P0430 after misfire bad coil
Discussion in '4th Gen 4Runners (2003-2009)' started by buddy75, Jun 18, 2024.
  1. Jun 18, 2024 at 9:05 AM
    buddy75
    buddy75 [OP] New Member
    Jason
    2005 4Runner V6 Sport 4WD
    Hello: first timer here. I had a bad coil in cylinder 6 misfire. Drove it only a short (1/2) mile back home. Check engine light came on with P0430 code. I replaced coil and spark plugs. Light never went off. Used a bottle of cat cleaner and it still stayed on. Replaced downstream O2 sensor and that seemed to do the trick. However, about a month of driving it it came back on again. I haven’t taken it to a mechanic and my skill set is probably not sophisticated enough to replace CAT. Should I replace upstream O2 sensor and see if that works? I’m concerned it is the CAT but I don’t want to spend that kind of money on this vehicle that has 215k miles. Any help would be appreciated. Thank you!!
  2. Jun 18, 2024 at 12:21 PM
    RonT4R
    RonT4R New Member
    Ron
    Virginia Beach
    2007 4runner SR5 4WD
    Fuel injector was my misfire problem not the coil pack.
