P0441,P0455 Code, What else to inspect?
Discussion in '5th Gen 4Runners (2010-2024)' started by Lc200, Sep 4, 2023.
  1. Sep 4, 2023 at 3:11 PM
    Lc200
    Lc200 [OP] New Member
    Pre Facelift SR5P
    My truck has been throwing the p0456,0441,0455 codes for the last few weeks.
    I changed the gas cap with OEM but that did not help.
    I did the smoke test and found a small leak in the canister.
    I replaced the charcoal canister, purge valve and the vacume hoses.
    The fuel pump was changed last year and the o ring was fine. It is believed that while changing the fuel pump, the o ring should also be changed cause it has a tendency to tear/crack. The tank was lowered and the o ring was intact.
    Cleared the codes and they came back after 2 days. No smell of fuel from anywhere. Appears to be running fine.
    I currently have 0455 and 0441.
    I am not sure if I have a leak so small that I am unable to detect. Maybe a pinched/cut wire or hose.
    Any idea what direction I should be looking at, my patience is wearing thin on this. Don't want to keep replacing parts anymore.
    TIA
