Paint Oxidation
Discussion in '4th Gen 4Runners (2003-2009)' started by aolson6, Jun 25, 2020.
  1. Jun 25, 2020 at 10:20 AM
    aolson6
    aolson6 [OP] New Member
    Andrew
    2005 SR5 4X4
    3" Toytech Lift with Coilovers and Toyo Open Country AT 285s
    Hi all,
    My 2005 original paint is getting pretty bad on the roof, fenders and lift gate. It is mainly the clear coat, but some spots are seeing wear in the base coat too. I don't want to spend $2k+ in a new paint job, so wanted to see what you guys have done.
    Has anyone used https://www.automotivetouchup.com/ ?
    For a few $100 I think I could use spray cans and get a not-so-shitty coating on there.
    Thanks for the thoughts.
  2. Jun 25, 2020 at 11:04 AM
    Dillusion New Member
    KYle
    If you are just planning on spraying it with no prep I'd advise not to.
    Unless you don't care if it comes off again soon.
  3. Jun 25, 2020 at 11:22 AM
    aolson6
    Andrew
    2005 SR5 4X4
    I would prep it fully. Sand, primer if needed, base and clear coat. It would probably be sufficient, just not look amazing. Which, whatever.
  4. Jun 26, 2020 at 4:51 PM
    DblZeta
    DblZeta New Member
    2006 Sport Edition 4x4 V6 Galactic Gray
    PT546 Radio
    Here is what i used to paint a mirror and the spoiler and a fender flare. 20200509_172427.jpg 20200510_092120.jpg
    El General***** likes this.
  5. Jun 26, 2020 at 6:18 PM
    KYle
    Prep is the main thing. With a 14 year old 4R I'd prolly do the same thing as you honestly.
    I've just seen some lazy asses just spray over with no prep and then cry later.
  6. Sep 5, 2020 at 7:33 PM
    Ruthven13
    Ruthven13 New Member
    2003 Limited V8
    I tend to think that if you spray can over large areas it will twnt to come out, well, not so good. As in probable crap. Going this route you would need to use a buffer machine with a compound product to smooth it out. If you don't care about looks then go right on ahead and take your time with it. It just boils down to what kind of a look your going for. So for whichever way you do it, cheers mate!
