P2716 Code
Discussion in '5th Gen 4Runners (2010-2024)' started by roc, Sep 9, 2023.
  1. Sep 9, 2023 at 5:09 AM
    roc
    roc [OP] New Member
    Michigan
    2021 4Runner TRD ORP
    Had the dash light up MALFUNCTION transmission, then switched to see dealer.
    Made an appointment but before I got there the lights went out. They said I would get charged $170 to run a scope if no current engine light was on and said to bring it right back if it did.
    So two days later it does the same thing, can tell something is wrong because when I shift from Neutral to drive it slams pretty hard. I get it back to the dealer, 30 mile drive, light is still on he takes a photo of it. But from the time they take the 4R from me and to the garage supposedly the light went out. Had a history code of P2716 but since it's not current warranty wont cover it.
    Sounds like a faulty pressure control solenoid. They cleared the code and told me to bring it back if it came back on but to take the aftermarket skids off, warranty doesn't cover removing those.
    In two weeks I'm planning a 2500 mile trip up through the Upper Peninsula. I see that code can send the 4R into limp mode. I don't trust taking it that far and having it break down in the middle of nowhere. Hopefully it gets fixed by then or I'll be driving my truck instead and these are the kind of trips the 4R is great for, 3/4 ton truck not so much.
    41,000 mi. 100,000 mi. platinum warranty.
  2. Sep 16, 2023 at 4:35 AM
    roc
    roc [OP] New Member
    Michigan
    Light come back on and transmission started doing the same thing. Got it back to the dealer and the light stayed on this time.
    They got it fixed, so far. Faulty solenoid assembly. Took 4 quarts of WF transmission fluid to fill it back up after dropping pan.
    backpacker and JETSPD1477 like this.
  3. Mar 10, 2024 at 3:29 PM
    BantamEddy
    BantamEddy Grand Poo Ba
    2021 Silver ORP
    Dobinson MRRs, Method 701s, Greenlane Bumper, Sherpa Winch, Black Oak Lightbar Greenlane Roof Rack & Ladder
    I just encountered a similar scenario. As luck(?) would have it, I am due for transmission service. I’ll share the fix.
  4. Mar 11, 2024 at 4:41 AM
    roc
    roc [OP] New Member
    Michigan
  5. Mar 11, 2024 at 4:51 AM
    BantamEddy
    2021 Silver ORP
    @roc , am I reading this post right that you were not charged for the solenoid replacement?
    EDIT: Nevermind, I see that it was covered by warranty in your original post. Time for more coffee! LOL
  6. Mar 21, 2024 at 11:40 AM
    BantamEddy
    2021 Silver ORP
    Delayed update by about a week but the dealership did fix it saying that it was a loose wire. The amount of time it took them to do it did not sit well with me though…. :facepalm:
