P2111 code with Brake Override Malfunction
Discussion in '5th Gen 4Runners (2010-2024)' started by Glenn Goodlett, Jun 3, 2023.
  1. Jun 3, 2023 at 7:59 AM
    Glenn Goodlett
    Glenn Goodlett [OP] New Member
    Glenn
    2020 TRD Pro
    Paid for
    As I turned into my jobsite my 4Runner beeped and said "Brake Override Malfunction, See Dealer". The gas pedal did nothing at this point. My 2020 TRD Pro with 80K miles would only drive at walking speed so creeped to my office trailer and killed the engine.
    Turns out a P2111 code is a throttle body stuck open. I cleared the code with my Carista and it ran fine. Seems the throttle body may need cleaning according to internet searches.
    I removed the throttle body and was shocked by how dirty it was. I drive in an extremely dusty environment everyday but, it looked like I forgot to put in the air filter. I do change the air filter at every 5000 mile oil change. I was using Fram air filters until they cheaped out and deleted the pre filter and the wire mesh. I'm currently running Wix filters.
    Anybody have any ideas how to keep from ingesting so much dust?
  2. Jun 3, 2023 at 8:23 AM
    Stitches1974
    Stitches1974 New Member
    2023 Nautical Blue TRD ORP
    Good that you're running wix, as they're one of the better air filters. I wouldn't use fram anything. In any of my vehicles, as I tend to stay with OEM filters.
    A good video to watch if you have a few minutes to spare:
    2ndGen22re likes this.
  3. Jun 3, 2023 at 8:38 AM
    Glenn Goodlett
    Glenn
    2020 TRD Pro
    Paid for
    Triple checked, everything is correct, clamps are tightened, etc. All that dust came through the filter.
    Thanks, the video is how I got turned on to the Wix filter.
  4. Jun 3, 2023 at 2:04 PM
    aelfkins
    aelfkins New Member
    2021 4Runner Off Road Premium KDSS
    Just storage mods.
    If it's all put together right with no leaks, and you've got the best filter you can, then it seems that you just need to clean your filter more often.
  5. Jun 3, 2023 at 5:06 PM
    Holy schnickey! That ain’t right!!! I cant believe a paper filter would allow that much dust through. Maybe a K&N would, but not any regular filter.
    Besides an install error, maybe a filter had a bad gasket?
    But why is it wet inside there?
    Also, what’s going on with the mating/sealing surface between the throttle body and intake plenum? It looks horrible…
  6. Jun 3, 2023 at 8:36 PM
    JETSPD1477
    JETSPD1477 New
    Typical 4Runner
    given your willingness to remove the tb i’m sure my advice is already in your action plan.
    it’s unlikely anything catastrophic happened but that amount of intrusion into the tb and manifold isn’t good either.
    i’d look at the filter more often and adjust the change intervals. air flow follows the path of least resistance and probably the root of the intrusion since the filter was so clogged.
  7. Jun 3, 2023 at 9:36 PM
    Glenn Goodlett
    Glenn
    2020 TRD Pro
    Paid for
    Just checked my service records, the vehicle has had 19 air filters installed since new in 80k miles. I don't think the filter was ever clogged. I think fine silty dust passes through the filter, much like it does the cabin filter.
    It is wet inside from the oil vapor via the crankcase ventilation system.
    McSpazatron and JETSPD1477 like this.
  8. Jun 3, 2023 at 9:42 PM
    JETSPD1477
    JETSPD1477 New
    Typical 4Runner
    interesting thing about the silty dust. i’ve been on a few dusty trails but likely no where near as much as you. i’ve explored the intake pipe out of curiosity after a few days out in the dusty wild and not much was going on.
    is everything working normal after cleaning the tb?
  9. Jun 3, 2023 at 10:22 PM
    Glenn Goodlett
    Glenn
    2020 TRD Pro
    Paid for
    Everything seems to be OK but, I'm replacing the throttle body and gasket anyway.
    JETSPD1477 likes this.
  10. Jun 4, 2023 at 7:31 AM
    The cabin air filter doesnt have a gasket around the filter. Also the cabin pulls air from everywhere. It’s not a sealed system. It can’t be compared to the engine air filter, which is designed to filter ALL the air sent to the engine.
    There’s something wrong somewhere. I can’t imagine any aftermarket filter media allowing this much dust through the engine. I just dont think this is normal, no matter how silty the dust it.
    I recommend going through everything. The airbox sealing perimeter, all the intake connections, missing plugs or hoses that have come off the intake tube, the sealing surfaces of the throttle body…something isn’t right.
    backpacker likes this.
  11. Jun 4, 2023 at 7:37 AM
    2ndGen22re
    CR
    Carson Valley, NV
    1990 22RE & 22 AG ORP KDSS
    WIX filters are far superior to most, especially Fram.
  12. Mar 4, 2024 at 2:06 PM
    soze
    soze Tiny Trucker
    Orange County, CA
    2022 MG TRD ORP
    Bone Stock
    So... I just ran into this over the weekend. I've only been on one light dirt road for camping and have only put on 9000 miles in my 2 years of ownership. I got the p2111 and brake override malfunction. Had it inspected and this is basically what they said caused the issue, but mine was nowhere near the level of what the OP posted. Is this a common thing? Given that I've barely driven and only trailed once, I didn't think I would run into something like this.
    Is the stock filter just not up to the task? Something wrong with the airbox design?
  13. Jun 1, 2024 at 1:19 AM
    soze
    soze Tiny Trucker
    Orange County, CA
    2022 MG TRD ORP
    Bone Stock
    So, I haven't gone on anything like dirt roads for camping since the last time before I went to the dealer to have it inspected. They "supposedly" cleaned up everything and I should've been all good. This was about 1 month and a half ago. Since then I've just been driving max 10 miles to work and back 3x a week. Not much driving at all. Today I was in a long line at the drive thru window and slowlly creeping along like you usually do at a drive through. Midway through the line, I get the dreaded CEL with a Brake Override Malfunction message on the dash. When this happens, it also flashes the green crawl control indicator on the dash even though I haven't ever touched that button.
    Something isn't right. And I'm not sure where to start looking.
