Portable compressors
Discussion in 'General 4Runner Talk' started by oldtimer, Aug 7, 2019.
  1. Aug 7, 2019 at 10:10 AM
    oldtimer
    oldtimer [OP] New Member
    Robin
    Edmonton, Canada
    2020 TRD Pro 4Runner Army Green
    4 x 4 Innovations sliders Greenlane Rear hatch ladder
    Has anyone used the TJM portable compressor? These are Australian made. The price seems attractive at $109.00 If so, any comments?
    TJM Portable Air Compressor kit comes with everything you need for easy access to portable air. The all in one kit includes a storage bag, 20 ft of air hose, twin core alligator clips, multiple air fitting adapters to fill not only tires, but mattresses and more and even includes a spare fuse. The unit is thermally protected with automatic shut off and weighs in just over 12 lbs. Power is supplied directly from your vehicle's battery using the supplied alligator clips.
    Features
    • 72 ltr per min Max air flow
    • Includes: Bag
    • Includes: Hose
    • Max Current Draw: 30amps
    • Max Voltage: 13.8v
    • Max Working Pressure: 120psi
    • Non Lube Piston & Cylinder
    • Oil-less style compressor
    • Weight: 5.5kg (12.3 lbs) including bag & hose
  2. Aug 7, 2019 at 2:16 PM
    jester243
    Dan
    Spokane, WA
    for that price, it would be hard to pass. My dad was looking at a compressor for his RV and the things were stupid expensive compared to this.
    SlvrSlug likes this.
  3. Aug 8, 2019 at 4:20 AM
    DGP1961
    DGP1961 New Member
    2018 SR5 Premium
    Bought one two years ago at Lowes for half that price still works to this day. Use it a few times a week (slow leak in daily driver I haven't bothered with.) There's probably ones out there that inflate quicker but it gets the job done. Don't recall the make right this second.
  4. Aug 10, 2019 at 5:25 PM
    oldtimer
    Robin
    Edmonton, Canada
    found a compressor on sale for Canadian $79.99, took it home, checked 4Runner tire pressure, 3-4 lbs low all around. This compressor topped up to recommended tire pressure on Goodyear Wranglers in less than 2 minutes/tire. Comes in a case. Electric cable and hose plenty long to reach all tires. Surprisingly quiet. Came with extra in line fuse, and tips for filling balls and air mattresses etc. Built in digital pressure gauge reads high during filling so have to fill to about 4 lbs high. Also has a LED light on front for using if dark. When shut off, it reads to tire pressure. Comes in a nice case for storage.
    jester243 likes this.
