Pearl's -King Shocks-Dirt King +3.5 -Califab -Metal Tech -Custom Baja Bumper -Doug Thorley Headers
Discussion in '4th Gen 4Runners (2003-2009)' started by MI-FL off roader, Jan 4, 2019.
  1. Nov 3, 2023 at 5:00 AM
    #121
    MI-FL off roader
    MI-FL off roader [OP] T4R Hobby/Addict
    Brett
    Merritt Island, FL
    03' SR5 Sport - 12' Limited
    Back to my abuse of steel and my little Hobart, and my lack of fabrication skills.
    The Baja style bumper needed to have the main pipe extended to match the fiberglass, and I started thinking about how to make use of a tube bender I picked up cheap on marketplace. So I thought Nerf bar...why not?
    nimby and xtremewlr like this.
  2. Nov 3, 2023 at 5:21 AM
    #122
    MI-FL off roader
    Brett
    Merritt Island, FL
    I did a little research into joint coping, and stumbled on a free calculator. Plug in your numbers and then you print and cut out your template. Instead of using a hole saw and notch tool, you use a cut wheel and flap disc. I used to do tile and marble and got pretty good with a cut wheel and saw, so that part went ok.
  3. Nov 3, 2023 at 5:26 AM
    #123
    MI-FL off roader
    Brett
    Merritt Island, FL
    I decided to install uprights for the Nerf bar and move the aluminum plate out and make it a little larger. So this involved some crazy angles.
  4. Nov 3, 2023 at 5:31 AM
    #124
    MI-FL off roader
    Brett
    Merritt Island, FL
    I have to say the main tube extensions went better than expected. The nipples are snug and I will plug weld either side, and then stitch the seam.
    nimby, BassAckwards and xtremewlr like this.
  5. Nov 3, 2023 at 5:33 AM
    #125
    MI-FL off roader
    Brett
    Merritt Island, FL
    Now I have everything tacked up and looking pretty good, it's ready for me to goober it up with some sloppy welds. In the interest of my pride, I won't be posting pics of that.
  6. Nov 3, 2023 at 7:26 AM
    #126
    xtremewlr
    xtremewlr New Member
    Todd
    Tucson, AZ
    2003 4Runner V8 Limited 4WD
    Lots with more in the works
    Dude, you're doing a great job with the fab stuff! The bumper is coming out great!
  7. Nov 3, 2023 at 7:30 AM
    #127
    MI-FL off roader
    Brett
    Merritt Island, FL
    Thanks man! What you don't see are the gaps in certain places and my welding is terrible lol. Flappy and paint are my saviors.
    xtremewlr[QUOTED] likes this.
  8. Nov 5, 2023 at 5:22 AM
    #128
    MI-FL off roader
    Brett
    Merritt Island, FL
    Very subtle difference from the front angle, but the Nerf bar and larger plate help fill it in a little. Profile looks ok. Overall? it needed to be done and I'm happy with it.
    nimby, xtremewlr and BassAckwards like this.
  9. Nov 5, 2023 at 5:36 AM
    #129
    BassAckwards
    BassAckwards New Member
    2006 4Runner V6 SR5
    Looks great from where I’m at!
    nimby and MI-FL off roader[OP] like this.
  10. Nov 5, 2023 at 10:41 AM
    #130
    xtremewlr
    Todd
    Tucson, AZ
    Agreed. Came out really nice!
  11. Nov 29, 2023 at 9:17 AM
    #131
    MI-FL off roader
    Brett
    Merritt Island, FL
    Replaced the factory front skid with some aluminum.
  12. Nov 29, 2023 at 9:38 AM
    #132
    Nomadik Overland
    Nomadik Overland New Member
    David
    2006 V8 Tacorunner
    Tacoma Swapped Frontend +2 Long Travel in the front Long travel in the rear Addicted offroad front bumper True North Fab Rear bumper Custom rock sliders Nomadik Overland Drawer system Nomadik Overland roof rack Yakima RTT w/Napa Awning Caliraised Lights
    Ooooh, This is looking mean! Definitely been contemplating ditching my current bumper for a more prerunner inspired bumper! Yours looks great!
