pls confirm if this Enkei wheel with 265/70/17 tires will work with no rubbing
Discussion in 'Wheels & Tires' started by Dohc97, Nov 5, 2021.
  1. Nov 5, 2021 at 6:24 AM
    Dohc97
    Dohc97 [OP] New Member
  2. Nov 5, 2021 at 8:19 AM
    beankozi
    beankozi New Member
    Jarrett
    Vancouver Island
    2021 Venture
    quite a few
    I would say no rubbing.
    Toy4X4 likes this.
  3. Nov 5, 2021 at 4:47 PM
    Dohc97
  4. Nov 6, 2021 at 10:59 AM
    619T4R
    619T4R New Member
    2021 SR5P
    Nice choice! Just put those wheels on mine a couple weeks ago. Running stock size tires as well, no rubbing at all.
  5. Nov 6, 2021 at 4:23 PM
    Dohc97
    Have any pics to tide me over? ETA on mine is 11/19.
  6. Nov 6, 2021 at 5:36 PM
    619T4R
    619T4R New Member
    2021 SR5P
    Unfortunately not any good ones but here ya go!
  7. Nov 7, 2021 at 5:21 AM
    619T4R
    619T4R New Member
    2021 SR5P
    I wish I knew what this meant haha
  8. Nov 7, 2021 at 2:57 PM
    icyhotahs
    icyhotahs NEw mEmBER
    Samuel
    Sacramento, CA
    2022 ORP Super White
    Method 703 - Nitto G2 - C4 Ladder - UpTop Rack - EIbach 2.0 Coilovers & Load Levling Kit (250) Victory Strike Sliders - Dometic 55 - EcoFlow Delta
    He's being a sarcastic overthinker
    Toy4X4, Mtbpsych and 7385 like this.
  9. Nov 7, 2021 at 6:04 PM
    619T4R
    619T4R New Member
    2021 SR5P
    Damn didn’t know this was Facebook. I’ll show myself out now.
  10. Nov 7, 2021 at 6:19 PM
    icyhotahs
    Samuel
    Sacramento, CA
    RIP Brad
    DRobs and 619T4R like this.
  11. Nov 7, 2021 at 6:21 PM
    icyhotahs
    Samuel
    Sacramento, CA
    He wasn't talking about your ride, he was talking to the OP. But in your Facebook world, you read it as an attack and got feelsbadman
  12. Nov 7, 2021 at 7:47 PM
    619T4R
    619T4R New Member
    2021 SR5P
    I don’t do Facebook for this reason haha. Just wondering what he was talking about since I’m new to this.
    icyhotahs likes this.
  13. Nov 7, 2021 at 9:28 PM
    Xombie2000
    Xombie2000 New Member
    2016 4RUNNER trail
  14. Nov 12, 2021 at 12:51 PM
    4RunnerRPT1
    4RunnerRPT1 New Member
    Dave
    2020 TRD OR
    Stock suspension on a 2020 TRD Off Road. Enkei RPT1 17x9 and BFG K02 265/70. No rubbing but I kind of feel like the Off Road model suspension is a little more generous than the SR5 / Sport. Maybe it's just my poor eyesight.
    Dabigono likes this.
  15. Nov 12, 2021 at 12:57 PM
    4RunnerRPT1
    Dave
    2020 TRD OR
    FYI - you may want to research some of the threads on TPMS. You either have to keep your OEM TPMS, reprogram new TPMS, or live with the TPWS light (which I did - a little annoying, but I didn't want the hassle of going to the dealer to reprogram).
  16. Nov 12, 2021 at 1:48 PM
    afret
    North Idaho
    I'm still waiting on a Limited but have been trying to find out what 17" combo will fit with no rubbing. If a Sport is very similar to the Limited in tire clearance, you might have some rubbing with those Method wheels since it looks like it has 0 offset. There's a thread here of a guy that got 17x8 wheels with +15 offset and 265/70-17 tires and he still had a bit of rubbing in the front at full lock. I think it will be worse with a 0 offset since the wheel/tire will stick out more.
    I'm planning on just getting stock SR5 or Off Road wheels that both have a +15 offset. The Off Roads are .5" wider that the SR5 wheels. I'll get 265/70-17 tires and push the liner forward if it rubs.
    https://www.4runners.com/threads/what-size-duratracs-to-avoid-rubbing.21548/
  17. Nov 14, 2021 at 7:40 AM
    Dohc97
    I spoke to a Tire Rack rep before ordering the wheels and he said it will fit without rubbing. That was the reason I didn't get the Enkei because he said it would rub. Let's see what happens when I get the wheels in a couple of days.
    If it rubs, I guess I have to lift the truck? I don't want to lift it a lot because of the missus. What would be a minimal lift I should do? No plans on offroading here.
  18. Dec 2, 2021 at 8:22 PM
    Dohc97
    So I got the wheels/tires delivered today from Tire Rack. Three of the wheels have centering rings on them, one does not. Are the centering rings needed to fit the wheels in our 4runner? I called Tire Rack and the guy said the rings are not needed. I sent an email to Method Wheels support and the guy said he will send me the missing ring.
  19. Dec 3, 2021 at 1:14 AM
    runnerjimmy
    runnerjimmy New Member
    Scottsdale Az. Castle Rock Co.
    2021 ORP Barcelona red
    Fox 2.5 DSC. 2 1/2” front, 2”rear. Falken Wildpeak 255/80/17
    So is Method saying the ring is needed on the 4Runner install
  20. Dec 3, 2021 at 5:04 AM
    Dohc97
    He didn't say it is needed. He said he will send me one centering ring. I am sending him another email to confirm.
  21. Dec 3, 2021 at 7:40 AM
    Dohc97
    Got an email from Method. I guess the rings are not needed after all. Below is a copy and paste from his email.
    Thanks for your question. The Hub Rings are not specifically needed for the install. The Hub Rings basically center the wheels on the hub while installing the lug nuts against the hub. If the installer uses the star pattern to tighten the wheel on the hub, you will be good to go without having to use the hub rings. The experienced installer will only tighten the first 3 lugs about ¾’s of the way using the “star or cross lug sequence, ( This centers the wheel on the hub ), then hits the other lugs fully to tighten the lugs on the wheel. Then all of the lugs should be hit a second time using the star or cross method to ensure the lugs are all secured before lowering the vehicle to the ground. After the vehicle is on the ground, the tire tech should torque the lugs before you leave. We Always recommend re-torquing lugs on All new wheels after 50 to 100 miles.
  22. Dec 3, 2021 at 7:57 AM
    banjos-n-beer
    banjos-n-beer New Member
    Steve
    Maine
    2018 Pro
    i disagree with the opinion not to use hub centric rings. it doesn't take much misalignment to get weird vibrations. plus you're adding extra stress to your studs.
    ymmv
  23. Dec 3, 2021 at 8:36 AM
    Dohc97
    I think I am going to be on the cautious side on this and wait for the centering ring from Method.
  24. Dec 3, 2021 at 11:40 AM
    afret
    North Idaho
    I think the reason the Method person said the rings aren't needed is that the bore diameter on the MR316 is 106.2 which should fit the hub pretty closely.
