P0441 again..
Discussion in '5th Gen 4Runners (2010-2024)' started by Steve40th, Apr 4, 2026.
  1. Apr 4, 2026 at 11:45 AM
    Steve40th
    Steve40th [OP] New Member
    sTEVE
    I know what the code is, and I cleaned the gas cap rubber seal and mouth if fill tube to tank.
    Cleared code, 160 miles later it came on.
    Clearee code again and am going to monitor miles again.
    I use Torque app to detect fault codes and an Actron (spelling) scanner.
    Question I have is, is it common for our gas caps to fail?
    Or is it the evap on drivers of engine system?
    93000 miles, 2019.
    ToyotaDude99 and NB4x4 like this.
  2. Apr 4, 2026 at 12:08 PM
    NB4x4
    NB4x4 New Member
    Illinois
    2003 v8 sr5 4wd
    Replace the cap.
  3. Apr 4, 2026 at 12:20 PM
    Steve40th
    sTEVE
    I did order a new one.
    Now, when I bought this, their was a recall for the fuel pump, and that was 2022 I think. I did have it replaced the day I bought it at Toyota.
  4. Apr 4, 2026 at 1:07 PM
    Yep, My last one on the Tundra about 2 years and then the replacement has been a trooper. Must be hit and miss on qc on such a high volume production item... Or not. Depends on your opinion.
  5. Apr 4, 2026 at 1:08 PM
    Hungryhawk
    Hungryhawk New Member
    Southern CA
    2017 SR5
    The evap code is saying there is a vacuum leak somewhere in its fuel system: fuel tank, fuel pump gasket, hoses that connect fuel tank to gas cap & filler tubes. The charcoal cannister and its hoses are part of this system. My Pilot had this issue for months. Turned out It had a tiny vacuum leak where the gas pump nozzel filler tube (steel) connected to a steel tube that lead to fuel tank. It was not designed for service-so I made some tools to pry it apart. I silicon greased 2 large O-rings where these two parts joined. it solved the issue.
    You said your fuel pump was replaced. So the tech certainly disconnected lots of parts in this evap monitored system. Try to learn what he took apart?
    An old school mechanic used a low pressure smoke pump to spot likely leak sites. He wanted big money to replace some components which is why I did a DIY for just my time-all day Saturday and a Sunday morning plus a smear of new grease.
  6. Apr 4, 2026 at 1:11 PM
    Steve40th
    sTEVE
    I am going to the dealership Monday to ask if this is still covered under any warranty due to it being recently worked on per say, and its emissions related. Cant hurt to ask.
    Otherwise, I will replace cap, do a vacuum test on purge valve. And, well, just monitor it.
  7. Apr 7, 2026 at 6:08 PM
    ^You got the fuel pump recall done 4 years ago? There wouldn't be any remaining warranty on the shop workmanship.
    Emissions warranty for most items (except catalytic converters and PCM) is the same as the bumper-to-bumper warranty, 3yrs/36k from date of first use.
    Do a visual inspection of the evap hoses and clamps. With 7 yrs and 93k, some of the clamps may have cracked from rust. One of the flaws of OEM constant-tension clamps is they aren't stainless.
  8. Apr 7, 2026 at 6:15 PM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Mods? Don’t ask… Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar Armor: RCI Skid plate package C4 Gas tank skid (modified) RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS extended travel shocks: (Front: IMS59-50574 w/ Apache CF220 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Diode Dynamics XPR reverse bulbs LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    Might just smoke test it honestly. Could be something very simple
    TrailSpecial22 and NB4x4 like this.
  9. Apr 9, 2026 at 8:24 AM
    08TXRunner
    08TXRunner New Member
    '20 SR5P
    Buy an OEM one, not something off Ebay or Amazon. I've been burned twice with fake OEM caps on Amazon for a Tacoma and my old 4Runner. They both leaked and brought back the code. After buying one from the dealer I never had a problem again.
  10. Apr 9, 2026 at 10:01 PM
    2Toys, NB4x4 and TrailSpecial22 like this.
  11. Apr 10, 2026 at 4:24 AM
    my 2011 SR5 with 177,000 miles on it has its original gas cap and no issues. A 2022 has 58,000 miles on it no issues.
    I would just replace the cap. It’s too easy not to try there first.
    NB4x4 and Hungryhawk like this.
  12. Apr 10, 2026 at 7:32 AM
    2Toys
    2Toys Imperial Star Cruiser
    Gordon
    2019 4Runner TRDORP
    I had to replace the gas cap on my 2015 Tacoma once so far. The truck is now at 143k miles. I did use an OEM fuel cap.
  13. Apr 10, 2026 at 7:49 AM
    Amen, always start with the basics AND always use OEM parts.
  14. Apr 10, 2026 at 9:46 AM
    KSChief21Runner
    KSChief21Runner New Member
    Don Meredith
    21 Trails grey ghost
    I bought it already had leather. Some audio
    To echo 3JOH22A
    If no other codes present then chasing a leak is not helping you.
    "P0441 Evaporative Emission Control System Incorrect Purge Flow"
    With as many bad vs good aftermarket purge valves out there I stick to OE. I experienced, again, this issue on Tuesday. This time it was a NAPA part the individual had installed.
    morfdq, TrailSpecial22 and NB4x4 like this.