    MI-FL off roader[OP] likes this.
  13. Dec 29, 2023 at 9:38 AM
    #133
    MI-FL off roader
    Brett
    Merritt Island, FL
    I know squat about tuning, but I want to learn so......
    Installed an AEM Wide band, URD Maf Calibrator, new plugs, and an air filter. 20231224_071656.jpg 20231224_150947.jpg 20231224_144124.jpg
    xtremewlr likes this.
  14. Dec 29, 2023 at 9:42 AM
    #134
    MI-FL off roader
    Brett
    Merritt Island, FL
    Decided to mount the URD in a location easily accessible. Did a base run on a Mustang Dyno.
    I realize there won't be much more power gain out of this 4Runner in its current set up, but you gotta start somewhere. Thanks to Rolo Lopez @CentralFloridaTurbo It was basically a teaching session for him. As you can see in the video linked below, my dumb ass never went WOT on this pull...SMH. I had 3 bad pulls because of my inexperience, but I settled down on the last one and will use that as a baseline. I should have run 2 more.....
    I do have to remember this MY only came 230 HP at the crank. They were made for more torque and these torque numbers on a Mustang Dyno aren't terrible.
    Mustang Dyno You Tube Vid
    03' 4Runner V8 w 35" tires
    58* raining/intake Temps 70* to 90*
    189.85 HP @ 4600 rpms
    250.69 Ft Lbs @ 3900 rpms
  15. Dec 31, 2023 at 6:28 AM
    #135
    MI-FL off roader
    Brett
    Merritt Island, FL
    Got my LT trims at idle leveled out. They were rich by an average of 5-8%. Now sitting almost even with ST trim. This gives me a start on getting closed loop dialed in. Open loop tuning will be a lot more difficult.
  16. Jan 1, 2024 at 5:27 PM
    #136
    MI-FL off roader
    Brett
    Merritt Island, FL
    RCF Throttle Body installed. Might be a step in the wrong direction, but we'll see.
  17. Jan 5, 2024 at 4:43 PM
    #137
    MI-FL off roader
    Brett
    Merritt Island, FL
    Transmission work this week. Got a mild upgrade on my valve body to firm up the spongy shifting. Also installed an 11" x 11.5" Hayden w 2 - 5.2" Spal pusher fans, switched out a few of the trans hoses, and put a Magnefine Trans Filter in line. . Truck is running good so far. 20240104_122604.jpg 20240104_142923.jpg 20240104_142933.jpg 20240105_074713.jpg 20240105_165747.jpg 20240105_165754.jpg
  18. Jan 6, 2024 at 7:18 AM
    #138
    MI-FL off roader
    Brett
    Merritt Island, FL
    FYI for everyone: Here is a video that John at IPT Performance Transmissions made using the valve body I purchased off Ebay and is the one I installed in the post above. I decided to roll the dice with this chinese reman, and I'm glad I sent it out for the service at IPT. The solenoids DID NOT MATCH my wiring harness, so I had to swap in my old solenoids. Truck worked fine last night on a 30 mile test drive, but I would say the Ebay Valve Body was a mistake.
    https://youtu.be/LVjcGONU4Sk?si=vY_9VG-Z_e6YaaRT
  19. Feb 11, 2024 at 4:06 PM
    #139
    MI-FL off roader
    Brett
    Merritt Island, FL
    Pearl goes to the Desert.
  20. Feb 15, 2024 at 4:55 AM
    #140
    MI-FL off roader
    Brett
    Merritt Island, FL
  21. Feb 16, 2024 at 7:58 AM
    #141
    MI-FL off roader
    Brett
    Merritt Island, FL
    Next day trip was out to the Vulture Mtns, AZ.[​IMG]
