Please help. Parts Required for TRD wheel
Discussion in '5th Gen 4Runners (2010-2024)' started by GAPrecison, Nov 30, 2020.
  1. Nov 30, 2020 at 3:38 AM
    GAPrecison
    GAPrecison [OP] New Member
    2019 4Runner TRD PRO
    Shrockwork Rock Slider
    I have a 2019 4R TRD Pro. I just got a TRD Pro wheels (PTR2035110BK) from the dealership. Not as expensive like people said, just around $165 wo tax per wheel. But it only comes with the wheel, no extra parts to complete it. What is other part will I need? Will I need back spacer for stock setup or the wheel is good as it is? Refer OEM part number. Thank you.
    PS: Does the 4Runner have low pressure monitor like Tacoma?
  2. Nov 30, 2020 at 5:53 AM
    Archangel
    Archangel Special Assistant to the Regional Manager
    Matt
    Monroe, North Carolina
    '04 T4R SR5 4x4
    Stock AF
    Yes, your 4Runner has the tire pressure monitor system (TPMS) like the Tacoma. You'll need a rebuild kit (hex nut, washer, rubber grommet, valve core, and valve cap), which can be picked up at any tire shop when they swap your wheels out. Unless the center caps didn't come with the wheels, you should be able to use your old lugnuts currently on you T4R. Hope this helps.
  3. Nov 30, 2020 at 7:56 AM
    Welcome to the forum.
  4. Nov 30, 2020 at 8:07 AM
    edgesalon
    edgesalon New Member
    Te
    18 FunRunner :-)
    did you just buy the one extra wheel for the spare & welcome to the forum
  5. Dec 3, 2020 at 7:52 AM
    GAPrecison
    Extra for a tire carrier overland bumper that I will but on soon.
  6. Dec 3, 2020 at 7:56 AM
    Daytonaviolet
    Daytonaviolet TRD Bro
    Bay Area, CA
    Blizzard Pearl TRD Bro
