Plastic Oil Filter Housing
Discussion in '5th Gen 4Runners (2010-2024)' started by skistoy, Nov 16, 2022.
  1. Nov 16, 2022 at 4:58 PM
    skistoy
    skistoy [OP] New Member
    2022 Lunar Rock Trail Edition
    BFG KO2
    The Car Care Nut has done a very informative video on toyota oil filters and the plastic or metal housing. I was considering replacing the plastic housing, but after watching this I will just stick with the original plastic one. Video has great information for those who do their own oil and filter changes.
    https://www.youtube.com/watch?v=G_vl2AYe7Yg
  2. Nov 16, 2022 at 5:18 PM
    Bald Michelins
    Bald Michelins New Member
    21' SR5P
    Ha. I just got done watching this. I came over here to see if it was posted yet. Same here. I have a metal housing I was going to swap out but I think instead I'll get a spare plastic housing assy to keep on the shelf as a spare.
    HotelMedicis and skistoy[OP] like this.
  3. Nov 16, 2022 at 5:35 PM
    skistoy
    BFG KO2
    On my last oil change I asked my service manager what he thought about the plastic housing. He said that they never had any problems with them at all.
    Slopemaster and HotelMedicis like this.
  4. Nov 16, 2022 at 5:46 PM
    Singleminded
    Singleminded New Member
    2020 4Runner Limited
    OEM LED foglights
    Good you posted that! Convinced me to stick with the OEM plastic housing!
  5. Nov 16, 2022 at 5:53 PM
    Use the right wrench and the plastic housing will serve you well.
  6. Nov 16, 2022 at 5:56 PM
    I've never had an issue either.
    Its only when dumb asses touch it shit happens.
  7. Nov 16, 2022 at 6:25 PM
    And that's when the plastic one will crack and give you issues. I will stick with my metal one even if the care nut guy doesn't like it.
  8. Nov 16, 2022 at 6:45 PM
    Singleminded
    OEM LED foglights
    I don't blame anyone for preferring an OEM metal housing to the plastic one -- but note what the guy says about the tube! He says using the short one is the same as activating the bypass valve, which means your oil never gets filtered at all. And he also says that swapping tubes is asking for a failure, because that spring loaded part is not designed to be disassembled and reassembled. If that mechanism is dislodged the entire housing assembly should be replaced.
    2014 pepe, Nmscuba and Slopemaster like this.
  9. Nov 16, 2022 at 6:50 PM
    TrueTexas
    TrueTexas New Member
    The Woodlands, TX
    That would be reason #42 that I change my own oil. If something happens to it, it's only my own fault.
    For reference 80k miles on my daughters Camry with a plastic housing so about 16 oil changes and it looks perfect.
    I'll stick to the plastic one. If it gets damaged, I'll replace it with another plastic one. The days of metal being better than plastics are long gone.
    Matter of fact, now that I think about it some more, what happens when the metal one gets over torqued? Which threads give way? The filter housing or the part you screw it into? Would rather it be the filter housing. I'm sure Toyota engineers grabbed that one vs the metal one that was also in the parts bin for a reason.
  10. Nov 16, 2022 at 9:28 PM
    Nevin
    Nevin New Member
    Puyallup, WA.
    2022 TRD ORP
    PPF, Tint, Black out badges/Valances. Bilstein 6112's & 5100's
    :deadhorse:
    Ironguy and ToyoTaco25 like this.
  11. Nov 16, 2022 at 9:35 PM
    Potsie
    Potsie New Member
    2022 Army Green 4Runner ORP
    Car care nut and scotty kilmer comment section is hilarious. They take everything these two say as gospel. That housing it not trash just because he removed the tube. It easily goes back in
    57HotrodVW, roc, ChessGuy and 2 others like this.
  12. Nov 17, 2022 at 2:01 PM
    He is good with some stuff but so dramatic with other stuff. I like his knowledge but I think on this one he was a bit much on the plastic versus metal. I know not apples to apples but what's next, that plastic bumpers are better than metal?
    Singleminded likes this.
  13. Nov 17, 2022 at 5:56 PM
    2020 4Runner
    2020 4Runner New Member
    Fl
    We have the metal housings all over on the Tundra side....no issues that I know of.
  14. Nov 18, 2022 at 9:41 AM
    And its also why I do my own.
    I've never broken it on any vehicle yet.
    Not saying the metal one isn't worth it. No sense changing it if you do it yourself and competent.
    ToyoTaco25 and glwood54 like this.
  15. Nov 18, 2022 at 10:26 AM
    ElectroBoy
    ElectroBoy Ad astra
    Bay Area, CA
    When you’re a DIY mechanic there are all sorts of opportunities to do damage to your vehicle if you do something wrong.
    If you’re installing the Toyota metal oil filter housing do it right. Be sure to properly swap the correct height center tube from your plastic one.
    2Toys, Ironguy, glwood54 and 2 others like this.
  16. Nov 18, 2022 at 10:37 AM
    A wise man, referring to the difficulty level of a trail, once said: “The trail is pretty easy…I mean, you can f*ck things up…but it’s pretty easy.”
    DIY mechanical-maintinance work is the same way :D
    2Toys, Slopemaster and ElectroBoy like this.
  17. Nov 18, 2022 at 10:51 AM
    5thToy
    5thToy New Member
    Northern Nevada
    2019 SR5P
    For good measure, use the original spring from the stock plastic housing too. It is possible they are different spring rates. I was focused on the tube swap and who knows which spring I ended up installing.
    ElectroBoy[QUOTED] and Curt56 like this.
  18. Nov 18, 2022 at 11:21 AM
    TrueTexas
    The Woodlands, TX
    Agree that we should all assess our mechanical ability and risk tolerance before we decide if we should do the work or take it to a shop.
    Personally, I trust myself way more than the new hire at the shop who is being measured on the quantity not the quality of their work.
    As far as I am concerned, the dealer is only for warranty work, nothing else. The only other thing I don't do myself are tire installs and alignments (jeep excluded - too easy to align in my garage)
  19. Nov 19, 2022 at 5:57 AM
    Plastic or metal?
  20. Nov 19, 2022 at 8:54 AM
    Potsie
    Potsie New Member
    Well, I guess you proved that it wasn't junk over the past 70k miles. Good to know. This was with a drop and being dislodged from the force of a fall. Simply removing it doesn't harm anything and that was my original point. If these springs can't handle being removed they could never be trusted to last the life of a vehicle.
  21. Dec 19, 2022 at 3:20 PM
    Masol32
    Masol32 New Member
    Gray 2014 4Runner sr5
    Same exact thing happened to me a couple days ago. Then I watched this video, and will replace it with OEM plastic. I put the center tube back in without a problem, but I think ill just replace it.
