Please help
Discussion in '3rd Gen 4Runners (1996-2002)' started by K4x4, Sep 3, 2021.
  1. Sep 3, 2021 at 3:27 PM
    K4x4
    K4x4 [OP] New Member
    97 four runner 4x4 v6 tan
    My ac compressor went out on my 3 gen so I replaced it and expansion valve and dryer and it does work but when I first turn it on the compressor squalls for a 2 seconds and its not the belt I put oil in compressor dryer and 22 oz of 134 what did I do wrong
  2. Sep 3, 2021 at 4:06 PM
    Oil in compressor dryer too? Just thought pag oil was added to the compressor. Has to be a certain amount mine was already added. Spray something on the belt and see if it stops?
  3. Sep 4, 2021 at 11:35 AM
    PhantomTweak
    PhantomTweak New Member
    Patrick
    OREGON
    1999 4Runner, bone stock
    Could be the belt tension is a little loose, and/or the idler pulley's bearings going bad. Easy enough to check, just take the belt off and turn it by hand. Feel for grinding, or looseness/play of the pulley. The pulley is pretty easy to remove from it's mount.
    The pulley bearings are readily available, both installed in a pulley, and out by themselves, that you have to press in. Again, easy process.
    Good luck, and keep us up to date
    Pat☺
  4. Sep 4, 2021 at 12:27 PM
    How do you know it's not the belt?
    If it's a new belt, it takes 2 more attempts at tightening to get it to stop squawking.
    If it's an old belt...at least one more attempt.
  5. Sep 4, 2021 at 1:21 PM
    2Toys
    2Toys Imperial Star Cruiser
    Gordon
    2019 4Runner TRDORP
    Oil circulates throughout the system, so it would make its way to the receiver dryer also. I just watched a professional yesterday put oil in the servicing port using an oil tube in a gun with a coupling attached to the servicing port.
