PCS [pre-collision system]
Discussion in 'New Member Introductions' started by RubyRed19, Jan 7, 2024.
  1. Jan 7, 2024 at 7:36 PM
    RubyRed19
    RubyRed19 [OP] New Member
    Patti
    2023 4Runner TRD Pro
    Running Boards /black out w/ Windows tinted,
    My dash warning light is on after snow & ice’d on my tk in 25-30° weather. It’s been on 3+ days now. I can’t turn on or change any settings. The vehicle is clear of the elements now.
    xana22 and Naruto_HD1 like this.
  2. Jan 7, 2024 at 7:52 PM
    steelevo
    Utah
    Welcome. Usually the PCS warning will clear after the sensor has been cleaned and driven a few miles with the clean sensor.
    icebear and 2Toys like this.
  3. Jan 7, 2024 at 8:40 PM
    RubyRed19
    Patti
    Thank you!!!
    xana22 likes this.
  4. Jan 8, 2024 at 3:04 AM
    xana22 likes this.
  5. Jan 8, 2024 at 3:44 AM
    laxman09
    laxman09 Gassy Member
    Mahoning Valley, OHIO
    Had this turn on for me driving the PA turnpike on saturday. Wiping away all the snow/slush had it back in order.
    xana22 likes this.
  6. Jan 8, 2024 at 7:16 PM
    DesertSurfer
    Welcome aboard!
    xana22 likes this.
  7. Jan 9, 2024 at 12:48 PM
    UofLCardfan77
    UofLCardfan77 Large Member
    Elizabethtown, Kentucky
    Welcome from the center of the bourbon universe.
  8. Aug 31, 2024 at 5:19 PM
    64mech
    64mech New Member
    I’ve noticed in heavy rain the pcs unavailable warning will come on. Seems to clear up fairly quickly.
  9. Dec 27, 2024 at 8:16 AM
    Naruto_HD1
    Naruto_HD1 New Member
    Ruben
    New here. Ran into a similar problem where in heavy weather my PCS would disable while driving. I have a 2021 4runner SR5. This past fall the system was disabled for the majority of November. My frustration is that the cruise control would not function. I started to look in to see what the issue might be. I found the wire harness behind the sensor was full of water. So much that it started draining onto my leg when I pulled it out. I didn't see any issue with the loom or with any of the connectors so I was confused why so much water was in there. I dried the harness out I inspected it for corrosion it seemed to be OK. When i reinstalled it i used heavy electric tape. Home Depot sells some that is rated for outdoor use. Needless to say I wrapped the **** out of it connectors and all. We've had some heavy rain and snow in the Chicago land area since then. No problems whatsoever. I didn't need to replace the harness or the sensor or anything. I figured I would put this out there so that frustrated owners have something look for when troubleshooting.
    Tojlim24 and icebear like this.
  10. Dec 27, 2024 at 8:26 AM
    Interesting, my PCS alert just showed up for the first time yesterday, a couple times in very heavy rain but also went away not long after.
    Just in case, you can revert to “classic” cruise by holding down the cruise button and I personally use it more due to my sense (unconfirmed) that adaptive cruise is a bit too brake happy.
    Naruto_HD1 likes this.
  11. Dec 27, 2024 at 9:48 AM
    You can unplug it and clean it up as well.
