May 20, 2024 at 1:26 PM
    Topher1164
    Thanks. I don't know how to test it really.. I don't have a voltage reader, and not very knowledgable with wiring... I'm trying to eliminate the possibility of an alternator issue. Your suggestion makes sense.. lowest hanging fruit.
  6. May 20, 2024 at 1:33 PM
    1SilverRunner
    Tejas
    My bet would be its power to a head unit or amp somewhere in the rig. If it was my rig I would chase the wire first and see where it leads. If you can't find where it goes you could
    1: Check the voltage with vehicle turned off. Should be around 12.5v
    2: Check the voltage when the vehicle is in accessories on. Should be around 12.5v
    3: Check the voltage at idle. Should be around 13-14v
    Disconnect that wire and do this again. See if your results change.
    Also see if your stereo and all accessories and lights still work without it being connected. That should lead you in the right direction
  7. May 20, 2024 at 1:34 PM
    Topher1164
    Perfect! thanks for the voltage readings.. i'll have to get a multimeter.
